07-22-2018, 08:06 PM | #24 |
Rep 125
Pic below... This afternoon I changed the oil, and in the process, I pulled the belly pan and took a closer look at things... The front of the belly pan (under the oil filter housing) was clean, as were all the belts. As mentioned and as you can see, there's a fair amount of dirt build-up (172K miles' worth) but it's all dry. As was suggested, I cleaned it up best I could with brake cleaner and I'll continue to monitor it.
Since we're chatting, with the pan removed, I did notice a small amount of leaking oil from a thing a few inches in front of the oil drain plug (second pic, far left). I couldn't tell the origin of the leak... Is this something that likely needs attention? Thanks! Here's the other pic that shows the leak in front of the oil drain plug... |
07-23-2018, 07:54 PM | #26 |
Rep 1,487
Drives: 2108 X3 xDrive30i
Not a scam...it does happen more than you think.
07-23-2018, 10:19 PM | #27 | |
Rep 125
Thanks again. |
07-24-2018, 07:38 AM | #29 |
Rep 1,572
Yup! Classic example of the OFH rear gasket leaking. Change both. Done a couple and not hard. I also changed out all the bolts and thermostat housing plugs.
