12-26-2019, 10:40 AM | #2 |
¯\_(ツ)_/¯
945
Rep 1,762
It most definitely is satisfying... just seeing the end result is worth taking the time to clean the wheels. I try to clean mine once every two weeks depending on the weather.
Adams wheel/tire cleaner, boar hair brush, ez wheel cleaner brush and a 2gallon garden sprayer. Touch up the tires with meguiars endurance tire gel
wdeerfield2745.00 |
01-13-2020, 08:56 AM | #3 |
Rep 849
Drives: BMW 435i
Very satisfying. Probably one of the great side benefits of swapping wheels between winter/summer is getting a chance to clean the wheels off the car.
01-13-2020, 11:55 AM | #4 |
Rep 16,051
I clean the inside in the fall, when I rotate. I started using Flash Brown Royal last year, it's amazing stuff.
https://www.amazon.com/Flash-Brown-N...WE8M25EKZGEX26 On the inside I spray with Brown Royal, wipe it a bit with a medium Scotchbrite pad, then rinse. It really makes them look like new. |
01-17-2020, 07:58 AM | #5 |
A family of bimmers
2745
Rep 7,741
I clean mine once a week when washing the car. ez wheel clean brush, microfiber mitt and just car wash soap. they dont need much other than that if you stay on top of it.
My winter wheels on the other hand get a good dose of wheel cleaner for a minute or two and then pressure washed down in the spray off bay when the weather is favorable in upstate NY. Weekly trips to vermont leave them plenty dirty.
01-17-2020, 09:43 AM | #7 |
A family of bimmers
2745
Rep 7,741
If you are referring to the barrel of the rim. Yes. The split 5 spoke im able to get in there without issue.
01-17-2020, 12:32 PM | #9 | |
Rep 1,641
01-18-2020, 03:58 PM | #10 |
Rep 6,696
Drives: F30 340i
01-20-2020, 05:18 PM | #12 | |
Rep 849
Drives: BMW 435i
Looking at a picture of them they wouldn't be that hard using something like a Speedmaster or EZ Detail wheel brush. With those you can leave the brush straight and get behind the spokes or the brush shaft itself bends and you can bend it to an angle which will get back there better. I've also simply used my finger to get the last little bits I couldn't reach with a brush.
10-10-2020, 07:17 AM | #13 |
Rep 33
Drives: 2016 328ix
Received a package of Meguiars products recently. Is the Meguiars Wheel and Tire cleaner, pink bottle, safe to use on the OEM 403M factory wheels? Thanks in advance for any input.
10-11-2020, 08:47 PM | #14 |
Rep 2,193
Meguiar's G9524 Hot Rims Wheel & Tire Cleaner (pink/purple bottle) is listed as safe & effective on factory painted & clear coated rims, & tires as well.
Whatsupguy19.50 |
Tags |
bbs, bbs super rs, bbs wheels |
