04-09-2020, 05:04 AM | #243 |
Rep 114
With latest 1.41 i can't make to work Google assistant. I make it system priv-app as always and i can do the assistant to voice match but then is not saved.
04-09-2020, 08:20 AM | #247 |
Rep 59
A quick question under boot logo my unit has an option to import new logo. Anybody know where the file should be for the import to work. And which file type does it look for zip or .IMG. thanks in advance.
04-09-2020, 12:29 PM | #248 |
Rep 59
Well I figured it out if I put the animation.zip, or the logo.img on to an USB /oem folder and boot the device it updates the logo or the boot animation. It would be nicer if I could do this through the import button they placed in the software but anyways.
Another question related to the digital speedometer and rpm the scale is way off on mine it goes up to 380 KM/hr is there a way to correct this. I already checked the correct top speed in the factory settings but it did not fix it. |
04-09-2020, 12:38 PM | #249 |
Rep 13
Hi all. Received my unit from MEKEDE on AliExpress. I have a BMW E87 without any screen.
Currently having an issue with sound & AUX. My car has Bluetooth, USB and AUX as standard with BMW Professional Headunit. However, I removed the fiber optic cable from the original quad lock to add to the harness provided, and when I do this, the original head unit loses AUX, USB and BLUETOOTH options therefore no sound for the Android screen. When I plug the original BMW professional back in with the original quad lock, everything works fine, USB, Bluetooth and AUX, it's only when using the android harness. |
cesarortiz23324.50 |
04-09-2020, 02:32 PM | #250 |
Rep 6
Astrowind seller from AliExpress just told me that they are about to release a new version more updated than 1.4.1, more bugs fixed
daschacka76.50 Alpina_Guy4.50 |
04-09-2020, 10:45 PM | #251 |
Rep 9
Tell me, is there a contact for the firmware developer?
On two HU, I encountered the problem of detecting the location in GPS when the LTE network is connected. Satellite signal strength is high, but the location is not fixed. The LPP_PROFILE settings in /etc/gps_debug.conf do not solve the problem. Solves the problem of forced LTE disconnection in the settings of mobile networks in Android by enabling the "auto GSM WCDMA" mode. I assume that some operators do not support LPP in LTE, and the head unit fails. |
04-09-2020, 10:52 PM | #252 |
Rep 9
I want to say about Mekede from Aliexpress. This year, he's not responding to messages. Sends a lot of defective devices. During the dispute, he lies to the arbitration that the device is working normally, although the fault is obvious. Many of us couldn't get a refund. We have added Mekede in the black list.
04-10-2020, 02:16 AM | #253 | |||
Rep 1,048
The "SevenColor" Dashboard scaling can`t be changed, you would need to change to some of the old dashboards, this can only be done via factory_config.xml, change the number of following: Code:
<!-- Dashboard selection 0:General 1:Tri-color dashboard 2: seven color Dashboard --> <Dashboard_Select>2</Dashboard_Select> Quote:
i`m curous when this will happen as 1.4.1 is only 3 days old Quote:
depending on your seller it will be implemented, i also had two changes/fixes got implemented through my seller (navidom) Its important to explain them the issue and the solution as good as possible which is no easy job Kri |
04-10-2020, 02:34 AM | #254 |
Rep 1,170
Hey guys so I want to get my self one of these android 10.25 screens
But what's a good brand or where to buy from I've heard of avinusa Is that the best place to purchase one of these I mean it seems fairly easy to purchase one from there website with choosing options etc. Or are all these units exactly the same ? They sell one that says 10.25 Android 10 qualcomm snapdragon with 4gb ram and 4g SIM card Is that a good option or ???
bmw m2
04-10-2020, 06:49 AM | #256 |
Rep 30
Victor84900.00 |
04-10-2020, 06:56 AM | #257 |
Rep 32
04-10-2020, 04:59 PM | #258 | |
Rep 59
04-10-2020, 08:54 PM | #259 |
Rep 13
Hi guys. I sorted the sound issue out. Now I have one more question.
I have a GPS receiver that goes into the back of the screen and also a 4G/LTE receiver but nowhere to plug it in? Any ideas? And also I have no sound on navigation app, any help? Last edited by Livar; 04-10-2020 at 09:09 PM.. |
04-11-2020, 04:04 AM | #260 |
Rep 72
Is it possible to enable greek language? i tried to modify factory xml . Greek language appeared but because it is the same id no 15 with french it change to french. any help? Maybe the id number is wrong?
04-11-2020, 04:48 AM | #261 |
Rep 220
Drives: MINI Cooper, 2020 X1
No, Chinese applications (only KswPLauncher and KswPMedia are needed) do not contain many languages, they do not contain Greek translation. I created my own translation into my language and uploaded it to the rooted Android using LuckyPatcher.
04-11-2020, 05:00 AM | #262 | ||
Rep 1,048
Have you tried to activate it under normal android Settings ? its basicly the same as at the BMW GUI. Quote:
with which navigation app, its depending on the APP if it does support it at all. Kri |
04-11-2020, 06:21 AM | #264 | |
Rep 13
Do you know where I can input the LTE receiver? |
