12-14-2018, 12:31 AM | #3 |
Rep 897
I'm running iptv but on a cable box
2014 f330d
2015 f335d 2016 f32 440i tanzanite/white merino 2008 Toyota Yaris sr 2005 e46 320d. 1996 316i. |
12-14-2018, 02:12 AM | #4 |
Rep 1,801
Nvidia Shield is still regarded as the best.
Depending on what you are streaming many of the cheaper boxes cope fine. If its netflix, iplayer or similar you're fine on everything but if its local content at 4k you're going to need something a bit beefier. I originally started with WDTV Live's. They were okay but when I moved onto a T95M (4k) - https://www.amazon.co.uk/Tronic-T95M.../dp/B06ZZF5VPV - it was far better. Since getting a 4k HDR TV the older boxes simply couldn't cope with the content. They'd jitter and buffer and simply were not up to the job even though they are 4k capable boxes. I bought one of these for the 4k content and it copes fine. https://www.amazon.co.uk/gp/product/B07FD1SN2G The problem is some heavy 4k streams are upwards of 150mb/sec and most cheap boxes only have a 10/100 network port so are simply unable to handle the throughput. The cheaper box sat at 85mb/sec solidly then buffered then repeated. It just needed that little bit extra through put to handle the content. |
12-14-2018, 04:26 AM | #5 | |
Rep 777
Thanks for the info now looking to run a cat6 cable to hardwire it.. |
12-14-2018, 04:46 AM | #6 |
Rep 1,801
The Beelink GS is decent and I had looked at those I was just in a rush and the one I bought from amazon was around the same money and has slightly better spec.
For the older boxes I run them with OpenElec to make them that bit faster but there seems to be issues with the gigabit lan on some of the units that OpenElec doesn't play nicely with and at the moment I dont have time to mess around with "fixing" something that isn't really broken on the new box. The older boxes with a 10/100 card can work better with a £10 USB3 -> Gigabit lan adapter but they then have the hardware bottleneck with the GPU with some content. |
12-14-2018, 05:02 AM | #7 | |
Rep 777
As I already have a cat 6 cable to my compo would it be possible using a switching box 10/100/1000 instead of running another 15 metre cable from the router? |
12-14-2018, 12:36 PM | #10 |
Rep 32,881
Why not just install IPTV app on your TV?
Donny_1962476.00 |
12-15-2018, 01:48 AM | #12 |
Rep 256
12-15-2018, 02:40 AM | #13 |
Rep 156
12-15-2018, 03:34 AM | #14 |
Rep 256
12-15-2018, 03:41 AM | #15 |
Rep 1,799
Me too please as a Google search for satguru reveals nothing
U06 230e Active Tourer |
Previous : 2019 F31 340i : 2017 F31 335D M-Sport |
12-15-2018, 04:13 AM | #16 |
Rep 777
Depending what OS the tv has it may not allow an IPTV to be installed also its best to go through a good VPN when connected so another app the TV may not let you install.
You can do all this on a box even if you have to sideload to get it on its more difficult with a TV OS unless you have an android TV |
12-15-2018, 04:27 PM | #20 |
Rep 777
