10-16-2020, 09:19 AM | #3763 |
Rep 29
Hi everyone,
Looking for some help here. I have my unit up and running and bought rederick's knob keyboard only to realize that my idrive knob isnt working in Android mode. Touchscreen works fine. Knob works fine in CCC mode, but once over to android its non-responsive EXCEPT I'll get random scroll and selects after a massive delay. Ive checked both Knob A and Knob B with no noticeable difference. This happened to me on initial install and jiggling the connections to the unit seemed to resolve it, or so I thought. Ive tried that again and no luck. Short of ripping out the dash and redoing the entire install to check for damaged wiring harness, is there anything else I can check? I had a helluva a time getting this unit installed and my hands are bloodied enough from the first go-round. EDIT: Fixed. I swear these units can be finnicky. Turned out to be a loose connection AGAIN. Even though I had checked previously. I pulled the headunit and removed the connections, cleaned them and reinstalled and the knob seems to be working fine now (and loving the rotary keyboard mod). Hopefully this post helps someone else out down the road. Last edited by preppyr6; 10-16-2020 at 09:36 AM.. |
10-18-2020, 01:16 AM | #3764 |
Rep 2
Hi. I have a px6 unit with android 8.1.0.
can i update it to android 9? The data on my screen are: MCUVer 023042bGS-NBT-HW7-190118(B1280_170325 Frameworkver:8.1.0 OPM5.171019.019 eng.zxw.20181228.162012 Androidver: 8.1.0 Appver 2019050501_1280x480 970 Nandflash: 17,23g/24,83G Ram: 2G Thank You |
10-18-2020, 02:31 AM | #3765 | |
Rep 1,048
Kri |
10-18-2020, 04:54 AM | #3766 |
Rep 2
10-18-2020, 05:00 AM | #3767 | |
Rep 41
its probably the wires inside the screen itself, just open it up and tape it down |
Mjam133.50 |
10-21-2020, 03:07 AM | #3768 |
Rep 6
how to fix bluetooth?
Hello! I reset it to factory settings. After that, my Bluetooth disappeared from the arm settings.
I used to have feiyitong selected in the bt module and everything worked, but after a factory reset, it is not listed in the bt module list and I can only select wenqiangbc6, but it does not work. How do I fix it? px6 device Last edited by Alex141; 10-21-2020 at 06:40 AM.. |
10-22-2020, 11:41 PM | #3769 |
Rep 2
Hello everyone and thank you for having me a part of this forum.
I have an Android 8.8 unit and my iDrive Wheel does not let me hit enter/select. Everything else works fine but the enter/select key only works if I press the triangle UP icon on my steering wheel (e90 3251 2007). I am sure this can be fixed via the settings of the unit but I don't know where to look. My installer did a firmware upgrade for me yesterday and all was working perfect. Now a day later the enter/select in the wheel isn't responding. I'd appreciate some help. |
10-23-2020, 02:31 AM | #3770 |
Rep 24
10-23-2020, 01:31 PM | #3771 |
Rep 22
Hi everyone. Is it possible to edit the homepage links to custom, like change the first navigation link to opening a preferred app. I use a lot carplay, and when i switch to oem menu or if the wireless carplay doesnt start automatically, i need to go to android apps menu scroll down then open autokit. Thats why i want to make autokit the first homepage link
Thanks |
10-23-2020, 04:17 PM | #3772 |
Rep 117
10-24-2020, 05:40 AM | #3773 | |
Rep 2,365
Drives: E63 645Ci
10-24-2020, 05:53 AM | #3774 | |
Rep 22
I am using the ID7 interface. Last edited by Metafan; 10-24-2020 at 06:01 AM.. |
10-24-2020, 12:31 PM | #3775 | |
Rep 2,365
Drives: E63 645Ci
Next you have two options here: you can either modify your own file or use the fully featured one done by kri. If you go with option one, open up your file and to the list of supported nav apps add your CarPlay app - you need to know package name of CarPlay app for this to work. Option two is to download factory_config.xml from here and again modify list of nav apps. This is how the list of supported nav apps looks like: Code:
<SupportNaviAppList> <Item name = "com.google.android.apps.maps" /> <Item name = "com.waze" /> ... </SupportNaviAppList> Code:
<Item name = "package.name.of.the.carplay.app" /> You can go a step further and create a theme with custom tile to show CarPlay logo instead of map and change the description of said tile. More info on that here. |
10-27-2020, 05:19 AM | #3776 |
Rep 47
Good morning! I just received an update for px6 android 9. I don't know what date it is, if it's helpful, I'll leave it here.
