09-03-2021, 02:54 AM | #1 |
Rep 19,982
Anyone fitted Bilstein B12 Pro-kit?
I bought my original 335d tourer back, from the friend I sold it too. It's now on 145k miles, so the coilovers that I fitted on about 20k miles are past their best, and the car sits too low for it's new role as all rounder for station/airport/dog wagon/DIY duties. I still have the original xdrive adaptive suspension, but I'm not sure I can quite face going back to that garbage, but clearly don't want to spend lots on it either. So was thinking that the B12 kit with Eibach pro-kit springs plus Bilstein B6 passive dampers might be a sensible option, as they can be had for less than £800.
I don't want it xdrive high, nor lowered particularly, just normal! And handling more towards everyday composed and comfortable, without being wallowy. Any experience shared appreciated.
09-03-2021, 03:09 AM | #2 |
Rep 1,993
Drives: F30 335d
I have the B12 kit on my 335d, fitted it myself not long after getting the car nearly 3 years ago as I couldn't stand the wallowy feel of the stock suspension - the rear dampers especially were poor with a rebound so slow it couldn't possibly keep up with bumps in the road.
The B12 kit did transform the handling, but not in a harsh way, the stance and feel is what it should have been from the factory IMO. Obviously subjective but you could do worse than go for the B12. BTW the B12 kit has B8 shortened dampers.
if I've helped - an Appreciate would be, er, very appreciated!
Tengocity8567.00 |
09-03-2021, 03:20 AM | #3 | |
Rep 19,982
My 340 (silver)is on the full ACS sports suspension, and sits ideally, but you can see the 335d (blue) sits very low on the ACS RS Coilovers, and it's too firm for how the car will be used now.
09-03-2021, 03:53 AM | #4 |
Rep 1,993
Drives: F30 335d
This is mine on 18" winters:
Sorry to say that the car needs a ruddy good clean otherwise I'd have get some more up-to-date pics
Tengocity8567.00 |
09-03-2021, 04:14 AM | #5 |
Rep 19,982
Thanks, that's looks good to me, possibly a little higher than ACS springs would sit, which is perfect.
09-03-2021, 04:59 AM | #6 |
Rep 811
Watching with interest - my car has now done 100k on stock suspension (well the bits that haven't failed an MOT yet!) Please give feedback on your thoughts Tengocity.
Where are you ordering from? To get the slight drop, do you have to order a non X-Drive set? |
09-03-2021, 05:02 AM | #7 |
Rep 1,993
Drives: F30 335d
I wouldn't order the non x drive set as the spring ratings wouldn't be correct for the extra weight of the x drive components. I can't remember the drop offhand of the B12 kit but it is about 10mm less than the ACS springs at the front, with the same drop at the rear.
@Eddamoo you're welcome to come and see how mine is, I've had the b12 kit on for about 40k miles so far.
Eddamoo391.00 |
09-03-2021, 05:08 AM | #8 | ||
Rep 19,982
I'd always order the right parts for the car, and there are quite significant differences between the sdrive and xdrive cars. Quote:
Eddamoo391.00 |
09-03-2021, 11:55 AM | #9 | |
Rep 5,392
If you wish to go lower, then Koni Sport Yellow can handle larger drops (like the B8's) but they also have 10 adjustable comfort settings to avoid teeth rattling of the Bilstein's Hope this helps! |
Tengocity8567.00 |
09-03-2021, 01:34 PM | #10 | |
Rep 19,982
johnung4528.00 |
09-03-2021, 03:16 PM | #11 |
Fool
1857
Rep 3,542
Hey Terry,
From what I've read, B6 and B8 shocks are too stiff for the UK roads, that combined with stiffer springs results in a crashy ride. I went for the Birds B3 setup and it's honestly a transformation. It doesn't lower the car from stock RWD (so you might see 10mm drop) but the way it works is frankly amazing. It's basically turned mine into a plush roundabout weapon. The front grips and grips and grips, the diff can then do its work at the back and it's such a hoot. Combined with a much more comfortable ride than it ever had using stock suspension. I'm sure you know what Birds do, but for others, they take a B6 shock and get Bilstein to custom valve it and spray it black (no garish yellow here thank you!). They then match it with a custom Eibach spring setup which is softer (certainly at the back) than the stock one. The combination is very impressive indeed. It's so impressive my wife noticed the difference before we'd even got off the drive, the way the car went down the kerb was (is) so much better. If you're ever back down this way, do let me know and you can have a ride in it. Edit: What makes you think the coilovers are shot after just 20K miles? That's not a lot of mileage!
09-03-2021, 03:31 PM | #12 |
Rep 379
I think he is saying the car as done 125k on the coilovers.
Current - F36 440i
Previous - F31 335d, F10 535d, E60 M5, F30 335d, E84 25d, E92 335i, E60 M5, E46 M3 CS, E83 3.0sd, E46 M3 Silverstone Edition. |
Daftasabrush1857.00 Tengocity8567.00 |
09-03-2021, 05:07 PM | #14 |
Rep 19,982
That's correct! I fitted them Coilovers back in 2014 I think, so they've been on the car 6+ years, and done well over 100k miles. They're not totally knackered by any means, but the adjusters are seized, and I'm sure they're not anywhere near as good as when new.
ar68149.00 |
09-03-2021, 05:21 PM | #15 | |
Rep 19,982
I've now got a 340 tourer also, and it's on the ACS version of the Birds kit you have. It's exactly as you describe, and a perfect balance of wonderful ride and decent handling. My dad has the Birds set up on his M135i and I was super impressed with it too. I suspect the Birds is a little firmer and all the better for it when it comes to handling, as I think the ACS sports suspension is a little too soft for me when pushing it. So back to the 335d… I've no doubts that if this were a newer car with a long life ahead of it still then it would be worth going down that route, but it really is meant to be a cheap run around for leaving at the airport and train station, carrying the dog etc. Main objective is to raise it back up, and move the balance to comfort over handling. Cheapest thing would actually probably to refit the adaptive dampers and get a set of Eibachs, but these Koni ones might be worth a look and I can get a full set for around £500.
09-04-2021, 03:44 AM | #16 | |
Rep 379
Current - F36 440i
09-04-2021, 03:49 AM | #17 |
Rep 19,982
Yes, that's right, well remembered, except I'm sure it was earlier than 2016. Anyway, it's done good service in that time. I'd have thought more parts all round the suspension could do with a freshen up really, but defeats the whole point of getting a "cheap' run around if I do that.
09-04-2021, 04:57 AM | #18 | |
Rep 379
Current - F36 440i
09-04-2021, 05:10 AM | #19 | ||
Rep 19,982
09-04-2021, 05:18 AM | #20 | |
Rep 379
Ah well back to the drawing board then.
Current - F36 440i
09-04-2021, 08:32 AM | #21 | ||
Rep 19,982
I've raised the front ride height a little, and working on the rears, but it's quite awkward to do. But hopefully by the end of the day I should have something that's actually going to work just fine for a while.
ar68149.00 |
