07-02-2018, 03:00 PM | #1 |
Rep 50
275/30/19 rears on staggered set for f30 328i w/xdrive?
Hi all. I currently have a f30 328i xdrive running style 397s (18x8 et34, 225/45/18s all around). Im interested in a staggered set of wheels with the following specs:
fronts: 19x8.5 et34 , 235/35/19 rears: 19x9.5 et34 , 275/30/19 Has anyone used a similar setup? I just wanna know if they setup will work for my f30. Any help, feedback or advice would be appreciated. |
07-02-2018, 03:25 PM | #2 |
Rep 808
I run a similar setup and it's fine on x drive. Only thing is you need to bump the front to a 245/35/19. The rolling diameter is 1.2% different, but similar enough to OEM as the front wheels are slightly bigger.
07-02-2018, 04:39 PM | #3 | |
Rep 50
Thanks, couple of questions for you. Are your offsets the same for all 4 wheels? Thats what Im a little concerned about. Also, why didn't you go with 235/35/19 for the fronts? I thought that the 235 was actually closer to OEM rolling diameter than the 245.... |
07-02-2018, 05:11 PM | #4 | ||
Rep 808
As for the size, 245/35/19 I believe is closer to OEM size, a little shorter overall by about half an inch I believe. The 235s you can run but the difference in size I wouldn't mess with... so in that case it would be recommended to go with a 265 rear |
ikehigh0534.00 |
07-02-2018, 07:43 PM | #7 |
Rep 4,318
oem diameter is 26". 235/35/19 and 275/30/19 are both 25.5", perfect for x-drive, however if you are not lowered you will be increasing your wheel gap 1/4".
1bad14-F3030.50 |
07-04-2018, 08:35 AM | #8 |
Rep 400
1bad14-F3030.50 |
07-05-2018, 09:30 AM | #9 |
A family of bimmers
2745
Rep 7,741
why would you want to run a .5" shorter tire? also an et34 with a 275 is going to poke quite a bit
07-06-2018, 10:04 AM | #10 |
Rep 50
Im not choosing to run a shorter tire, those are the tires already mounted on the wheels that are for sale from a friend. Id prefer not to buy new tires if I dont need to. In terms of the poke, it doesnt look too horrible based on the pics in the tread above. I do feel like I need to see that offset in person though.
07-06-2018, 01:06 PM | #13 | |
Rep 808
I just know that an expert told me that and that I've liked the setup and have had no problems at all with it. |
07-15-2018, 11:13 AM | #14 | |
Rep 487
I am assuming you are running a 235/35-19 front and 275/30-19 rear? |
07-15-2018, 07:16 PM | #15 | ||
Rep 808
