BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Auto brake when wipers ON @ above 80km/h
      01-18-2024, 09:06 AM   #45
nunomaia
Drives: BMW F36
Same porblem F36
Hi!
I have a 4 series F36 and the same problem. Above 80km/h in rain the car loses power and automatic braking for 1 or 2 seconds, it's still a big scare! I change gear and the car continues normally, until a short time later it does the same...very dangerous!
But it has happened without rain too, but not at such a low speed...
Nothing appears on the panel...
I've already tried to do what they told me for diagnosis, which was to turn off DTC and turn off DSC, but it causes the same problem. How is it possible for the car to brake on its own even with these systems turned off!?!?
Could the problem be the brake fluid as mentioned above, or the ABS module or some more specific sensor?
At BMW, without seeing it, they said it must be an ABS module! If they know it's a problem with the module and several cars, why don't they solve this problem!?!?
Anyone who has actually solved the problem please help...
Thanks
      03-23-2024, 03:19 PM   #46
cbrown
Drives: 2015 BMW 328i, 1997 BMW 328ic,
Fixed brake dry and brake drag issues
I have a 2015 328i, F30, rear wheel drive manual transmission I purchased a couple of months ago. I was first having an issue with the brakes not releasing after coming to a full stop. After the test drive I spoke to the sales manager who I had dealt with in the past on my wifes new Mazda's. I explained what was going on during the test drive and he said he would take to the BMW dealer they also owned. A couple of days later I went to pick the car up and the manager said it was hill hold. I owned several VW's with hill hold and none were ever that intrusive. Took the car home and still not satisfied with the explanation. On a rainy day with the rain sensor wipers on the car would brake very hard on its own and I would loose 15 to 20 MPH. Checked the brake fluid and looked like it had never been changed. Removed all the brake fluid from the reservoir and refilled with Napa DOT 4 I had at the house. Brakes were better but still not right. Pulled the wheels off and pressure bled the system. A little better but still not right. Pulled the wheels off again and re lubed the slider pins and cleaned the brake pad mounts, the calipers are single piston. No change. I then called an old Mercedes friend who was also retired and he said to go out and find some loose gravel and hit the brakes hard to get the ABS to kick in. Did that and the brake drag issue subsided temporarily but still came back. He said that one of the valves in the ABS/DSC unit were probably hanging up. Went on E-bay and found the correct ABS/DSC pump for 69 USD. BMW new is 3600 USD I installed the unit, power bled the system and went to a local BMW specialist to recode the unit. Picked up the car and it drove like a completely different car. This morning it was raining hard and drove the car with the rain sensor on, no hard braking. Problem solved. Apparently the old brake fluid corroded the valves in the unit and they would stick. Next thing I am going to do is pressure bleed the entire fleet. Learn something new every day.
