11-02-2018, 01:02 PM | #1 |
Rep 46
F31 328d xdrive Staggered Setup - Warranty invalid
I purchased a used 2015 F31 328d xdrive wagon with 403M wheels and tires
19x8 - 225/40R19 - Pzero bmw star tires 19x8.5 - 255/35R19 - Pzero bmw star tires (0.4% difference in tire diameter front to rear) When I took my wagon into the dealer for service they said my factory warranty was no longer valid (for suspension, transmission, transfercase) because I was running incorrect tire sizes (they did not match the factory specs listed in the door jam - 18x8 - 225/45R18 all around) I contacted BMW of North America and was told the same! There are many xdrive cars that come with this staggered setup (I know in Europe xdrive wagons come with these exact wheels/tires as an option). Has anyone had this experience in the US? (I posted this story in another thread before I was allowed to create my own threads, sorry if you are reading this for a 2nd time!) Last edited by jseeleybmw; 11-02-2018 at 03:55 PM.. |
11-02-2018, 02:22 PM | #2 | |
Respect My Authoritah
368
Rep 873
Seems like they'll do anything to void a warranty. P.S. You mention 18x8 and 18x8.5, but the tires are 19".
2014 335xi M-Sport 6MT: Estoril Blue II, MHD Stage 2+ , Dinan Exhaust, Dinan CAI, ER Catted DP, ER Chargepipe, AA FMIC.
11-02-2018, 02:34 PM | #3 |
Sedan Driver
389
Rep 1,018
I’m quite surprised so many threads about different than stock tires voiding warranties. It’s ridiculous.
What happened to magnuson moss warranty?
Slapping on M Performance parts, ZHP, badges, and stickers does not ///M car make
ZCP | ZHP | ZTR | ZE0 | MSport | ZMP | DHP | MStickerPack | THP | MPPSK | MPPK BMW MSP Lightweight Jacket | DTM Motorsport Team Cap| BMW M Drift Cat 5 | BMW M Thermo Mug |
11-02-2018, 02:52 PM | #4 | |
Rep 1,232
11-02-2018, 03:35 PM | #5 |
Rep 1,452
11-02-2018, 03:57 PM | #6 |
Rep 10,473
It’s in effect.
You just need to hire your own experts, have them run tests with your size tires on several BMWs models the same as yours for several hundred thousand miles to prove it will not cause an issue. And BMW will bring their experts and their evidence it does. Good Luck. Seriously OP, in your defense, you are using the BMW OEM 403m wheels with correct size tires that come on the 403m from factory, so there should be no issue and when push came to shove, you should be able to prove that to saner minds....as along as you get your facts straight on what’s what. |
Beek707.00 |
11-02-2018, 04:02 PM | #7 | |
Rep 46
Sorry, the 403M style wheels ARE 19" (updated now on the initial post)
When things like the transfer case begin to fail at 38k miles and the car is under factory warranty... I would like to think they cover it and not say oh, but your tires, we can't help you anymore! Quote:
I guess they want people to lawyer up to get anywhere... |
11-02-2018, 04:14 PM | #8 | |
Rep 16,080
Also, OP, is the dealer saying you have no warranty the one who sold you the car? If that's the case the tire size problem is his, not yours. Last edited by Billfitz; 11-02-2018 at 04:21 PM.. |
11-02-2018, 04:17 PM | #9 |
Rep 1,045
What a joke, soon they'll void your warranty for breathing too close to the engine. You would think they're smart enough to know this is bad for their PR. The least they can do is warn people about it when they bought the car new, at least they can do that so people know.
11-02-2018, 05:40 PM | #10 | |
Rep 46
I'm not sure how I prove that this tire setup was available as an option for my specific car, I don't think it was in the US. For other xdrive cars sure, as well as for the 320d xdrive wagon in Europe which is basically the same car, but not my "exact" car... As I stated in the first post, the tire diameters are 0.4% different, and are the same specs as found on other xdrive cars that come factory with staggered setups. This is my first BMW, but I'm coming over from Audi, so I'm used to having to maintain consistent tire diamters all around... Audi's system at least allows up to a 5% difference... not allowing 0.4% is bonkers. I currently have put the same size tires all around to try and satisfy the dealer (225/40R19's), but the rears are brand new and the fronts are worn and I'm still having issues and they are saying the diameter difference from the front set being more worn than the rear is the cause of my problems... that's one sensitive AWD system! HA! exactly my thoughts... |
11-02-2018, 09:14 PM | #12 | |
Rep 46
Paying out of pocket at a real shop is looking more enticing... |
11-02-2018, 11:04 PM | #14 |
Rep 46
I have 3 issues->
1) Studder on acceleration; I assume a failing transfer case, but my dealer won’t diagnose the issue until the front tires are replaced. 2) Excessive bump steer; I’m constantly fighting the steering wheel when going over any sort of bump/rough road. 3) Car pulls to the left when braking heavily. (Interesting if I let go of the wheel when braking heavily the car will track straight under heavy braking, but the steering wheel pulls right) I’ve had the car aligned 3 times now, the last time at the BMW dealer. They claim the car is perfectly aligned and there are no worn components/bushings, bent control arms or tie rods and the wheel bearings are good. They won’t proceed any further until the front tires are replaced, claiming that it’s causing all 3 issues, which sounds like BS to me. Will update when I get further (replace the tires and take it back in) FWIW I did have 2 other issues which were fixed by the dealer on two separate visits due to check engine lights; Clogged DEF and failed SCR module (now replaced) Last edited by jseeleybmw; 11-02-2018 at 11:15 PM.. |
11-03-2018, 04:12 AM | #17 |
Rep 878
Won’t you likely get these differences if the tyre pressures front to back are different even on a non staggered wheel setup? Are they really saying that this particular f30 xdrive is that sensitive and intolerant, does that not make it not fit for purpose?
11-03-2018, 05:40 AM | #18 | ||
Rep 15,858
Issues 2 & 3 "could be" due to tire wear, particularly as you are on the larger 19" wheels with a lower profile. What is the wear like? Odd? Don't forget pressures are a possible culprit. Have you checked with a decent pressure gauge? Issue 2. Even the feeling of bump steer can be tires, I had that feeling on my E91 with run-flats. Can be very sensitive to pressure and temperature. I know when I changed to non run-flats it disappeared. Issue 3, if not due to odd tire wear.. has the car been in an accident? Issue 1. You mention engine issues, DPF problems. I'm wondering if it is EGR related, (EGR valve and/or carbon build up). Diesel stutter and hesitation can be an EGR problem. We experience it over here in Europe, one of the first things to check out when a diesel engine is hesitating. Any particular engine speed and loads? |
11-03-2018, 05:53 AM | #19 |
Rep 15,858
Shouldn't be any issues with xDrive using star marked approved tires in the OE sizes, if set to appropriate pressures. BMW do reference a 1% allowance for the RC, within the tire logic function. Technical data often mentions allowance for a 2 - 3mm tread variation, front to rear. We must also ensure tire pressures are in 'tolerance', as RC is also a function of load/pressure.
11-03-2018, 09:12 AM | #21 |
Rep 126
Thats Why I will not mod a car under warrentee .....But your getting screwed by dealer, if car was purchased like that... I talked to my dealer and said any mods void warrentee . And I quote he said anything....custom wheels,lowering suspention,exhaust......
11-03-2018, 02:42 PM | #22 |
Rep 891
This is nonsense. You could option staggered wheels and tires on any F30 xDrive MSports if you opted for the summer tire option, the all-season option was a square setup.
If that option voided people's warranty they might want to have disclosed that to avoid a lawsuit.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
