12-18-2020, 01:07 PM | #2225 |
Rep 17
Hi
I updated my Android 10 to this last firmware.. But i cant now acess to pen USB with music player but if i Open the file explorer i Saw the files on USB.. can u help me? Another question but i think it was relacioned.. update the factory config.. i have the file on pen USB but on profile update it says no file on external drive. Thanks guys |
12-18-2020, 01:10 PM | #2226 | |
Rep 68
Everything is described here https://f30.bimmerpost.com/forums/sh...&postcount=372 Additionally, you can also download some sample kswoverlay.apk file from this forum. Unpack it and see the directory structure. |
12-18-2020, 02:32 PM | #2228 | |
Rep 1,048
Check at the Headunit at Factory Settings the knob type. Kri |
LittleSamurai4.50 |
12-18-2020, 02:38 PM | #2229 | |
Rep 4
Factory Config file 2.5.8:
I have MCU Ver:615085dFY-N4.5-G-DC-201105 on my wife Mercedes. I have downloaded the merc version, just need to know how to install it into the HU. Thanks. Last edited by scroll11; 12-18-2020 at 02:44 PM.. |
12-18-2020, 03:07 PM | #2231 | ||
Rep 1,048
I Updated 1st Page 1st post, its now explained there Quote:
Kri |
12-19-2020, 02:36 AM | #2233 |
Rep 2,367
Drives: E63 645Ci
Maybe... and this is a big maybe. We are working on an app that will hopefully intercept buttons so you can remap them or disable altogether. But this is not ready yet.
12-19-2020, 03:49 AM | #2234 |
Rep 5
Hello!
I’ve got a HU, SD625 The volume of the internal microphone is terribly low. I bought an external microphone, but unfortunately the same thing .. Could you do something about it with a software update? Or what is their suggestion to solve this problem? APP Ver: Lsw-Q-Userdebug_OS_v2.3.0 THX |
12-19-2020, 04:09 AM | #2235 |
Rep 55
Quick question regarding the time on our units. I’ve set the time on the HU to sync with the vehicle. Whenever I start the vehicle the HU starts up with the time set to 12:42. It can then take up to five minutes before it corrects itself to the actual time. If I try to start Waze before the time has corrected itself, Waze gets completely confused. Is there a CMOS battery that should be keeping the time whilst the vehicle is off?
12-19-2020, 04:34 AM | #2236 | |
Rep 1,048
Code:
ro.product.locale=zh-CN ro.product.locale.language=zh ro.product.locale.region=CN You can also try to change location at Android settings, but i am unsure if this will also do the job. Kri |
12-19-2020, 04:43 AM | #2237 | |
Rep 353
Here's my video on how to do that: https://youtu.be/F52m1Sy2jpQ |
12-19-2020, 04:46 AM | #2238 | |
Rep 353
There's no any battery to save time in the HU. |
12-19-2020, 04:54 AM | #2239 | |
Rep 5
Can't you simply disable it? |
12-19-2020, 04:57 AM | #2240 | |
Rep 68
Could you please specify what the settings should be for Poland? Thanks |
12-19-2020, 06:00 AM | #2241 |
Rep 353
12-19-2020, 06:49 AM | #2242 | |||
Rep 1,048
For ro.product.locale.langage use "locale" code which does define the language For ro.product.local.region use the "variant" (country) code which does define your country. For ro.product.local use the combination of of "local" and "varian" with an "_" between. them. For alot of Countries, language and Region codes are the same value, but there are also alot of contries who have different one. Some samples: en_US -> English - United States en_UK -> English - United Kingdom en_CA -> English - Canada de_DE -> German - Germany de_AT -> German - Austria pl_PL -> Polish -Poland And Finally, always beware of changing build.prop files, you need to know what you do, you need Root permissions and partition has to be remounted to be able to modify the file. Also do not use build.prop file from other OTA versions , always do edit the file from the actual OTA version, as the sometimes the file is different from OTA version to OTA version. Kri Last edited by Kri; 12-19-2020 at 07:11 AM.. |
Tomasz_pl12.50 LittleSamurai4.50 |
12-19-2020, 07:41 AM | #2243 |
Rep 9
12-19-2020, 08:28 AM | #2244 | |
Rep 55
I’ve tried syncing with android instead of vehicle but the same occurs!? No one else sees this behaviour? |
