07-19-2018, 11:18 PM | #45 |
Rep 740
This question may be an odd one but has any of the f30's that was USA exported to EU have high beam assist? If so, were you able to code anti-dazzle function?
Long story short, I purchased xenon headlights from Germany that allows anti-dazzle. I was speaking with Shawn Sheridan and he mentioned that it may need to change the US to ECE.
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
07-22-2018, 12:19 PM | #46 | |
Rep 7
I am confused that I have in VO both 6UD and 853 - which I believe for English? Please give a hint how to add other languages to USA car. Thanks! UPD: I have removed from VO 853 English Language, add only 6UD Russian language. Now I can see other languages in iDrive, but cannot select them, once selected they just go back to Russian without changing language on screen. UPD2: Fixed. Removed 6UD from VO, changed to 853, coded. Than remove 853 + add 6UD, coded. This time works, have no idea, what was wrong first time. Did same stuff and no errors during coding. Problem solved. Last edited by avtor; 07-24-2018 at 11:03 AM.. Reason: Updage 2 |
12-28-2018, 11:44 AM | #48 |
Rep 2
Hello,
I have small issue after language change from US english to polish. I have changed VO and code KOMBI and NBT. After coding all menues expect "destination adress in navigation" menu are polish. Only this one is without any language. Do U know why? How to change also this menu ? In attachement photo with this menu: https://www.fotosik.pl/zdjecie/usun/...qIiHlwumR81o~b |
09-14-2019, 12:16 AM | #49 | |
Rep 2
im from PL. ive replace normal headlamps to bi xenon non adaptive. regards. Last edited by Odir; 09-14-2019 at 11:52 AM.. |
01-17-2023, 02:24 PM | #50 |
Rep 82
crazyiven Hello, resurrecting an old thread. Could send me to PM what did you change in VO in order to convert from US to ECE and which modules did you code?
As per my research: 1. 697->698 (DVD Area code 1 -> 2) 2. 230 (Eu specific aditional contents) Not sure what this does and if it necessary 3. 876 -> 874 (Radio frequency 415 -> 434) I catch most of the stations in Bulgaria with 415 frequency as it is now 4. 645 (Us radio control) should I remove this? 5. 801 (German version) Does that mean default EU and is it required? FDL Code HU_CIC/NBT Module: RADIO_COUNTRY = ece FM_DEEMPHASIS = 50us ANZEIGE_FREQ = nicht_aktiv Thanks in advance. |
02-05-2023, 06:26 PM | #51 |
Rep 5
In my G01 I changed the following to have my radio working fine in Poland
HU_CIC / 3002 AUDIO_TUNER_TRAFFIC / RADIO_COUNTRY = ece / Werte=00 RADIO_COUNTRY - ece (werte00) ==> EUROPA FM_DEEMPHASIS=50us ==> frequency step is 0,1 Mhz ANZEIGE_FREQ - nicht_aktiv (werte00) ==> radio station names without Mhz RADIO_IBOC = nicht_aktiv => this was required to hear sound when radio_country = ece I did it via bimmercode |
