04-17-2015, 05:49 PM | #134 |
Rep 341
Ahh, I hating doing this but I figure I give it a shot in case someone has ran into the same issue as me and might know what is going on. So I ended up buying a new REM and P# 61359329700 was replaced by BMW by P# 61359362394 and the dealer sent me the new one. I figured it should work. I installed the new REM today and tried to inject cafd into REM but with the current i-step level of 14-07-503 I could not read SWE. Oh, before I even tried to inject any files I decided to scan the car with Rheingold and see what errors were there. I had 5 extra errors which 4 them were about voltage supply and no auto close up function to rear windows. Clearing did not work and the auto-up really did not work from driver's button or rear door buttons. I figured it should go away ones I inject cafd but ones I tried to read SWE I would get the message "Could not read CAFDs from SWE. BTW this is on psdzdata 53.4. So I figured I will just get the new psdzdata 55.1. With the new psdzdata I was able to read from SWE but my i-step level was not available so I picked the latest to inject into REM. Injecting the file worked and I coded off bulb checking off. I scanned the car and same errors were there and auto up still didnt work. I also changed my psdzdata to 54.1 without the trimmed cafd files and downgraded the i-step level on REM but that didnt fix the issue. So finally I gave up and returned to my original REM. I am hoping this can be fixed otherwise I have a $200 paperweight REM that I can't return and I will have to look for a used 700 model. Any insights or suggest are appreciated.
04-17-2015, 06:14 PM | #135 | |
Rep 1,141
04-17-2015, 06:36 PM | #136 |
Rep 341
Codes are 030115, 030120, 030195 and 0301A0. Roxxor, do you know get the windows initialized? I found some instructions but holding the button for a minute doesnt work also I am missing "initialize power window regulator" when i drill down into service functions.
04-17-2015, 09:29 PM | #137 | |
Rep 1,397
reinitialize the window with reihngold and it will go away and auto up will work again |
04-17-2015, 09:35 PM | #138 | |
Rep 1,397
Service function body locking and security functions power window regulator initialize power window regulator follow the prompts |
04-17-2015, 09:57 PM | #139 |
Rep 341
Thanks guys. Maybe I need to update to 3.46.30 from .20 because that option was not there. I'll update tomorrow and try again.
04-18-2015, 09:23 AM | #140 |
Rep 1,035
Just another data point here...
I was telling f30GTR that I was having rear-window issues as well after the REM swap (not going up when using driver window controls). I thought my driver window control unit went bad (it had been acting flaky intermittently after my bavsound speaker install after I had man-handled it trying to get it out) A few days after injecting the new CAFD using SWE to code the new 700 REM, I just happened to try the rear windows again from the driver control module and it worked. I didn't even tie that back to the coding of the REM until f30GTR brought it up. I thought it was just an intermittent driver control module. But it works great now. Incidentally, I didn't have to use Rheingold to re-initialize to get it to work. Does he have to do that because he coded his REM with a CAFD that was not his original/exact I-Step? I've always wondered about the safety of doing a CAFD inject with a version that is LATER than the I-Step level of your car. Having to re-initialize a bunch of stuff would be a good reason to try to avoid using a later I-Step if possible... Last edited by squidlyboy; 04-18-2015 at 10:19 AM.. |
04-18-2015, 01:08 PM | #141 |
Rep 341
Woot, I am happy to report that I was able to initialize my rear windows and fault codes are gone, or most of them. Kombi error still there but worry about at another time. My headlights errors is there but I am sure that is because I raised my headlights too high Next moving onto removing bumper and all the fun stuff. Thanks for the helps guys. This community rocks.
squidlyboy, good thing you didnt have to do anything because I started getting worried about the module not working. I already painted my sensor and bought my drill bits. I was ready to go and getting stuck at REM didnt make me very happy. |
04-18-2015, 01:16 PM | #142 |
Rep 1,141
I don't think that would cause the error about the light control... By any chance did you swap your headlight switch in the car with a euro one to enable rear fogs? That's what I had done, and it was fine until I did my xenon retrofit, now I get that error. I'm thinking it's because the euro switch I got was for halogen headlights, not xenon.
04-18-2015, 01:49 PM | #143 | |
Rep 341
04-18-2015, 01:49 PM | #144 | |
Rep 1,479
Drives: 2020 M340Xi (G20)
Funny that you mention the Euro light switch. Some time ago, I swapped out for Euro light switch and coded left rear fog light (like most European cars do). One of my earlier challenges with the dealer was that with that switch he was getting several errors so I put original back in until I get my stuff done. BTW, dealer claimed (mistakenly) that the light switch stores info on the car
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA |
04-18-2015, 05:09 PM | #145 | |
Rep 1,035
But besides that, what did you end up going with: later i-step cafd with psdzdata 55.1 or earlier i-step cafd with psdzdata 54.1 ... odd you weren't able to find your exact i-step level CAFD available. |
04-18-2015, 07:29 PM | #146 |
Rep 341
Hey guys, I take the sensors' connectors need to be facing up?
I ended up using 54.1 since it's not trimmed and it works. I think the initialization is because of the pinch safety function. If the windows didn't have auto up I doubt we have to initialize the motors. Last edited by f30GTR; 04-18-2015 at 07:50 PM.. |
04-18-2015, 08:18 PM | #147 |
Rep 1,035
You're the second one to mention installing these sensors in a specific direction. I don't know why it would matter.
Roxxor mentioned in his original DIY that the sensors connector ends should be facing away from the bumper center, but he didn't say why. I can see if there were obstruction issues, but it seems like the back of the bumper is pretty free and clear. It doesn't make any sense to me |
04-18-2015, 08:18 PM | #148 | |
Rep 1,397
my bumoer came with holes and mounts predrilled and installed so im assuming its correct |
04-18-2015, 08:41 PM | #149 | |
Rep 341
04-18-2015, 09:04 PM | #150 |
Rep 1,035
04-18-2015, 09:48 PM | #152 |
Rep 341
04-18-2015, 11:02 PM | #153 | ||
Rep 1,035
Maybe these vatapro sensors are not as bad as originally thought. Still ... with OEM sensors running close to $200 a piece compared to $30 for the vatapros, you gotta expect some difference in performance - that's a pretty big price discrepancy. I may just go with a light single coat of paint like you did. Maybe it was the excessive sanding/repainting that 1lyfe did to them that caused some performance degradation... Just got bad news from partsale saying that there was a delay at the factory and my pdc retrofit cables are gonna be at least another two weeks. dang it. getting tired of waiting already... |
04-18-2015, 11:37 PM | #154 | |
Rep 341
