03-03-2015, 06:51 PM | #1 |
Rep 1,894
Europe NEXT 2015-2 Maps are now available
Hi all,
As posted by fellow members in my other thread, the Europe NEXT 2015-2 maps are now available. It also appears that the usual location for the maps has been closed.....boo. Anyway never fear, here they are . I've downloaded and installed myself and in the post below, I've included the instructions from the 2015-1 guide and updated the lookup.xml + download location, so you just need to whack in your DE file into the generator. |
03-03-2015, 06:54 PM | #2 |
Rep 1,894
Here is mini guide on how to extract your DE (NBT) or 1B (CIC) file, generate the FSC code.
The method I am using requires ESYS and ENET Cable, I am aware there are other ways to extract such as using SWID_Reader but those methods did not work for me. Looks like people are having issues getting the FSC Generator. Here is the link of where I got the original files from: https://mega.co.nz/#F!ugo0HB5L!TPCmejMKPBlRRkz2SDvg0Q and then extract the lookup.xml.zip. Prequisites: ESYS ENET Cable PSDZData Lite (lite version is fine for FDL coding, you only need the full package if you want to flash ECUs) Token (not required to reach FSC Extended) To get the esys and psdzdata files, goto the coding forum and send an email to shawnsheridan, he will PM you the links. NBT/CIC EUROPE + North America NEXT 2015-2 Maps (19GB+ download) http://www.e90post.com/forums/showthread.php?t=995629 The mapping data from the location above for 2016-1 (for Europe), are no longer available without payment to the OP. Fair play as he is offering a service. Therefore you can grab the Europe NEXT 2016-1 Maps from here: http://gpsunderground.com/forum/bmw/...worldwide.html NOTE: The lookup.xml attached has the Europe/North America 2016-1 entries added. In the coding forum there is a sticky called BMW F30 3 Series Coding DIY - Code Auto Start Stop, DVD, Folding Mirrors, Etc. in the first page, there are guides on how to start up E-Sys. if you are generating maps for NEXT then you need to follow the guide for DE if you are generating maps for MOVE, MOTION or PREMIUM then you need to follow the guide for 1B Extracting the DE or 1B file: Fire up E-sys make sure your connected to the F20 (not F20_Direct) via your VIN and then in the left hand vertical menu select FSC Extended. For NBT (DE File): In the Parameter section enter: 1. Diagnostic Address (hex) = 0x63 2. Click on the Identify button and the Base variant HU_NBT will be populated 3. Application ID for NBT= 0xDE 4. Upgrade Index = 0x1 For CIC (1B File): In the Parameter section enter: 1. Diagnostic Address (hex) = 0x63 2. Click on the Identify button and the Base variant HU_CIC will be populated 3. Application ID for NBT= 0x1B 4. Upgrade Index = 0x1 In the Action section: 5. Select Store FSC and move from left to the right 6. Click on the Read button 7. Click Save and and name the file in the following format XXXXXXX.fsc where XXXXXXX is last seven letters/numbers of your VIN or your donor NBT vin if you have retrofitted the NBT. 8. [Optional] You can now disconnect e-Sys from your car as the next stages can be performed offline. Getting the Code Generation Software: Unzip the directory attached. The directory can be placed/run from anywhere. Generating the FSC code using the BMW_CIC_NBT_FSC_Generator for NBT: If you are generating NBT, copy fsc.exe in the NBT_FSC directory to the tools directory 1. Place your XXXXXXX.fsc into your tools directory (same location as the Base64.exe) 2. Open a command prompt (DOS Screen) and go to the tools directory 3. Type "Base64 XXXXXXX.FSC XXXXXXX_000DE001.FSC" and press enter 4. Open BMW-FSC-NBT-Generator.exe 5. Click "Browse" and select the XXXXXXX_000DE001.FSC file you generated in step 3, it should be in your tools directory. 6. Choose your map product from the list (For me it was "Road Map EUROPE NEXT 2015-2) 7. Click "Generate" Generating the FSC code using the BMW_CIC_NBT_FSC_Generator for CIC: If you are generating CIC, copy fsc.exe in the CIC_FSC directory to the tools directory 1. Place your XXXXXXX.fsc into your tools directory (same location as the Base64.exe) 2. Open a command prompt (DOS Screen) and go to the tools directory 3. Type "Base64 XXXXXXX.FSC XXXXXXX_0001B001.FSC" and press enter 4. Open BMW-FSC-NBT-Generator.exe 5. Click "Browse" and select the XXXXXXX_0001B001.FSC file you generated in step 3, it should be in your tools directory. 