https://wetransfer.com/downloads/740...d74e02?src=dnl |
10-27-2020, 05:36 AM | #3777 | |
Rep 2,365
Drives: E63 645Ci
10-27-2020, 06:49 AM | #3778 | |
Rep 22
Thank you so much, i did it.
10-27-2020, 06:59 AM | #3779 |
Rep 2,365
Drives: E63 645Ci
11-05-2020, 10:47 PM | #3780 | |
Rep 1,048
If you ordered an Snapdragon unit, but received this i would recommend you to open a disput to your seller. the display resolution is looking like 1920 tough. Kri |
11-09-2020, 09:46 PM | #3781 |
Rep 2,602
Anyone run into this issue? I installed a program onto the Avin interface (I think it was an Amazon video download from the android store, and I was prompted to create a pin). I used the exact same pin I always use, and all was fine. After about an hour, I parked my car. When I returned, the unit was pin locked and wouldnt accept the pin I had entered. It's worth mentioning the prior owner still had his store credentials in the Avin, but it let me download and create my own pin. I even got the pin the owner usually uses on his own devices and no dice.
I contacted Avin, and they had me reset the unit with the _KSWOTA_ USB drive but the unit repeatedly just keeps going to the pin screen no matter what I do, including using the hard reset button on back. I re-named the file to Ksw-P-Userdebug_OS_v-ota-reset-data_factory.zip as instructed. Out of ideas at this point. The instructions I followed are below. 1: Format the U disk and empty it. Change the name of the USB flash disk in the computer to: _KSWOTA_ It is important that you have an underscore before and after the letters _KSWOTA_as shown in the photo below. DOWNLOAD from the link below Ksw-P-Userdebug_OS_v3.8.5-ota.zip https://drive.google.com/file/d/17xF...ew?usp=sharing After you have downloaded the file above rename the file to: Ksw-P-Userdebug_OS_v-ota-reset-data_factory.zip 2. Copy the file Ksw-P-Userdebug_OS_v-ota-reset-data_factory.zipto your USB flash drive with the name_KSWOTA_as shown in the photo above. 3. Insert this USB flash drive into the Android monitor's Yellow USB port 4. Restart the Android monitor's (must power off OR restart poking the RST and to start the force recovery. As shown in the photo below. NOTE: If the system is not updating, repeat the previous steps to update again. In the fourth step, please wait for two to three minutes before powering off and restarting to force the update.
11-11-2020, 11:07 PM | #3782 |
Rep 2,602
This has happened to me and now the unit wont recognize the zip file I'm trying to recover it with. How did you fix?
11-14-2020, 05:11 PM | #3783 |
Rep 13
Hi all,
First time posting on here. Sorry if I have missed it, but is there a central link for the last few MCU versions please? I have the latest but, as with many, the bass has stopped working. Whilst using the workaround does have some success, I would rather go back to a previous version that works. Further to this, is there a version of Android 9 that is able to have a split screen for me to have the radio and satnav on the screen together? Or is this just available in Android 10 please? And lastly, I have the dreaded flickering screen as someone else had previously in this page. Is there a way to reduce the temperature for the box as I am fairly pleased with the unit apart from this, and it would be a pain sending it back for a replacement. Many thanks. |
