BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > 2013 F30 Xdrive sedan rims and tires
Studio RSR
      12-18-2018, 07:34 AM   #1
Kongomann
Drives: 2013 328i Xdrive sedan
Hey everyone, I'm new to BMW and this is my first one. I have the stock rims and tires right now that come with the F30. I'm looking at getting some rims and tires put on it and wanna be sure since im new to this that I can do this. Can I get the same size tires and rims for the format and back or di they have to be offset? I dont wanna lower the vehicle at all but just wanna take up a little bit more space on the wheel well part just so it sits nice and comfy. any information would be great. Thank you
kong lee
      12-18-2018, 08:42 AM   #2
SunzOut
Drives: '18 340i and '00 M Coupe
Yes a "square" setup with the same size rims/tires on front and back is common vs the "Staggered" setup where the rear tires/rims and normally wider than the front. If you check the wider tires will have the same diameter (or very close) as the fronts. That's the requirement on modern cars so the traction/stability control does not get confused.
when looking for a square setup, you will normally have corners the same a the current front wheel size.
      12-18-2018, 09:01 AM   #3
Kongomann
thanks! yeah I'm looking to get the exact same set up bit instead of 17s I wanted 19s is all
kong lee
