11-17-2019, 06:38 PM | #3015 |
Rep 11
Can't get past "Loading: E-Sys Launcher PSdZ API Module Failed! Error C:\ProgramData\TokenMaster\E-Sys Launcher Pro\bin\PSdzAPI.dll: Can't find dependent libraries."
Tried fresh D/L of 3.27.1 and PRO 2.8.2 and even installed on a totally different machine. Win 7 vs Win 8.1. Same error and can't FDL code. |
11-17-2019, 06:40 PM | #3016 | |
Rep 40,765
11-17-2019, 07:01 PM | #3017 |
Rep 11
11-17-2019, 07:05 PM | #3018 |
Rep 40,765
Try specially installing .NET 4.5. Update Java too. And Microsoft Visual C++ Runtime components.
11-17-2019, 07:39 PM | #3019 | |
Rep 11
"Loading: E-Sys Launcher PSdZ API Module Failed! Error C:\ProgramData\TokenMaster\E-Sys Launcher Pro\bin\PSdzAPI.dll: Can't find dependent libraries." --- Edit: Found and updated to E-Sys 3.30.1 using same Pro launcher and it loads without error and Activating FA works, will try FDL shortly. Guess update to 3.30.1 fixes this error. Thanks for the suggestions. Last edited by rabbitf30; 11-17-2019 at 07:54 PM.. Reason: Resolution |
11-17-2019, 09:21 PM | #3020 | |
Rep 40,765
11-29-2019, 08:17 PM | #3022 |
Rep 40,765
PM sent.
11-30-2019, 01:35 PM | #3023 |
Rep 40,765
PM sent.
12-07-2019, 06:42 PM | #3024 |
Rep 965
Drives: 2016 F36 435x MSport
new laptop, so if you get a free moment, mind sending me a fresh link to esys/psdzdata
tia
2010 Mazda RX8 - Sold (11/17)
2016 BMW 435xi GC - Current |
12-07-2019, 07:11 PM | #3025 |
Rep 40,765
PM sent.
12-07-2019, 08:09 PM | #3026 |
Rep 965
12-11-2019, 10:57 AM | #3028 |
Rep 40,765
PM sent.
12-12-2019, 09:35 AM | #3029 |
Rep 1,123
Has anyone else had issues with Launcher 3? I haven't accessed in a several months, now when I try to log in with my google authenticator pin I get "verification failed".
I only code occasionally, and it's getting frustrating using Esys, as I've paid some folks $$$ to get 'updated' versions in the past....don't use for a few months, and boom, doesn't work anymore. I'm not surprised most people are using Bimmercode, which is what I've been using too. Just figured I do some in-depth stuff with Esys….nope, not today. Does anyone have a solution, or experience the same issue? |
12-14-2019, 04:46 AM | #3030 |
Rep 40
Drives: 2015 F31 330D
Hi,
Would appreciate a link when you get a moment Shawn. Thanks in advance. |
12-17-2019, 04:08 PM | #3032 |
Rep 40,765
12-17-2019, 04:14 PM | #3033 |
Rep 22
I'm asking because while programming with ISTA+ 4.18 the car turned off itself. Communication was lost and now almost nothing works. I need to reprogram ECU and I don't know if E-Sys can handle in such situation.
12-17-2019, 04:28 PM | #3034 | |
Rep 40,765
You need to make sure car is not stuck in Transport Mode now.
12-17-2019, 05:52 PM | #3035 |
Rep 22
Sorry my english is not my native language. What do you mean by "commercial grade". It means that a car has some sort of "sensor" detecting it is on commercial grade therefore it will not turn off ?
12-17-2019, 05:56 PM | #3036 |
Rep 40,765
No. A High-Current Charger given it high-cost is designed for commercial applications. You can jump car to another car with its motor running if you have no charger.
