01-07-2020, 03:20 PM | #1893 |
Rep 3
Hi,
Which Android screen have you installed? I have a 7.1 Android screen from Andream. Which has the exact same problem. Hotspot not automatically connecting and the bluetooth sound is horrible. |
01-07-2020, 03:41 PM | #1894 |
Rep 3
You can use the idrive controller with apple careplay to navigate in spotify, google maps etc. The i drive controller does not support other 3rd party apps on your android screen.
Controlling spotify with idrive is better than by touch... |
01-07-2020, 04:01 PM | #1895 | |
Rep 399
Create a new profile: Event, System, Device boot. Tasks: 1. Start KswMedia app (I've changed this to the BT app instead, it's better because the KswMedia starts playing music immediately) 2. Wait 500 ms (you might need to increase) 3. Press Back button 2x (change this to 1x if you're using the BT app in step 1) Edit: You can now install KSW_SoundRestorer to fix this bug. This also fixes a similar bug in call volume. Thanks to Frankly30 Last edited by Mjam; 11-16-2020 at 02:27 PM.. |
01-07-2020, 04:10 PM | #1896 |
Rep 399
Is it possible to extract the launcher files from Ksw-P-Userdebug_OS_*-ota.zip, edit them, then pack together and install/update? I want to insert a tile for starting DAB-Z, and change the tiles for browser and file manager.
I found this URTool from Kri: https://github.com/chinesebmwheadunits/URTool I know about the LayoutChanger, but this requires root and Magisk/Xposed. |
01-07-2020, 04:41 PM | #1897 | |||
Rep 1,048
EDIT: Download of 3.7.5. and OEM 3.6.6 can be found here. Code:
ro.build.display.id=Ksw-P-Userdebug_OS_v3.7.5 ro.build.version.incremental=eng.zlx.20191225.103649 ro.vendor.build.date=Wed Dec 25 10:38:54 CST 2019 ro.vendor.build.fingerprint=Android/msm8953_64/msm8953_64:9/PKQ1.190202.001/zlx12251038:userdebug/test-keys Feature : Temperatur unit selection C/F has been implemented Feature : Restart Option has been added at Profile import (factory_config.xml) Bugfix: changes to Audio drivers, changes unknown Bugfix: Rotation direction of Bluetooth dial has been switched ? Software: Google Services have been updated Software: TXZAdapter.apk software updated, related to Music player ? Software: Easyconnection software updated, related to Music player ? , Text found that Android 10 is not supported Software: CMfilemanager.apk has been removed (cyanogenmod Filemanager, was not active at all) other: Antman movie demo has been replaced by 4K_demo other: implementation of how MCU Version information is read has been changed other: two navigation software have been added to navigation selection list of factory_config.xml, Atlan (korean) and TomTom other: "client" field at GUI`s have been removed, old factory_configt.xml do still work. all in all not alot new stuff. i have it in my room at the moment, haven`t tried it in car as i have not really time at the moment. so maybe some other changes have been made which i have not recognized. Quote:
you don`t need to repack the whole OTA image, you can replace the .apk file with adb when the device is rooted. To change the apk you need programming skills then keep in mind that software updated from the chinese are published very often, so you would need to reprogram the apk every time they deliver a new package, which is just not worth the time. Its easier to use the "workaround" using a different tile. If you have ID7 GUI, then you can select DAB-Z for "Music" app under settings, then your small Music tile will start DAB-Z if you have ID6, then add "com.zoulou.dab" to the "SupportDvrApplist" of your factory_config.xml, activate activate "USB DVR" under Factory Settings, so it will start DAB-Z when selecting the "DVR" Tile. Kri Last edited by Kri; 01-07-2020 at 11:07 PM.. |
01-07-2020, 06:10 PM | #1898 | ||
Rep 3
https://www.aliexpress.com/item/3302...3b857909ldaPbg In the description of the productpage it says the 1920x720 res screen is a snapdragon |
01-07-2020, 10:30 PM | #1899 | |
Rep 122
01-08-2020, 03:03 AM | #1901 | |
Rep 45
01-08-2020, 03:38 AM | #1903 | ||
Rep 32
01-08-2020, 06:20 AM | #1904 |
Rep 63
01-08-2020, 07:58 AM | #1907 |
Rep 32
If you want to see the average fuel consumption, travel time and average speed while playing Carplay or Android Spoty. it's not possible?
01-08-2020, 09:15 AM | #1908 |
Rep 51
that is not entirely true i can listen to the oem radio and have sound from igo navigation works like a charm . best to try different nav software
01-08-2020, 09:35 AM | #1909 |
Rep 8
Dear Forum members
I have this system: Coika 10.25 "Android 9.0 System 8-Core Cpu For Bmw 5 Series F10 F11 2011-2017 With 4 + 64G Ram Touch Screen Zlink Swc Wifi Dvr https://nl.aliexpress.com/item/40001...1cdb4c4dVeTmaG The following problem occurs, when I make a long car ride (more than an hour), the sound drops from carplay, radio or navigation voice away every 3 minutes for 2 seconds, at short distances, there is no problem at all. I contacted my Vendor and got the latest MCU from him and installed it, but today still had the same problem. Did anyone recognize this problem? And if so, does anyone know a solution ? Everything is connected according to instructions. |
01-08-2020, 09:54 AM | #1910 | |
Rep 399
Check, and check again that QuadLock is correctly inserted. Regarding MCU, which version (date) did you get? |
01-08-2020, 10:23 AM | #1911 |
Rep 8
THX Mirjam for your answer.
Sorry but what do you mean by amp ? (amplifier ?) if so i don't have. I will check Quadlock, but it's strange that the problem is coming after an hour and not after a sort drive MCU version i become from my Vendor is Z03_BM_F13_191226A(13-17款宝马5系专用MCU程序) the problems that I had, described in an earlier post about 4G and LTE, have been corrected with this update Last edited by TRP; 01-08-2020 at 10:37 AM.. |
01-08-2020, 10:36 AM | #1912 |
Rep 67
@TRP
Please note! You can't compare your device to Snapdragon or PX6. You have a special device with Intel processor, You need special mcu and firmware files for that and can't use posted files. |
01-08-2020, 10:38 AM | #1913 |
Rep 8
