01-17-2022, 10:44 AM | #1 |
Rep 1,148
Hey everyone, planning on getting some wheels in the next few months if nothing hits the fan, anyway the fitment for these is 18x9 +35
My understanding this isn't super aggressive fitment and should be pretty easy. They don't have many options so this is the fitment I settled on if I go this route. I know the front may be limited to a 245 tire maybe even a 235 with this offset, could I get away with more, I will be running 2.5-2.7* camber front and 1.5-1.9* rear. I wanted to run a 265 on the rear but not exactly sure if It's going to tuck. Ideas? |
01-17-2022, 12:16 PM | #2 |
Rep 3,189
Those are definitely not aggressive offsets, running stock camber would be fine. If you go for -2.5° in the front it might not look as flush as you might be expecting, but not tucked/sunkin. You should be able to run 255 square if you want. You might run into inner clearance issues on the fronts, but worst case a 5mm spacer would fix it. You would have no clearance issues in the rear with a 265, you could also fit a 275 if you wanted. A 245 would fit easy in the front, but if you get the taller sidewall to match the rear it would probably rub the fender liners ever so slightly on turns. That is also tire dependent based on how sharp or rounded the edges are.
01-17-2022, 12:28 PM | #3 | |
Rep 1,148
01-17-2022, 03:39 PM | #5 |
Rep 1,148
11-02-2022, 03:47 PM | #6 |
Rep 328
