07-12-2019, 04:36 AM | #1 |
Rep 75
4 equal tires with M tires
good morning.
right now I have wheels 400M, 8.0 front with 225, and 8.5 rear with 255. Has anyone tried to put 245/40/18 on all 4 tires? Will I lose a lot of traction? will I gain direction? |
07-12-2019, 06:53 AM | #2 |
A family of bimmers
2747
Rep 7,742
you will gain turn in and they will fit just fine so long as you are not xdrive. You still wont be able to rotate around the car though since the rim width and offset front to rear is still different.
07-12-2019, 10:39 AM | #3 | |
Rep 75
I'm not xdrive I want to gain some direction, so it will be my next change. thank you |
07-12-2019, 12:36 PM | #5 |
Rep 75
07-12-2019, 01:17 PM | #6 |
Rep 4,327
a 255 is wider than 245. why would you lose rear grip?
i run 245/40/18, 255/40/18 on my aftermarket wheels. going from 225 to 245 in front will increase front grip and reduce understeer thus a higher speed can be carried through a turn. |
07-13-2019, 12:45 AM | #7 | |
Rep 75
I explained it badly. I mean if with 245 I will notice less traction than with 255 in the back |
