BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > bootmod3 for BMW F series Vehicles - General Discussion
      04-02-2020, 02:43 PM   #2883
thejeremyman9
thejeremyman9's Avatar
626
Drives: 2015 BMW 335i
Originally Posted by alexp930 View Post
You really think its clutch slip? Wouldn't that result in an RPM spike?
I calculated it was about an E25 mix that I put in. These maps are 7.1 versions. I'll try and get some more logs on my way home.
Turn everything off except engine rpm and vehicle speed and you will see. It suggests either clutch slip or you were spinning.
      04-02-2020, 05:03 PM   #2884
designatedposter
Drives: m235i
your RPM did spike at 3400, see photo. to test it, go into 5th gear, and floor at 3000 rpm through 4000 rpm.
      04-02-2020, 05:06 PM   #2885
designatedposter
Drives: m235i
jynx!
      04-02-2020, 06:29 PM   #2886
thejeremyman9
626
Originally Posted by designatedposter View Post
jynx!
I think mine shows it better
Although you did annotate yours.
      04-03-2020, 06:23 AM   #2887
alexp930
Drives: Bmw
I do see that now. Thanks to both for the graphics. I'll keep an eye on it. Car has a 87K now and it's the original clutch to my knowledge. Soon I'll have to upgrade to the 550i clutch
      04-03-2020, 11:01 PM   #2888
JaredG_F30
JaredG_F30's Avatar
1019
Drives: 2014 335i, M-Sport, Manual
I also had clutch slippage running the stage 2 E30 bm3 map when I went to v7.1. Just turned over 80k miles. I upgraded to the 550i clutch and CDV delete. It's a solid upgrade.
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI).
SPI Films Blog/DIY Vids
      04-04-2020, 12:08 PM   #2889
AmuroRay
Drives: M235i
Part number or link to the clutch?
      04-04-2020, 05:04 PM   #2890
Justin_F32
Justin_F32's Avatar
Drives: BMW 435i
I bought my F32 with Bootmod3 already installed by the previous owner, how would I be able to use it?
      04-05-2020, 07:39 AM   #2891
msquaredF33
Drives: 435i
Contact pro tuning freaks with your VIN, they will get you the corresponding authorization code to login.
      04-05-2020, 08:07 AM   #2892
Justin_F32
Justin_F32's Avatar
Drives: BMW 435i
thank you, I did contact them their saying the car isn't in their system but the owner says otherwise
      04-06-2020, 12:05 PM   #2893
JaredG_F30
JaredG_F30's Avatar
1019
I bought all of my parts from FCP Euro as their price was competitive and I plan to keep this car for a long time so I might end up replacing the clutch one more time in its life.
Clutch Kit - $282.89 (this price just dropped as I paid $339)
https://www.fcpeuro.com/products/bmw...uk-21207603248
Slave Cylinder - $57.75
https://www.fcpeuro.com/products/bmw...te-21526785964
Pressure Plate Screw (you'll need 6) - $1.52/pc
https://www.fcpeuro.com/products/bmw...ew-21207548052
I was charged $514 for labor
      04-06-2020, 02:49 PM   #2894
designatedposter
Drives: m235i
did you reuse the dmfw? if so, how'd it look? how many miles?
      04-07-2020, 07:41 AM   #2895
JaredG_F30
JaredG_F30's Avatar
1019
Yes I did. The DMFW was in good condition and within spec. BMW recommends changing the DMFW every two clutch changes. This was my first. 80k miles on the stock clutch and DMFW. Even the stock clutch looked good. Plenty of friction material still on it. It just couldn't handle the power at WOT on the latest tune.
      04-08-2020, 06:15 PM   #2896
xnick101
Drives: 2014 Bmw 335i (F30)
Can you guys take a look at these logs and tell me if it's good? All 3 pulls done in third gear. Thanks
EWG car, Mods: IC, CP, DP, BM3 Stage 1 93.
https://www.bootmod3.net/log?id=5e8e...0b432fcc88de16
https://www.bootmod3.net/log?id=5e8e...0b432fcc88de14
https://www.bootmod3.net/log?id=5e8e...729b1444aa464f
2014 335i M-Sport
Bootmod3, VRSF 5" IC, VRSF CP, VRSF 4" DP, AFE Pro Dry S Drop-in Filter
      04-08-2020, 06:50 PM   #2897
thejeremyman9
626
I took a quick look at this one: https://www.bootmod3.net/log?id=5e8e...0b432fcc88de14
Timing looks pretty good. Do you have any E85 in the tank? STFT are fairly positive, more so than i see in my logs.
Boost starts to deviate from target after 5500 rpm. Its not horrible, since its only a little more than 1 psi, but nearing what I would think is "too far" below target (for an EWG on stage 1 at least).
      04-09-2020, 07:34 AM   #2898
xnick101
I dont. It's just shell 93 pump gas in it. I get around 1 more psi of boost after 5500? No complaints there.
What about AFR's? I don't know what the car is supposed to target for AFR at WOT.
2014 335i M-Sport
      04-09-2020, 07:47 AM   #2899
designatedposter
Drives: m235i
no, he's saying that you are UNDER target by 1 psi. i looked at one of my stage 1 logs from version 7.0 and it was same behavior. in my experience with bm3 ots tunes.. the boost deviation at the top end is typically 1 psi under, regardless of which map. if you want to verify, check a few other people's logs of stage 1 to verify the boost deviation.
      04-09-2020, 10:59 AM   #2900
thejeremyman9
626
As mentioned above i was saying you are UNDER target by 1psi. Again, not alarming, and as suggested check other peoples logs to confirm this is normal behavior.
The target AFR is in the log. You can check actual vs. target directly.
      04-09-2020, 03:06 PM   #2901
chaungo
=D
chaungo's Avatar
Drives: 13' 335ix
I spoke with Halim and it's how they tune it, normally they turn down boost up top for more timing, it's more consistent and IAT will rise much more slowly, in comparison of just turning the boost up where timing will be low or pulled, and IAT will shoot up. On EWG, normally the taper isn't bad, but on PWG, it's tapered alot more (On 2H maps)
2013 335i xDrive
Bootmod3, Pure Stage 2, Pure Inlet, GFB DV+, AFE Pro Dry S Drop-in Filter, ER CP/TIC CP, ER Catless DP, ATM FMIC, Borla ATAK, Dinan Springs, Dinan Shockware, XHP ZF8AT Stage 3, xDelete
      04-09-2020, 03:16 PM   #2902
thejeremyman9
626
Makes sense as a tuning strategy since stage 1 is designed to be applied to a stock car (stock IC).
      04-10-2020, 10:35 AM   #2903
xnick101
Ohhhhh LOL. Im going to assume Lambda [AFR] is the target and Lambda Act Bank 1 [AFR] is what the actual sensor is reading. Well that's good to know the logs look good. Crazy how high the AFR target is on these cars.
2014 335i M-Sport
      04-12-2020, 10:04 AM   #2904
Bmwman325
Drives: 2015 MG CR 335 XI 6SP
Was driving around today, casual driving nothing intense, was going up a hill in 3rd going about 30 mph and received a drivetrain malfunction codes I got
123601 Electronic wastegate control:Short
120408 Charge pressure control shutdown: pressure build-locked
I am running bootmod3 stage 2 93 oct, I upgraded to version 7.1 about 2 weeks ago, I've put several hundred miles on it since the upgrade, I have an upgraded charge pipe, intercooler and fabspeed catted downpipe. Should I clear codes and do a log?
