10-03-2020, 01:34 AM | #1 |
Rep 1,407
Drives: 13' F30 328i 6MT
2013 F30 328i RWD ( Diff / Trans Fluid Change )
This seems to be a huge grey area, I have a 2013 328i RWD 6MT car, Can anyone recommend a fluid change kit or fluids?
I have hit 105k miles and wish to change my rear diff and trans fluids. Thanks in advance! DG
'13 F30 328i Sport 6MT | '18 G01 X3 xDrive30i | '95 E36 325i Vert 5MT
92 Sentra SE-R SR20DET DET Build Thread 89 E30 325is [sold & missed] |
10-03-2020, 04:45 PM | #2 |
Rep 157
Since you have a manual, there is no ‘kit’, that’s more for automatics. You can get the OEM fluids from BMW (just check RealOEM), alternative is something from Redline.
10-04-2020, 04:32 AM | #3 |
Rep 1,407
Yeah I cant even find what fluid is preferred ie weight etc, I guess just google "S6-17BG" Transmission Fluid was seeing what you guys use in these transmissions.
11-02-2020, 12:40 PM | #4 |
Rep 1,407
In case anyone ever searches for this information I can confirm the F80 DIY below is relevant for all F30's with Manuals when it comes to the transmission.
I purchased my fluid from FCP Euro "Red Line 75W90 NS GL-5 Gear Oil". F80 M3 Transmission DIY - Unfortunately are diffs are not the same procedure as we have no drain plug, We have to suck out the old and then refill with new.
92 Sentra SE-R SR20DET DET Build Thread 89 E30 325is [sold & missed] Last edited by QUiKSR20; 11-09-2020 at 07:53 PM.. |
11-09-2020, 07:56 PM | #5 |
Rep 1,407
Just finished the fluid change, Wow @ 105k miles this stuff was black.
Trans seems to shift much smoother, So strange BMW labels this crap as lifetime.. What a crock of crap ( marketing speak for the lease people I guess ).
11-09-2020, 08:30 PM | #6 |
Rep 1,055
How much of the fluid did you use QUiKSR20 ? Have to do the same. Also, it's kind of interesting to see another member from "the dash" make their way into a 6MT F30.
11-10-2020, 09:38 PM | #7 | |
Rep 1,407
You need two bottles, The transmission will take around 1.5qts ( 1.5 bottles ) to fill it. The process was as easy as drain and pump but with no information anywhere I drove myself crazy.. Hoping this helps clear it up for most, Now to tackle the rear diff although diff fluid changes arent as important. Anytime I have drained a diff the fluid never looked that bad and doesnt really get beat up. Let me know if you have any questions and follow the video above, it was spot on.