6. Choose your map product from the list (Road Map EUROPE PREMIUM 2014-1) 7. Click "Generate" Preparing the USB stick: Takes about 45 mins to upload the Maps to your car; make sure you enter the code in CAPITALS, it has been said that you should have the car on/running during this period. But for me just pressing the Start button once was enough. Once the update is done, you will get a success message, wait a few minutes then turn the car on/off and then the version number will reflect the new map. NBT USB stick needs to be FAT32 (32GB is enough), when you extract the map data to the stick make sure you extract the folders to the USB root. The folders will be like: 1 (directory) 2 (directory) 3 (directory) 4 (directory) config.nfm NBT_ECE_101141.3.111.pkg NBT_ECE_101141.3.111.pkg.sig CIC For the PREMIUM (CIC) maps you will have 3 directories: USB1 (directory) USB2 (directory) USB3 (directory) Copy the entire contents of USB1 to the root of the USB stick, should only be the following: config.nfm pkgdb (directory) Once uploaded to the car, the car will ask for USB2. Delete the both the config.fm and pkgdb from the root and repeat the above with USB2....and then again with USB3. Notes: What happens when NEXT/Premium 2015-3/2016 comes out? You just need to edit the Lookup.xml file with the new map details, just look at the previous entries, its follows a sequence. Backup your FSC file!!! Save your XXXXXXX_000DE001.FSC file, you can now just refer to this file and generate as and when the new maps come along. If you lose this file you will need to do the extraction steps again. Last edited by kitster; 03-15-2016 at 08:30 PM.. |
03-04-2015, 01:22 AM | #3 | |
Rep 1,858
03-04-2015, 01:25 AM | #4 |
Rep 1,894
03-04-2015, 01:40 AM | #5 |
Rep 8,083
Download doesn't work for me. I get the error but don't see a 'download anyway' link
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
03-04-2015, 01:45 AM | #6 |
Rep 1,894
Strange. I've just tried this on Safari and Chrome (OS X) and they both work for me.
Try this one but without the translation bit: https://drive.google.com/folderview?...m8&usp=sharing |
03-04-2015, 01:51 AM | #7 |
Rep 8,083
Cheers mate. That works but it will take a while with it not being a torrent!
Ian
03-04-2015, 07:00 AM | #8 |
Rep 8,083
All done. Shame there isn't anything that tells you the changes. If they've just added a back road in Belgium is it worth the effort!
Ian
03-04-2015, 08:12 AM | #9 |
Rep 8,636
2015-1 made some big changes on the roads I use specifically the reroute around the Birmingham airport runway extension, but that's been open ages and only made it in to the last update!
03-04-2015, 08:18 AM | #11 |
Rep 8,083
Coincidentally going round there tomorrow. So it was worth it then.
Ian
03-04-2015, 10:19 AM | #14 |
Rep 1,207
Same here.... awaiting !
03-04-2015, 05:05 PM | #17 |
Rep 83
03-05-2015, 07:06 AM | #20 | |
Rep 1,244
Drives: 2013 F10 M5
The map data is going to be *alot* harder to come by going forward. As of 01-01-2015, BMW shut down all of the internet facing map repository servers (which is how most people were able to use the HDD-Update program from ISPI Next to download maps). All of the map downloads are now locked away behind BMW's dealership portal (S-Gate Europe, S-Gate ZA and Dealerspeed) in the ISPI Cockpit console. Also, simply having an account there doesn't get you access either, ISPI Cockpit normally requires an access level of Service Manager or higher in order to get in so it's not something a lot of people are going to have. BMW has been actively tightening security around their platforms, especially in terms of retrofitting and coding. It's already been evidenced by the recent changes in the ISTA/P data in relation to E-Sys and trimming of the CAFD data starting in 3.54 and getting worse in 3.55. It's gaining more evidence with the changes to the map repositories and I wouldn't be surprised if they start making changes to the ISPI Next versions of ISTA/D and ISTA/P before too long. It'll soon get to the point that it won't be worth the time or the effort to keeping acquiring these to put out for everybody. It already costs a fair amount just for the bandwidth costs to seed all of the map updates out to everyone (my outbound bandwidth is roughly 50-75 terabytes a *month* just in seeding). Torrent links are working, there was a problem yesterday afternoon with it, but they are all working now. |
