10-19-2021, 01:50 PM | #1 |
Rep 631
Hi all, one of my occasional posts
Oil service light is on, 3,500 miles since the last one but 2 years. BMW quote £260 for oil, micro filter etc. Question….. should I have it done? 67 335D no issues with oil, level at max and regular short trips. Thank you Update - Full oil service, filter £82.00 all in. Mobil 1 ESP. Shout out to ATS Cwmbran 😀
335D EB LCI - Debadged
10-19-2021, 02:18 PM | #4 |
Rep 631
No, who would you recommend and thank you 😃
10-19-2021, 03:00 PM | #5 |
Rep 572
10-20-2021, 06:32 AM | #6 | |
Bird Flu and Cat Aids combined
857
Rep 1,122
You can go to either BMW or a BMW registered Indie, not two weeks ago there was a post similar and it turned into an argument about where was better. Which ever you choose do your research and pick a good one based off it.
Instagram: BIFCAIDS
10-20-2021, 05:30 PM | #7 |
Rep 52
If you are not bothered about service history buy the parts and do it yourself it's a doddle. I drop the oil midway through intervals. Maybe OTT but rather preventative than curative.
10-21-2021, 02:11 AM | #8 |
Rep 4,935
Drives: 340i MPPSK
I always figure if you're planning on keeping the car, do interim oil changes. Up to now I've been getting the local dealer to do it (as 340i filters have been known to disintegrate on removal) but now looking at a local indie instead as the car is 6yrs old.
Life is a state of mind |
10-26-2021, 12:58 PM | #11 |
Rep 55
I just take my 330d to national tyres in between my bmw services and it's £80 to have the oil and filter done and you can specify your oil too for an extra cost,quite handy in the winter so your not doing it yourself in the cold 🤣
10-28-2021, 01:47 PM | #14 |
Rep 88
Would you guys recommend using a K&N oil filter, or sticking with OEM ?
I ask as i used to use K&N over the oem Nissan one for my R34 , so now i got a 335d, when it comes to service time soon, my plan was to buy K&N air filter, oil filter, and then i will go with Motul for the oil... |
MY340i713.50 |
10-28-2021, 05:34 PM | #15 | |
Rep 1,438
10-31-2021, 03:41 PM | #18 | |
Rep 1,438
335d is a great platform, a remap and an alpina gearbox flash and it’s a whole new beast. Are you doing the services yourself? If so autodoc is the best place to get parts, although takes two weeks or so to arrive from Germany. Yeah would stick with oem, aftermarket ones can cause headache down the line |
10-31-2021, 03:58 PM | #19 |
Rep 88
cheers for the info dude!
and not doing service myself, but if it was a case of buying aftermarket service parts, and asking the garage to service using those parts.... I'll look at using either BMW or a specialist who uses OEM parts Autodoc = very good, used several times with the R34 ..... 335d goes in this Sat for stage 1 ECU remap + Dyno + Gearbox map (cost £600), am using Avon Tuning nr Bristol... |
11-01-2021, 05:28 AM | #20 | |
Rep 18
that's very very cheap is gearbox on zHP stage 3? |
11-01-2021, 07:13 AM | #21 |
Rep 88
its £650 normally, but discount got it down..
Stage 2 on the gearbox, i like my MPG for motorway miles and the pricing is just right (am factoring in 15yrs worth of tuning on the JDM side )... |
11-01-2021, 08:15 AM | #22 | |
Rep 222
