BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Oil Filter where to buy?
      11-26-2021, 01:05 PM   #23
johnung
Originally Posted by Emerson335 View Post
I purchase mine on Amazon…
Mann-Filter HU 816 X Metal-Free Oil Filter (Pack of 3) https://www.amazon.com/dp/B01NCVMOSY...UTF8&psc=1
I went for BOSCH , bad idea ?
I can't speak to Bosch, I've only ever used Mann. Others here can provide more input, as my experience is limited. My F30 is the only only BMW I've ever had and I've had it less than 3 years. I can tell you I replace my oil every 5,000 with the Mann filter kit and the oil that comes out is very clean.
FWIW- I buy the Castrol oil at Walmart and the filters on Amazon which makes the maintenance pretty inexpensive. The F30 is by far the easiest oil change of any car I've ever owned, which was a present surprise.
Lastly, for anyone doing their first oil change (like the OP), don't forget to pickup a 16 flute oil filter wrench for BMW's. Below is a link to the brand I have (although mine is an older style)…
https://www.amazon.com/dp/B01N54IT33...UTF8&psc=1
There's actually a great inexpensive oil filter wrench in most auto parts stores but most people miss it because it's labeled for Volvo and not BMW. It's 86mm/16 flutes. Only maybe $4. See photo.
      11-26-2021, 10:03 PM   #24
Polo08816
Drives: 2014 335i M Sport
Originally Posted by Billfitz View Post
xDrive has a steel oil pan and uses a steel drain plug. RWD has a plastic oil pan and uses a plastic drain plug. The filter element is the same with X or Z variants, the hardware that comes with them is not. Both the crush washer with the X and the drain plug with the Z versions are one time use only, so you'd best get the right one.
Originally Posted by Jvac View Post
My oil pan isn't plastic. I think that's an n20 thing? Op says he has a 335
Could be, since I have an N20 I never had reason to investigate an N55 oil filter. If that's the case my apologies for adding to the level of confusion.
I think that's contributing to the confusion.
The N55 RWD oil pan is metal. I could see the N20 RWD filter kit having a different part number if the oil pan design is different than the AWD oil pan.
Jvac170.50
      11-27-2021, 08:46 AM   #25
Orion4
Drives: 2013 335i Sport Line Sedan
The 335i has steel pan and associated bolt. Correct filter is Mann 816X (includes the o-rings and crush washer). I get mine as part of oil change kit from FCPEURO. Lifetime replacement after you buy the 2nd and refunded when you return the first. Only pay rtn shipping
Jvac170.50
      11-27-2021, 03:33 PM   #26
gameson
Drives: N20 BMW 320i
what are the options for an oil filter part number for N20? thanks.
      12-01-2021, 09:10 PM   #27
John in VA
Drives: 2015 228i M Sport
BMW part number is 11427953129 - Set oil-filter element
Supersedes:
11428683196
11427566327
11427541827
Part 11427953129 was found on F30 vehicles with N20, N26 & N55 engines:
https://www.realoem.com/bmw/enUS/par...129&series=F30
As stated earlier in this thread, MANN, Mahle or Hengst filters will do the job.
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining
      12-01-2021, 10:23 PM   #28
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
As I originally posted, HU816X for xDrive, HU816Z for RWD. The filter is the same in both cases, what comes with it differs.
      12-05-2021, 05:04 PM   #29
ErkanTR16
64-bit
ErkanTR16's Avatar
Drives: 2018 BMW 340i xDrive
FCPEuro.com
      12-11-2021, 09:01 PM   #30
Orion4
For the Record: Directly from the Mann website:
Copyright ©2000 - 2022, vBulletin Solutions Inc.
