BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > OFFICIAL Slammed/Stanced (F30/F32) Thread
Extreme Power House
      06-24-2018, 11:10 AM   #1013
DaFish
DaFish's Avatar
Drives: 2014 435iX, FBO
Originally Posted by harvs43 View Post
No slammed but lowered on ACS springs......
Wheels are 20 inch Ispiri FFR8s, fronts are 235/35/20 Et35 on a 9.5 inch and rears are 275/30/20 Et45 on a 10 inch.
Beautiful fitment and look. Really sharp.
2014 BMW F32 435iX - JB4, BMS Meth Kit, ER Intercooler, intake, catless DPs, KW Streets, 437M Reps with 24535 and 275/30 Michelin PSS 4S
harvs4393.50
      06-25-2018, 01:44 AM   #1014
mledfo2
mledfo2's Avatar
Drives: black f30 335i m sport
I'm attempting to fit some 19x8.5/9.5 +15 all around on h&r sports til I get coils. Hoping I'll clear with 225 front and 255 rears and a bit of camber?
      06-25-2018, 07:38 AM   #1015
kern417
Cheapskate
Drives: 2018 440i / 2010 X5
why?
      06-25-2018, 01:49 PM   #1016
daryl rsv4
Drives: BMW 435i
Picked up a set of new Vorsteiner VFF 102’s for a back up set up to my AG’s. Not crazy on the fitment in the front. I know I can go wider in the front as I’m bagged and rolled. I needed wheels same day as I cracked the inside barrel of my rear AG so I picked these up. Sending my AG’s in to get repaired and refinished so we’ll see what happens with the new wheels.
      06-25-2018, 01:58 PM   #1017
N0Chill 335i
N0Chill 335i's Avatar
Drives: 13' F30 335i M Sport AW
Yea, about -4 degrees in the rear. Fronts shouldn't be too much of an issue.
      06-26-2018, 08:31 PM   #1018
kedafoe
kedafoe's Avatar
Switzerland
17
Drives: F31 335i xDrive
Hey guys - greetings from Switzerland!
My Setup:
KW V1 coilovers + adjustable camber plates in the front.
Currently running 9x20 +30 and 10x20 +38 on 235/35 and 265/30 with -1.5 front and -3 in the rear. No rubbing issues at all.
Now I was looking for a more aggressiv fit with 9x19 +20 and 10x19 +25. You think it will fit with 225/35 and 255/30 Hankook and maybe a slightly fender roll/pull? My problem is that I have AWD, so I have to stick more or less to OEM sizes...
Appreciate 6
      06-29-2018, 07:54 AM   #1019
kern417
Cheapskate
I'm so happy with how this turned out.
      06-29-2018, 07:59 AM   #1020
wdeerfield
A family of bimmers
Drives: '13 f30, '11 f10
The ride height is perfect with that. Looks much better than your stockers. Nicely done!
2013 EB/CR 335i xdrive | DHP | 19" VMR V803 | MPS4S | MPerformance | M3 Grills | BMS Tips | LED Turn Signals | CTS intake | VRSF FMIC | VRSF CP
2011 JB 535i xdrive | ZPP | ZSP | ZCW | 6FL | NAV | 331s Square | MPerformance Spoiler | M5 Grills | Painted Reflectors
kern417842.50
      07-01-2018, 08:46 PM   #1021
Jazima
Jazima's Avatar
Drives: F30 335i M-Sport
2013 BMW 335i  [0.00]
I couldn't find it on here. Maybe I missed it but anyone running 19x9.5 et25 in the rear ?
Instagram: BoostedF30
2013 F30 335i M-Sport
2002 E39 530i
      07-01-2018, 09:26 PM   #1022
N0Chill 335i
I am. 255/35/19 with -2.4 camber.
      07-01-2018, 11:32 PM   #1023
Jazima
Jazima's Avatar
I have bc coilovers. Did you have to get any special rear suspension parts to get that much camber ? I'm looking at your wheel specs but with 265 tires
2002 E39 530i
      07-02-2018, 02:34 PM   #1024
kedafoe
kedafoe's Avatar
Switzerland
17
I think my question got under...
I am currently looking for a new set of bc forged wheels with 9x19 +20 and 10x19 +25. You think it will fit with 225/35 and 255/30 Hankook and -3 camber all over (f30/31 platform)?
      07-02-2018, 03:49 PM   #1025
F30_SixSpeed
F30_SixSpeed's Avatar
725
Drives: Estoril Blue F30 M Sport
335i M Sport 6MT || PS2 Turbo, FBO, BM3, KW, MP BBK, OEM+
Build thread can be found HERE
      07-02-2018, 07:45 PM   #1026
N0Chill 335i
I have BC coilovers as well. You will need to go full -3 or closer to it. It depends on what tires you go with, as some are beefier than others at the same widths.
      07-02-2018, 07:48 PM   #1027
N0Chill 335i
You're already at -3 with your current setup of et38. Your rims will poke 13mm more and your tire size will be lower by half an inch. You shouldn't have any issues due to the reduced sidewalls but you will probably rub on dips and hard acceleration.
kedafoe16.50
      07-04-2018, 07:42 AM   #1028
kern417
Cheapskate
First casualty I knew I needed a fender roll but tried my luck for a few days and the one time i load up the car with my wife/son this happens. It was my fault though since i turned a bit to avoid a car while going up an incline. Luckily I was going to a local shop's car meet and they had tools, so I was able to tuck it back under for the time being but will be trying to DIY roll this week to see if it gives me more room.
      07-04-2018, 09:04 AM   #1029
N0Chill 335i
To be honest, not much a roll would have done in that situation. You probably need a pull to make a difference. I rolled mine as flat as possible and gave a slight pull and I'll still rub the exterior fender if I turn too deeply at higher speed. You appear to be lower than me and definitely more meaty. This is gonna happen, part of the stance life.
      07-04-2018, 02:40 PM   #1030
kedafoe
kedafoe's Avatar
Switzerland
17
It's not because of the fenders, you just have too much tyre on that 8.5 and 9.5. Try it with 225/255 and you will not have that issue.
      07-04-2018, 08:05 PM   #1031
kern417
Cheapskate
The issue is that it snagged the inner lip. Really if I had cranked it harder I probably would have cleared because my caster causes the car to raise a bit as I add more steering angle. But double guessing and only making a minor adjustment lead to this. I don't mind rubbing the inner liner but by rolling the lip it won't pull the fender out like that the next time i make a mistake.
Luckily Tire Rack's Road Hazard coverage is sending a replacement tire so I'll be back like nothing happened by the end of the week.
Nah, def not going down a tire size. I don't like the look of stretched tires. If anything I'd move to a higher offset wheel. But this fitment is perfect, Rays knew what they were doing when they made these.
      07-04-2018, 08:28 PM   #1032
kedafoe
kedafoe's Avatar
Switzerland
17
Did you ever saw 225 on 8.5 and 255 on 9.5? It's perfectly flush with the rim edge, not stretched. Your actual tires are poking over, which I wouldn't like. But each his own.
      07-04-2018, 09:31 PM   #1033
KendrickOak
KendrickOak
KendrickOak's Avatar
Drives: 17' F32 M Sport
95% complete
Fitment so tight, a dollar bill can't fit lol
      07-04-2018, 09:44 PM   #1034
lfepro.g
Drives: 428i
Originally Posted by KendrickOak View Post
95% complete
You are my goals, my friend. What's your size of forgestars?
aggressive, f30, low, slammed, stance
