07-28-2019, 02:39 PM | #1 |
Rep 500
Drives: BMW 330e F30 M-sport
255 rear and 235 front?
So I'm currently running 235/40R19 front and 265/35R19 rear, but I have slight rubbing issues in the back, so I'm thinking either reduce to 265/30R19, or go 255/35R19.
I will loose 11mm of height if I go to 265/30R19, and I also worry it will be too harsh of a ride, so I'm leaning towards doing 255/35R19. But in the front I have no problems, and not really that keen on reducing the width. Would it be fine to run 235/40R19 in the front and 255/35R19 rear despite the fact that it will increase the difference in diameter between front and rear somewhat? I have a RWD (not X-drive).
Thorbjorn
16 BMW F30 330e M-sport Bootmod3 Stage2 / BMS Intake / RM Motors high flow catted downpipe & custom exhaust / BBS CH 19" / H&R Sport springs |
07-28-2019, 10:19 PM | #2 |
Rep 681
That should be fine I think. M cars come with 255/35/19 and 275/35/19 stock which is a similar difference to what you would see with this setup. Differences in tire height mostly come into play with xdrive cars.
2016 328ix F31 - SOLD!
2006 997.1 C4S |
hybris204.50 |
11-05-2019, 04:28 AM | #3 | |
Rep 1
I want to scale up to the same tire sizes but my car is a 428i Gran Coupe, normally that size should not rub, can you tell whether it is due to wheels? |
11-05-2019, 11:37 AM | #4 | |
Rep 500
For other readers: I did end up doing what I planned here, so I'm now running 235/40R19 front, and 255/35R19 back. This solved my rubbing issue.
Thorbjorn
