BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > NEED Help* F30 335i Stalling.
      03-25-2024, 04:07 PM   #1
David Kunitz
Mr OEM
David Kunitz's Avatar
South Africa
658
Drives: 2012 BMW 335i
Not sure if anyone has read this yet but your help would be much appreciated!
https://www.bimmerpost.com/forums/sh...php?p=31014051
      03-26-2024, 12:06 AM   #2
fe7565
fe7565's Avatar
Drives: 2012 BMW 328i N26
The issue could be fuel as you mentioned, could be ignition, or several other things. If you plan to work on this car in the future yourself, you should find a thread here for ISTA+ and ask for a download link. This is the BMW shop software. You need also a $10 ENET cable (Ebay/Amazon).
With ISTA+ you should be able to pull up hidden BMW specific error codes that can clue you to the source. Also allows you to run diagnostics and live data.
      03-26-2024, 05:45 AM   #3
David Kunitz
Mr OEM
South Africa
658
Not sure if I will be able to get ISTA, it would be good though.
Car took a while to start today and then stalled, after that I turned to restart it and it wasn't able to, just the starter spinning.
      03-26-2024, 06:19 AM   #4
devine mak
devine mak's Avatar
Drives: F30 335i SportLine
Hey David , I had experienced similar problems when my Low pressure fuel pump when out , threw me for a real one when I found out because there were no lights until the car wouldn’t start back up when it went. It can be tricky when trying to diagnose because you will still hear the HPFP when attempting to start and may dismiss fuel issues .
fe7565552.50
      03-26-2024, 06:31 AM   #5
David Kunitz
Mr OEM
South Africa
658
Hey Devine, many many thanks for your response, I truly appreciate it!
I have been thinking that it could be the Low Pressure Fuel Pump, will hopefully have a look at it when I am back with the car later today!
Do you have a recording or know how the HPFP and LPFP sound, It has been a while since I have had an F30 335i.
Big thank for the insight once again
