02-07-2020, 05:10 PM | #23 |
Rep 1,230
mines might be leaking..just received the turbo smart plumb back so it should be on this week to replace the DV+. Venting to atmosphere version is a no go in my eyes. You will loose power being that the n55 is designed to recirculate the air and MAF sensor needs to calculate how much air to provide to fuel ratio. Unless you get the car tuned or running speed density it doesnt make sense.
N55 GENERAL
David Shoup Tuned Fully Built By Miami Engines/Project Motorworks Precision 6266 On Steroids |
oma3710194.50 Bmw doubles983.50 |
02-07-2020, 05:21 PM | #24 | |
Rep 1,282
SOLD! X5 35i sdrive- JB4 SOLD! 435i- Cary Jordan E30 Tune~ Dinan Turbo~ BM3 trans tune~ XDI-35~ 3.5 T-map sensor~ VRSF HD FMIC~ VRSF Chargepipe~ VRSF Catless Downpipe~ CTS Intake~ FTP boost pipe~ FTP intake inlet~ FTP oil catch can~ Turbosmart dual bov~ |
02-07-2020, 05:27 PM | #25 |
Rep 1,230
yes we beleive so. will confirm when its out this thursday. Been reading of failures, not so much on BMWs but on Audis.
N55 GENERAL
02-07-2020, 05:42 PM | #26 | |
Rep 287
maybe a fbo car it would not be an issue and maybe it would for you since you have a more modified n55? no way to tell unforunately Last edited by e38740imd; 02-10-2020 at 07:54 AM.. |
02-07-2020, 05:52 PM | #27 | ||
Rep 1,282
e38740imd65.00 |
02-10-2020, 07:55 AM | #28 |
Rep 287
02-10-2020, 03:57 PM | #29 |
Rep 1,230
you can have the vent to atmosphere diverter valve. Car will start up and run fine. No issues. Your tune will be off and car running hella rich due to metered air. If your fine with your car running rich, green light it.
N55 GENERAL
02-10-2020, 06:25 PM | #30 | |
Rep 1,282
02-11-2020, 01:45 AM | #31 |
Rep 373
has anyone run the gfb and then the TS unit back to back and noticed a difference? im loosing about 1-1.5psi of boost up at the top end, im not sure if thats just down to the turbo running out of steam or the gfb is leaking
'14 F20 M135i EWG FBO:// INJEN INTAKE // PURE INLET// TURBOSMART BOV DUAL PORT // //CSF INTERCOOLER // ER CP // SNOW S2.5 METH KIT // B58TU HPFP // NGK 97506 // ER DP // TMSS MID PIPE //MPE // MPBBK // UR STRUT BRACE // BM3 CUSTOM JORDAN E85 TUNE // XHP STAGE 3 // |
oma3710194.50 |
02-11-2020, 12:10 PM | #32 |
Rep 1,282
Mine arrives on Friday and will be installing it with the ftp version 2 inlet pipe. Will let you guys know!
alohasurftoad3078.00 e38740imd65.00 |
02-11-2020, 03:33 PM | #33 |
Rep 1,230
have you seen there datalogs? that would be the only indication. AFRs will tell you everything. Just because you start the car and it drives normal... tune will be off and rich
N55 GENERAL
02-11-2020, 03:45 PM | #34 |
Rep 1,282
I am sure Cary Jordan will make the correct changes for car to run 100%.
02-11-2020, 11:51 PM | #35 |
Rep 373
Awesome can you link the ftp v2 inlet I have never seen it before, the first one apparently is as restrictive as stock
02-12-2020, 07:14 AM | #36 | |
Rep 1,282
02-12-2020, 08:11 AM | #37 |
Rep 1,282
Did you get it out yet?
02-12-2020, 10:13 AM | #39 |
Rep 1,282
Yes, the pure is larger. The FTP is between the pure and oem. The old FTP was the same size as oem. I ordered it yesterday and should be receiving it tomorrow.
02-13-2020, 07:25 PM | #40 |
Rep 1,230
yes just got the car back. GFB was perfect. Changed the DV anyway to the turbosmart. Car is way more responsive. Anyone needs a GFB throw me a price in the DMs.
N55 GENERAL
02-13-2020, 07:56 PM | #41 |
Rep 4,143
02-18-2020, 12:19 PM | #42 |
Rep 1,282
Ok so here are some logs before the turbosmart bov and intake inlet pipe.
http://www.bootmod3.net/log?id=5e4694e8d10b432feef14c48 http://www.bootmod3.net/log?id=5e46db99c090c6419c25d67b After install. http://www.bootmod3.net/log?id=5e4c1d06d10b431a6386e9f8 http://www.bootmod3.net/log?id=5e4c1d66d10b431a6386e9fc http://www.bootmod3.net/log?id=5e4c1e0dd10b431a6386ea04
02-18-2020, 01:03 PM | #43 | |
Rep 1,105
Looks like your still under target boost but maybe your just at the limits of your octane or what your stock turbo can do. |
02-18-2020, 01:04 PM | #44 |
Rep 1,282
Do you notice any difference at all between the logs?
SOLD! X5 35i sdrive- JB4 SOLD! 435i- Cary Jordan E30 Tune~ Dinan Turbo~ BM3 trans tune~ XDI-35~ 3.5 T-map sensor~ VRSF HD FMIC~ VRSF Chargepipe~ VRSF Catless Downpipe~ CTS Intake~ FTP boost pipe~ FTP intake inlet~ FTP oil catch can~ Turbosmart dual bov~ Last edited by oma3710; 02-18-2020 at 01:13 PM.. |
