BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Harman Kardon missing High tones
      03-21-2019, 02:53 AM   #1
vinzcast21
vinzcast21's Avatar
161
Drives: F30 340i MY2017
Hello there
I noticed if you connect using bluetooth on for music, sometimes the trebles are muffled and then came back to live couple seconds later. This happened on my front passanger side only where I was listening to hardstyle, the high pitched noises were sounding like they were covered by something and then got released seconds later.
does not happen when the phone is plugged in with USB to listen to music. Anyone having same issue?
Mod bug will bite you if you buy a BMW
      03-21-2019, 10:19 AM   #2
jay_spec5
Drives: 2019 430i F36
I have the same issue. Are you on iOS? I started noticing it a few updates ago. Repairing the phone didn't solve the issue either.
I'll have to try plugging in through USB.
      03-21-2019, 10:37 AM   #3
M3DIA
M3DIA's Avatar
Drives: 2011 E92 M3 // 2015 F82 M4
yea happens all the time, but for me it seems like the clarity goes from good to bad every minute or so
      03-21-2019, 11:41 AM   #4
upsidedownfunnel
Drives: 2014 335i
2014 BMW 335i  [0.00]
What version of smartphone OS are you on? Which OS? Android or iOS?
      03-21-2019, 12:33 PM   #5
N26Ghost
N26Ghost's Avatar
Drives: 2014 BMW 328i M Sport
Make sure your iPhone is always on the latest iOS version.
I am an audio-nerd and refuse to use the BT connection and use the USB port and a magnetic mount each time. The sound quality has been good, with the exception that the armrest tends to short out any lightning cable.
To mitigate this, I used a Dremel and created a channel in the arm rest for the cable to sit in. Since then, I've been using the same cable without issue. So sad BMW sought fit to place the USB port in such a bad spot.
Also, is your iDrive up to date?
'14 F30 328i M Sport // FBO // bm3 Stage 2+ DME Tune // Stage 1 TCU Tune // Apex EC-7s on Conti DWS06+s // 1 of 6 ever made of this spec (3C13 US-SULEV German-built //
      03-21-2019, 12:57 PM   #6
vinzcast21
vinzcast21's Avatar
161
Yes , I am using the iPhone X with latest software and on the iDrive too. seems to not happen when plugging with aux and usb
      03-21-2019, 12:59 PM   #7
vinzcast21
vinzcast21's Avatar
161
iOs 12.1.4
      03-22-2019, 10:11 PM   #8
akgambino
Drives: 2013 F30 335xi M-Sport (PWG)
I have been noticing this issue lately as well and I don't have HK only hi-fi. Seems like the really high end frequencies sort of come and go throughout a song intermittently but only happens through Bluetooth. This makes me feel it is an iOS issue because I only started noticing it recently.
2013 F30 335i xDrive M-Sport 6MT (FBO/BM3 custom tune by HCP, 91 oct, 550i clutch, xDelete)
      03-23-2019, 12:00 AM   #9
vinzcast21
vinzcast21's Avatar
161
I found the problem. seems to happen on ios 12.1.4 above. I tested on my other phone that still uses the ios 12.1.2 and seems the problem not to happen. plugging it via usb from now on
      03-23-2019, 10:29 PM   #10
Elvisfan
Drives: 2018 430ix convertible MGM
Probably interference from all the electronics. There is a lot going on.
