04-24-2019, 08:18 PM | #1 |
Rep 376
F30 340i - 19x10" rear wheel?
Anyone running a 19x10" rear wheel?
I would also be going with coil overs and camber plates... looking to go to a full track build on my 2018 340i and I know I need to go wider out back... I love the Apex ARC-8 in 19x10" but the ET is 25 which seems too low for this car... I'm running 19x9.5" et40 w/ 265/35 right now on Dinan springs and OE M-adaptive dampers... no rubbing... PERFECT fitment IMO.
/// F80 M3 CS ///
04-25-2019, 06:09 AM | #2 | |
Rep 57
04-25-2019, 09:17 AM | #3 |
Rep 2,063
Why 19x10 wheel for track build? You need to go smaller like 18 or 17 for a more meaty tires = better grip. Also you need to go wider on the tire not on the wheel. 9.5 is perfect for 275.
I'm also looking for a better grip performance wheel/tire setup than my current one below. 19x8.5 et35 235/40 19x9.5 et40 265/35 This is what I have in mind so far. Apex 18" EC-7 with Indy 500 18x9 et31 255/40/18 18x9.5 et43 275/40/18
04-25-2019, 11:55 AM | #4 | |
Rep 376
I think that set up is the move. Thanks for the input!
/// F80 M3 CS ///
04-25-2019, 12:22 PM | #5 |
Rep 4,259
04-25-2019, 12:28 PM | #6 | |
Rep 376
/// F80 M3 CS ///
04-25-2019, 12:35 PM | #7 | |
Rep 4,259
EDIT, sorry noticed there's an advan track tire available in the size i mentioned Last edited by alohasurftoad; 04-25-2019 at 12:45 PM.. |
04-25-2019, 12:36 PM | #8 | |
Rep 2,063
I doubt that MPS4S or Continentals tires will be cheaper than the Firestone indy 500. They are a lot of good reviews on those tire. Best bang for the buck out there.
04-25-2019, 01:06 PM | #9 | |
Rep 4,259
yup, firestones best bang for buck, for sure. i prefer to pay a little more for better. |
04-25-2019, 01:11 PM | #10 | |
Rep 2,063
08-16-2020, 10:56 AM | #11 |
Rep 9
CarolinaBavaro - I am a newbie. Apology on dragging up an old post. Did you use spacers on this setup? I like the flush fitment of the rear. Same on front (hard to tell from photo)? I am searching for reasonably priced 437m in aftermarket and hope to have flush fitment on my 2017 340i that has adaptive suspension. Appreciate your guidance.
08-16-2020, 11:43 AM | #12 | |
Rep 3,752
08-17-2020, 11:54 PM | #14 |
Rep 1,051
No issue with 275 18x10 in the back stock height. Wheels look meaty and wide.
Rear fitment photo
MY13: TTE400 Stage 2 turbo, Spec Single Mass flywheel + Stage 3+ Clutch, FTP V2 Turbo Inlet, Evolution Racewerks Charge pipe + Boost pipe + Intercooler, Turbosmart Recirculating Diverter Valve, aFE grill scoop + aFE Magnum Force Cold Air Intake, B58 coil retrofit, eBay Downpipe, Active Autowerke muffler, DW400 LPFP, B58TU HPFP, M5 s63TU injectors, Bimmermilvs, e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block
10-12-2020, 11:37 PM | #15 | |
Rep 9
2017 340i | Mineral Grey | Oyster | MPPSK | Tech | Driver Assist | Driver Assist + | M Sport | Track | 437m Wheels
10-14-2020, 07:54 AM | #16 | |
Rep 1,051
10-14-2020, 08:05 AM | #17 | ||
Rep 9
Taking a closer look at your tailpipe ... is your car a G20?
10-14-2020, 10:13 AM | #18 | |
Rep 1,051
https://f30.bimmerpost.com/forums/at...1&d=1601680390 https://f30.bimmerpost.com/forums/at...1&d=1601938831 |
10-14-2020, 12:46 PM | #19 | ||
Rep 27
I really like the look of your setup. Does this setup work with xDrive? Also, if I were to go with 19's, are 10" in the back too big? |
10-15-2020, 09:00 AM | #20 | ||||
Rep 1,051
This post is #63 within this thread: https://f30.bimmerpost.com/forums/sh...1133583&page=3 Quote:
10-15-2020, 12:14 PM | #21 |
Rep 960
depends on the brand/model of tire, but I am able to fit 285/30 quite comfortably. i'm lowered on B14s and have a little natural camber as a result, but nothing crazy. have never rubbed.
2018 Azurite Black F80 M3 ZCP
2019 Phytonic Blue G05 X5 2013 Glacier Silver F30 335i (sold) |
DLag30103.50 |
11-21-2020, 10:56 AM | #22 |
Rep 25
I've got the 437M wheels with 245/35/19 in F; 265/35/19 in R. Has H&R Sport Springs.
Does anyone have this setup? If so, can you confirm a 275 can fit in the R? @JRocker3: go with 17-18" wheels to track with, as others have mentioned @aps: 437M wheels look best on silver Apologies for pic angle.
6 spd MT; THP; H & R Sport Springs; 437M wheels; VRSF 4.5" catless DP; BMS intake; BM3 Stage 2 93 oct tune
