06-10-2021, 02:03 AM | #1 |
Rep 121
320Gt broken parcel shelf clips
Ive done stupid thing when installed rear camera and placed my shelf that attaches to rear boot door wrong way round, and when closed the boot the lip of that shelf being wrong way round pushed on parcel shelf that right behind rear seats casing all 4 clips that coming from the body snapped.
Any solution to this? Ill try any DIY suggestions given Tried hot glue but it just comes off. How far do i have to dig to replace them? are they part of allot bigger piece of body panel? As per image below this is where clips go in to the panel.
Mess with the Best - Die like the Rest
06-20-2021, 12:41 PM | #2 |
Rep 121
Anyone? Just need to know where the clips attach to, what interior body part to i ca see if can re replaced.
06-20-2021, 03:26 PM | #4 |
Rep 121
How easy of a job you recon to remove side trim panels? Thank you for reply.
06-20-2021, 03:39 PM | #6 | |
Rep 121
found this, guess its close enough
06-20-2021, 04:01 PM | #7 |
Rep 16,079
Required if you do your own work:
https://www.amazon.com/dp/B07L6FJGR4...roduct_details |
06-20-2021, 04:25 PM | #8 | |
Rep 121
06-24-2021, 03:47 PM | #9 |
Rep 573
Looks as though you'll have to replace item number 3.
https://www.realoem.com/bmw/enUS/sho...diagId=51_8968 These instructions should help get you close enough. |
SerTan45.00 |
06-24-2021, 09:36 PM | #10 |
Rep 16,079
06-27-2021, 06:23 AM | #11 |
Rep 121
Thanks for info guys. I didnt get to opening amd pulling trim panels off but as a temp i manage to use wide screws, cut head off, put some hardened silicon inside holes where pins broke off and screw them in. But will get it repaired properly.
