BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > bootmod3 for BMW F series Vehicles - General Discussion
proTUNING Freaks
      05-22-2018, 10:17 AM   #1387
Insane435
Insane435's Avatar
Drives: 435ix M Sport EWG
Anyone with N55, EWG, have an E30 map log I can look at?
2014 EBII 435ix - Armytrix Catback, Evolution Racewerks Downpipe - Chargepipe - Intercooler, Bootmod3, xHP Stage 3 Trans Tune, NGK 97506's, AFE Dry Filter, KW V1, Forgestar F14 19s, Potenza S-04's, M Performance Brakes, M Power Pads
2011 BSM 328ix
IG: @f32_rmacher
      05-22-2018, 01:42 PM   #1388
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
http://www.bootmod3.net/log?id=5b009370d10b4354bbc029fd
      05-22-2018, 06:38 PM   #1389
FSociety
@BM3Tuning @TristateBM3 @HCP.us
FSociety's Avatar
Drives: F98 X4MC, F90 M5, F80 M3 ZCP
Originally Posted by jv004 View Post
Planning to get BM3 Stg2 pretty soon and would like to run some e85 mixture since California only has 91 gas. Would E20-E35 be ok with the stock lpfp with BM3?
Currently FBO with catted DP.
Yep you will be fine just use http://www.georgebelton.com/E85Calculator.php
Originally Posted by Bimmertodd88 View Post
I run the e30 map on race nights. Runs well although only for the first fill up because I don't have a ethanol content analyzer installed yet so the mixture is off. After every e30 fill up I run 2 tanks of 93 to clean it out. If you plan to run e mixture all the time I would advise getting a ethanol analyzer.
I run E15-E20 all year to clean out the gunk in the crappy 93 lol
F90 M5 BM3Tuning STG2: 10.21@138mph --
F98 X4M TristateBM3 STG1: 10.8@127mph --
IG: bmw_F9XM
ronanz1724.00
jv004215.00
      05-22-2018, 08:27 PM   #1390
Insane435
Insane435's Avatar
Lol nice. Can you run e15 on the 93 map?
      05-22-2018, 09:41 PM   #1391
FSociety
FSociety's Avatar
I can & do, just monitor your HPFP.
IG: bmw_F9XM
      05-22-2018, 09:47 PM   #1392
Bimmertodd88
Drives: 2014 335i M-Sport
Ahh okay yeah I don't see any problems with the 93 I get but my always gets funky after trying to fill up twice on e30 I'm sure it's me messing up somehow but what ever lol
      05-22-2018, 09:50 PM   #1393
harkes
harkes's Avatar
China
769
Drives: M135i, NSX and AE86
HPFP is one thing. Another is the trims which you might end up maxing out adding too much E. Consequent of that is running lean. I'd say that checking your trims/AFR is most important in this scenario. If the hpfp run out you will just get a misfire.
M135i PWG, MHD, Pure Stage2, Torqbyte CM5-LT, xHP
(A Dane in China)
FSociety3323.50
      05-23-2018, 05:31 AM   #1394
harkes
harkes's Avatar
China
769
Originally Posted by reddemon73 View Post
Hello,
Can this be use in conjunction with PPK?
thanks
BM3 is a flash tune not a piggyback
(A Dane in China)
FSociety3323.50
      05-23-2018, 09:31 AM   #1395
FSociety
FSociety's Avatar
+1
That is correct, I start with hpfp to keep it simple the OTS itself will run a decent AFR and with E15 i don't think the AFR or Trims will max out at all.
I've tested E20-E25 on a 93 OTS but just for testing purpose and it was good, but i dont recommend others to do this unless they' know what they're doing and looking at.
At the end of the day E30 OTS Map with E20-E30 blend is going to be better for that.
+1
IG: bmw_F9XM
      05-23-2018, 10:26 AM   #1396
JaredG_F30
JaredG_F30's Avatar
1017
Drives: 2014 335i, M-Sport, Manual
bm3 will overwrite your MPPK but you can always flash back to the MPPK.
Hello,
thanks
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI).
SPI Films Blog/DIY Vids
      05-23-2018, 03:15 PM   #1397
deepghosh
Drives: '13 BMW 335i
Just out of curiosity, how lean would the AFR need to get before I should start to worry? I heard these cars run pretty lean as is
2013 F30 335i
BM3, MPE, VRSF DP, VRSF Street HD FMIC, VRSF Chargepipe, AFE drop-in filter, Bilstein B14 PSS Coilovers
      05-23-2018, 05:56 PM   #1398
harkes
harkes's Avatar
China
769
I would not be comfortable with anything above 13 from ~4000rpm and up. The OTS is on the safe side so there is some margin.
(A Dane in China)
      05-24-2018, 05:52 AM   #1399
enemigo13
Drives: F30 340xi
16.5psi @ 6000rpm? stock turbo?
Originally Posted by Anthony235 View Post
      05-24-2018, 10:58 AM   #1400
deepghosh
This is the "Lambda [AFR]" parameter in my logs, correct? There are a couple other [AFR] parameters not sure what they are
2013 F30 335i
      05-24-2018, 11:06 AM   #1401
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
Stock turbo.
      05-25-2018, 01:20 AM   #1402
enemigo13
Drives: F30 340xi
Stock turbo.
nice boost with stock EWG, what are the modifications? I have 16psi @ 6000rpm with stage1 pwg turbo but I have stock downpipe.
      05-25-2018, 05:45 AM   #1403
Dfahmy
Egypt
124
Drives: F30 335i PWG
2013 BMW 335i  [0.00]
Anyone interested in selling their BM3 license?
2013 335i BSM ~ Stage 3 turbo, forged internals and more check out my build thread https://f30.bimmerpost.com/forums/sh...7#post23789807
      05-26-2018, 03:04 PM   #1404
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
FBO (no cat).
My most recent log from today. I plan on getting the VRSF Race IC next. I bought their original street IC back in the day. I believe my IAT are causing my timing to not be as clean as it could be when I do very long pulls.
3rd through 6th gear pull on 8at. Should be about ~140mph when I let off.
http://www.bootmod3.net/log?id=5b09b67dd10b432f2edcca10
      05-27-2018, 09:39 AM   #1405
quick_335i
Drives: 335i
BM3 Help
Hey just wondering if anyone can help out, I tried making a support ticket but it won't let me login, it says "Error in Authorization"
I installed a catless DP and Stage 2 BM3 93 tune about a week ago.
The car drives great but I have a fuel system malfunction code.
Now I just had my LPFP recall done at bmw about a month ago, car always ran fine no codes.
I tried to online re-code and I get this error message, can anyone help out?
Is their and email address to contact BM3 directly or only though support tickets?
Thanks!
      05-27-2018, 07:54 PM   #1406
MTWO
Drives: M2
That 21208 code means you didnít run the online recode.
      05-28-2018, 06:25 PM   #1407
quick_335i
Drives: 335i
I tried to run the Re-code and got the message you see on the last picture
      05-30-2018, 01:31 AM   #1408
upsidedownfunnel
Drives: 2014 335i
2014 BMW 335i  [0.00]
I'm considering purchasing a license but was hoping someone could answer a couple quick questions. I've tried searching but couldn't find any solid answers:
- Car is a 335i EWG
1) Will exhaust burbles work on stage 1 91 octane? I am not looking for the backfire/shotgun type burbles. I'm just looking for a more aggressive and louder version of the stock burbles in Sport+ mode.
2) Can I run stage 2 without a downpipe? I plan on just eventually adding a FMIC and chargepipe to my car. I don't want to mess with the exhaust at all except for maybe a catback.
Thanks in advance!
