12-17-2019, 09:27 PM | #1 |
Rep 73
Help! RPM dip on startup
Linked is a video of a cold start on my 328i. The rpms fluctuate ONLY when the car is cold. Doesn't happen while driving or anything. Has this happened to anyone? Mods: ER intercooler Bm3 stage 2 Injen evo intake VRSF downpipe |
12-17-2019, 11:31 PM | #2 |
Rep 943
Drives: F30 328i Msport
Cold start off or on? Sounds like you have it off?
12-18-2019, 07:56 AM | #5 |
Rep 73
It hasn't had that issue before, the car starts right up and then the rpm dips for a second and then it idles normally. Doesn't do it when I try again after starting it, only when it's cold and hasn't been started in hours
12-18-2019, 09:21 AM | #6 |
Rep 108
This doesn't look serious to me, there's no obvious change in engine sound, you can only see that rpm needle is moving a bit down, and for a fraction of a second... I mean, it is a cold start, so engine cannot run perfectly yet.
You can try to revert cold start delete, and see if it happens again... |
