03-12-2019, 03:03 PM | #45 |
Rep 943
Drives: F30 328i Msport
03-12-2019, 03:13 PM | #46 |
Rep 4,456
I did get it back and no they did not replace it.
They did fix an oil filter housing leak under CPO. They told me to come back in a year to give it one final check before the extended warranty runs out. This is nothing new to them so I believe that mine is okay...........for now |
03-12-2019, 06:00 PM | #47 |
Rep 14
HELP!!! How do I not get screwed by BMW Service for Timing Chain Issue?
Help!!! My BMW Service Advisor just called and set my engine was blown and will be $17k to replace. He said the technician found bits of metal in the oil tank (probably from the turbo) and my engine oil level was low. Which is interesting because my car never once gave me a warning that my engine oil level was low, even when I ran the oil level diagnostic on iDrive less than a month ago.
So of course I brought up the faulty timing chain and oil pump 7yrs/70k on my N20 engine (my car only has 59k miles so is covered). The Service Advisor looked to see if I fall under that warranty with me on the phone and then confirmed that I do in fact fall under the warranty. He then told me that the technician's diagnosis did not involve the timing chain or the oil pump so that he doesn't think my engine is covered anyways but would check with the technician. If he calls me back and says that the technician tells him that wasn't the issue and my engine isn't covered what do I do??? How do I prove that it was the timing chain or oil pump that was at fault? From every post I've read and video I've seen about this issue, all signs point to the timing chain being the issue! |
03-12-2019, 06:16 PM | #48 |
Rep 1,051
i see this post has bring brought from the dead and back and dead and back again. whats the verdict on getting this replaced from the dealer or an indy shop? curious as my f30 m sport 328i has 92k however the vin doesnt meet the recall list. would changing it result in piece of mind or are their other issues with this engine as well?
03-12-2019, 06:18 PM | #49 |
Rep 5,451
Drives: F30
@cbsturge
What sort of oil change intervals have you been running? Do you have proof to support this? Did you use Auto Start Stop regularly? Any whining noises leading up to the failure? You never told us what caused you to bring the car into dealer in the first place... |
BettyFkinCrocker180.00 |
03-12-2019, 06:20 PM | #50 | |
Rep 5,451
Drives: F30
If all is well, Id leave it alone and keep your ear perked up for whining sounds. They usually don't just pop outta no where... they tend to whine for hundreds if not thousands of miles first. This isssue really isnt that common on well maintained vehicles. |
03-12-2019, 06:31 PM | #51 | |
Rep 14
Yes, I did use Auto Start/Stop regularly but less so in the past few months. I don't really recall hearing winding noises but if I did I probably wouldn't have noticed. What caused me to bring the car into the dealer was I got these two back to back error messages: ERROR MESSAGE 1 - Drivetrain malfunction: Drive moderately. Maximum drivetrain output not available. Consult service center. ERROR MESSAGE 2 - Engine Oil Pressure Too Low: Stop carefully and stop engine. Risk of engine damage with continued driving. Call roadside assistance. ...and then my engine just completely died. |
sspade2460.00 |
03-13-2019, 06:17 AM | #52 | |
Rep 191
IG: @derringerF10
2016 550i RWD N63TU 8AT | Catless Downpipes | BaskiSpeedworks STOCK TURBO RECORDS 1/4: 10.90@128 60-130: 7.43 |
03-13-2019, 01:05 PM | #53 |
Rep 230
1. So a month ago oil was at Max, and now dealer measured it as low, plus the message. Sudden oil leak? No enough oil at oil change? Oil pump failure? last does not explain low oil... There is room for investigation.
2. If metal shaving found, that is most likely end of the engine. No chain replace will help. Burned rod bearings, cylinder scoring, shafts... |
03-13-2019, 01:13 PM | #54 | |
Rep 14
2. The engine is definitely blown and needs to be fully replaced. I'm just hoping BMW says the cause is from the faulty oil pump and/or timing chain and not that my car was overdue for an oil change. |
03-13-2019, 07:50 PM | #55 | |
Rep 1,051
sspade2460.00 |
03-13-2019, 08:14 PM | #56 | ||
Rep 5,451
Drives: F30
Im at 71,5XX miles and counting fast. |
03-13-2019, 11:02 PM | #57 |
Rep 3,674
That and disabling auto start/stop!
03-15-2019, 04:04 PM | #59 |
Rep 1,051
03-15-2019, 04:32 PM | #60 |
Rep 3,674
When the engine turns off, the chain obviously stops spinning, and the jerk of starting and stopping the chain with AS/S can put a hurt on the chain and guides. Also, some have speculated that oil drips off the chain when the engine stops, and when it starts back up it's not well lubricated. Basically, starting the engine is a relatively laborious task, and it's not something you want to do 50 times per day.
BettyFkinCrocker180.00 SPSE93112.50 |
03-15-2019, 07:39 PM | #61 |
Rep 191
Well, when it's well/properly designed, it isn't a problem. BMW just implemented a clearly flawed design that makes the ASS feature a detriment to engine longevity.
IG: @derringerF10
03-15-2019, 11:01 PM | #62 |
Rep 3,674
I guess it's moreso for the N20, but in all engines startup is hard on stuff. Not as much oil pressure as when it's running, and everything is ice cold.
03-16-2019, 07:15 AM | #63 |
Rep 19
Clearly a flawed design.
80,000 KM 528i produced in May-2012. OCI 10,000KM or 1 Year. Always switch off ASS and coded it off in 2014. The problem is the guide rail. Look carefully and you will see crack where the side rail clip on to the top rail. Car does not have any whining noise at all. Took off valve cover due to VC oil leak. It is not whether it will happen ? It is when it will happen. Contemplating whether to repair or sell the car. Last edited by mikessc; 03-16-2019 at 07:20 AM.. Reason: More info. |
03-16-2019, 08:36 AM | #64 | |
Rep 15,966
The timing chain is a problem. The ASS system is present in cars with the N20/26 engine. Are the two connected? Maybe. But it's more than a bit of a stretch to connect the two. What if the timing chain problem is related to service hours, and not stop start cycles? In that case using ASS might extend the timing chain life. Either case is a possibility. In the absence of irrefutable evidence it's all speculation at this point. |
03-16-2019, 08:54 AM | #65 | |
Rep 3,674
03-16-2019, 09:40 AM | #66 | |
Rep 19
Read page 41 of 'BMW B46/B48 Engine Technical Documentation' on this sub-forum. ie. 5th sticky on first page. I agree with you that not using ASS will not extend timing chain life. The problem is the chain guide not the timing chain as depicted in my post. |
