12-07-2021, 01:46 AM | #1 |
Rep 40
Drives: 2009 335i xdrive
No heat w/ new motor and new thermostat
Howdy all,
Recently finished putting in a replacement motor (40k mi) after my 2015 335 (140k mi) spun a bearing. I could really use some help diagnosing a cabin heating issue. I'm feeezing in my car. Now that temps have fallen I am realizing I have no heat, and even less as temps drop lower. At 40+ deg F it will blow warm out of the far driver side vent and some very Luke warm out of the left-center vent. Any lower temps (today it is 15 degrees, just blows cold. Both passenger vents blow ice cold all the time. Dual climate set to 84 and stratification wheel set to hot. When parked, the temp of the air on drivers side will go up a bit but not much, and then will shoot back down while driving. Oil temp reads ~200 and in the hidden menu it says my coolant temp is ~200 after 20 mins driving. Could I have not bled coolant correctly? Is my new thermostat bad? Heater core? Blend motor?? SOS |
12-07-2021, 05:44 AM | #2 | |
Rep 844
EDIT: the thermostat is new and OEM right? You didn't reuse the one from the old engine?
2019 x5 50i - current
2016 340i THP stage 2 - gone but not forgotten. |
12-07-2021, 08:46 AM | #3 | ||||
Rep 40
Edit: I did squeeze what I believe are the coolant lines to the heater core (right next to the refrigerant lines) and they are definitely hot. |
12-07-2021, 09:50 AM | #4 |
Rep 16,065
If the lines to the core are hot then the core should be hot, so that points to the heater vent flaps being at fault. Either they're stuck in the closed position or they're not getting the command to open.
12-07-2021, 10:40 AM | #5 | |
Rep 844
12-07-2021, 10:52 AM | #6 | ||||
Rep 40
[IMG][/IMG] |
12-07-2021, 12:36 PM | #7 |
Rep 145
You can also try to flush and backflush the heater core. My car did the same, even when the hoses leading to the core and out were hot, the cabin wasn't getting any of the heat.
I did go the ISTA route to trigger all the flaps before flushing. Be careful of the pressure of the water used while flushing though, you definitely don't want to cause a leak at the core since it's inside the dash |
12-07-2021, 03:12 PM | #9 |
Rep 40
12-08-2021, 12:29 AM | #10 |
Rep 145
12-08-2021, 05:40 PM | #11 | |
Rep 40
12-08-2021, 10:49 PM | #12 |
Rep 145
He literally shows you in the video but for those who can't watch:
Turn on acc mode Heat max Lowest fan setting Hold down accelerator for ten seconds, you should hear the water pump activate I left cap open, he mentions it's up to you, I'd rather not use the screw there Just let it cycle and if you're not sure, do it again You don't ever ever want to open the coolant tank when the car is hot since it's pressurized. After that warm the car up and see if heat comes out |
12-09-2021, 12:58 PM | #13 | ||
Rep 40
12-09-2021, 04:04 PM | #14 | |
Rep 145
Try backflushing the heater core and doing it multiple times Hoses may feel hot, but what do you have to lose ? I think heating system isn't that complicated, coolant flows to the heater valve, then gets to the heater core, the core gets hot and air is blown through it and out the vents. If there's some things clogging up the core, and trust me, you might see some gnarly things come out- I did on mine, it'll prevent the core from staying hot. Coolant may flow, but there may be debris in the core that prevents it from maintaining its heat I don't think it's the heater valve since you said the hose going into the firewall and heater core gets hot |
01-13-2022, 06:28 PM | #15 | ||||
Rep 40
01-14-2022, 06:26 AM | #16 |
Rep 145
01-25-2022, 03:37 PM | #17 |
Rep 3
Im facing a very similar issue and its driving me nuts. Can you tell me how you flushed the heater core?
01-27-2022, 12:31 PM | #18 | |
Rep 145
If it's a quick and easy flush, try to angle the hoses vertically so more coolant doesn't drain from the engine and try to tuck it somewhere while you deal with the heater core. I believe you need 3/4 ID hoses for the heater core so grab some of that and a bucket. You need a water hose adapter. If you watch chrisfix's heater core video, he shows an overview of the process since it's pretty much the same for every car now. Connect hoses to the heater core. Connect the water hose into the heater core outlet and slowly release water from the hose. I'd suggest a valve there or something. Water will flow against the normal flow of the heater core...hence backflushing it. Let it run for a few mins then stop and pulse the water. Once it looks clear, switch hoses and flow the water the normal way and keep switching back and forth until you feel comfortable with how clear it is. Once that's done, blow into the hose to empty out as much water as you can from the heater core and pour down distilled water into the heater core. Once it's full and distled water is draining out one end, reconnect the cars heater core hoses. Then trigger the water pump bleeding procedures...run it twice. Make sure you don't see any bubbles in the coolant tank and you should be good to go. I'd just YouTube BMW heater core instead since it's pretty much all the same |
