BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > F30 328i drivetrain error
Carbahn Autoworks
      07-21-2018, 02:28 AM   #1
Jongdoo
Drives: F30 328i
Hello. This is Jongdoo in Abu Dhabi.
My car is 2014 328i and I have a big trouble. I tried to change the last spark plug to the cabin yesterday (3 spark plugs already changed) but my tool was touched to the bolt that is connected red line (I think it's + ) I saw the spark between the tool and bolt. After then Drivetrain error is coming. I have OBD and check the diagnostic below.
This is the diagnostic report.
Engine / Motor
Fault Code: 113027
Fault Explanation: Relay ignition and injectors, supply voltage injection: line break
Fault Code: 1F0515
Fault Explanation: Valvetronic, supply voltage: Line break
Fault Code: 1F4A02
Fault Explanation: Relay ignition and injectors, Control: short circuit to ground
Fault Code: 133102
Fault Explanation: Valvetronic relay control: Short circuit to ground
Fault Code: CD9010
Fault Explanation: LIN, communication (engine coolant pump): missing
Fault Code: 1B5202
Fault Explanation: Terminal 15N 1: no voltage
Fault Code: 1B5402
Fault Explanation: Terminal 15N 3: none Power
Fault Code: 1B5302
Fault Explanation: Terminal 15N 2: no voltage
Fault Code: 130002
Fault Explanation: VANOS solenoid valve inlet, control: Short circuit to ground
Fault Code: 130202
Fault Explanation: VANOS solenoid valve outlet Control: short circuit to ground
Fault Code: 122002
Fault Explanation: Diverter valve control: Short circuit to ground
Fault Code: 1C0202
Fault Explanation: Engine oil pressure control valve actuation: Short circuit to ground
Fault Code: 12B102
Fault Explanation: Lambda probe heating before catalyst activation: short circuit to ground
What is the problem and what should I do now?
Thank you.
