BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Akebono on M Performance Brakes
      12-07-2018, 12:25 AM   #23
Vulpe
Vulpe's Avatar
280
Drives: F87 M2C
Originally Posted by eleven11 View Post
No worries mate.
I wasn't 100% sure the price was for a set (left + right), so I stalled on placing the order.
I thought that for a moment too because it said something like "pad" instead of "pads" and the price, but I thought there would be no way to purchase sides separately instead of a full 4 pad set. They just came in and they are complete sets with new wear sensors and grease included. Also with just visual checks they look correct.
eleven11371.50
      12-07-2018, 07:16 AM   #24
ChristosD
ChristosD's Avatar
South Africa
97
Drives: m135i
Out of curiosity has anyone tried the m3/4 pads on the m performance brakes. I have them in red and my SA said they will fit as the calipers are the same? (at my cost obviously)
'14 F20 M135i EWG FBO:// INJEN INTAKE // PURE INLET// TURBOSMART BOV DUAL PORT //
//CSF INTERCOOLER // ER CP // SNOW S2.5 METH KIT // B58TU HPFP // NGK 97506 // ER DP // TMSS MID PIPE //MPE // MPBBK // UR STRUT BRACE // BM3 CUSTOM JORDAN E85 TUNE // XHP STAGE 3 //
      12-07-2018, 11:08 AM   #25
M4_GTS
Hong Kong
1153
Drives: M4 GTS
They will fit. But they will also dust a lot.
      12-10-2018, 01:29 PM   #26
Sanelko
Sanelko's Avatar
70
Drives: 2012 Jet Black 328i
Anyone install the Akebonos on their M-sport/performance calipers yet? How are they (performance, noise, etc.)?
      12-11-2018, 06:17 PM   #27
ChristosD
ChristosD's Avatar
South Africa
97
Drives: m135i
i dont mind the dust are they better then the stock pads? am i correct in saying msport and mperformance use the same pads[
      01-02-2019, 06:24 PM   #28
yoon_209
Masterchief
yoon_209's Avatar
Drives: 20' BMW M340i
Any reviews on the akebonos or r1 concept ceramics??
So im assuming based off what everyone is saying the EUR1880 front will fit even the unfinished grey 4 piston brembos but the EUR1656 will not fit for the single piston rears????
is the 1656 does not fit do you know if the 1610 fit the single piston calipers?
AWE Non-Res Touring | TE37 SL PW | Ohlins RT
      01-02-2019, 07:00 PM   #29
yoon_209
Masterchief
yoon_209's Avatar
Originally Posted by Logicoeur View Post
Should be correct as Msport blue or Mperformance calipers only differ by the carrier allowing for the difference in rotor size.
Should even work for the front Grey brembo as those are the same caliper as the both Msport blue and Mperformance front calipers.
      01-03-2019, 05:24 PM   #30
eleven11
eleven11's Avatar
Drives: -F85 X5M-
Sorry I haven't updated.
I've got the Akebonos sitting in a box, but haven't had a chance to install them, yet.
2017 X5M - Current
2017 F31 Wagon - Current
2014 M5 ZCP - Retired
2011 135i Coupe - Retired
2007 335i Sedan - Retired
      01-03-2019, 05:33 PM   #31
Vulpe
Vulpe's Avatar
280
Drives: F87 M2C
From solely looking at pictures it LOOKS similar to it.
Akebono site, Tirerack, and Rockauto seem to say it would fit for yours. No mention of "Blue Caliper" in the listings.
Mine too, another two weeks until my calipers are done with powdercoat. Then after that no idea when I'll have the time to install them.
      01-03-2019, 06:20 PM   #32
yoon_209
Masterchief
yoon_209's Avatar
i just pulled the trigger on akebono 1880 fronts and 1610 for the rears. will report back after install maybe in the next two weeks.
      01-04-2019, 08:52 AM   #33
Sanelko
Sanelko's Avatar
70
I did the install. Every now and then I get squealing under light braking, even though I applied anti-squeal to the recommended areas in the Bentley manual. Will try troubleshooting some more.
      01-04-2019, 12:30 PM   #34
Logicoeur
Logicoeur's Avatar
991
Drives: F30 335i xDrive
Not sure if this is already a required step, but is everyone changing the retaining clip with their pads as well?
mbanks211267.50
      01-16-2019, 10:56 AM   #35
yoon_209
Masterchief
yoon_209's Avatar
i can confirm that akebono 1880's will fit the gray brembo calipers for the fronts and 1610 for the single piston rears.
i've had them for a few days, no squeaking whatsoever, they do have less bite than oem but the brakes feel more linear and consistent
and the best of all minimal brake dust.
      01-16-2019, 11:04 AM   #36
Sanelko
Sanelko's Avatar
70
The squeaking got worse, and then for now it's gone away. I think it must have been outside factors - something caught between the pad and rotor or just not being fully bedded as I think it was only the front left brakes causing the squeal. So glad the deathly squeal on cold days from the PowerStop Z23 is gone now though.
      01-18-2019, 07:29 PM   #37
M4_GTS
Hong Kong
1153
Drives: M4 GTS
PowerStop pads absolute shit.
Originally Posted by FMLYSDN View Post
You're a dick. Oops. Did I just say that?
      01-19-2019, 10:17 AM   #38
Rebound
Rebound's Avatar
153
Drives: F33: The 435i Convertible
Is that good or bad?
Are they “absolutely shitty”, or are they “absolutely the shit!”?
      01-19-2019, 11:20 AM   #39
Sanelko
Sanelko's Avatar
70
Agreed, and their price reflects it.
M4_GTS1152.50
      01-20-2019, 05:29 PM   #40
yoon_209
Masterchief
yoon_209's Avatar
It was too good to be true.
I've been hearing a quick oscillating noise when I drive with the windows down and it's definitely coming from the wheels.sounds starts at about 20mpb. It's not a squealing or grinding but a oscillating noise. The noise only occurs when I'm driving and there is no noise while I brake. I'm not sure if it's the akebono pads or the r1 concept rotors. Iv the pads and rotors for about 100 miles so far. Im guessing I need to give the pads and rotors more time
      01-20-2019, 07:05 PM   #41
Sanelko
Sanelko's Avatar
70
You know, I thought I heard the same noise while on the highway (stop and go). This was while the brakes were still squeaking, but it has since gone away
      01-22-2019, 12:36 PM   #42
yoon_209
Masterchief
yoon_209's Avatar
i took it back to the shop that installed the pads and rotors and they are saying everything looks fine and to give it some more time. they are saying since the pads and rotors are new the buzzing sound could be a result of the pads making contact with drilled and slotted part of the rotor while driving. i guess we will see what happens in the next few hundred miles
      01-23-2019, 10:12 AM   #43
M4_GTS
Hong Kong
1153
Drives: M4 GTS
It's not going away and it's not an issue with the pads. It's the dimples in the rotors creating that noise. Lots of ppl reported the same noise with the m performance big brake kit as well.
      01-23-2019, 10:32 AM   #44
yoon_209
Masterchief
yoon_209's Avatar
well that sucks
