03-06-2019, 09:16 AM | #112 |
Rep 2,665
Yep...Fortunately I have a reputable shop nearby with great pricing that will take care of that.
CandyRedRC46242.00 |
03-06-2019, 02:06 PM | #113 |
Rep 2,665
The exhaust mod isn't listed under supporting mods on BM3 - so not sure if less back pressure is required or not. Wouldn't want to overspool the turbo.
Also my axleback is 2.5" - fitted to the 3" magnaflow muffler. |
03-07-2019, 03:44 PM | #115 |
Rep 3,679
^ +1 Back pressure is not necessary and is a detriment to performance.
03-07-2019, 07:45 PM | #116 |
Rep 2,665
So you're saying bigger is always better when it comes to turbos exhaust systems??
That's not how I understand it... but I'm not professional mechanic or tuner of course. |
03-08-2019, 06:54 AM | #117 |
Rep 3,679
Pretty much. Turbos use back pressure to spool to a degree, so with no back pressure you'll drop a few psi but the turbo will spin more freely. Generally, the less back pressure the better. It's a very common myth that engines need back pressure.
03-08-2019, 07:18 AM | #118 |
Rep 5,457
Drives: F30
Not debating, just sharing...
I am also under the impression that some back pressure is needed and is healthy for an engine/system running optimally. |
03-08-2019, 07:39 AM | #119 | |
Rep 3,679
So, yah, for optimal performance on a normal engine, you don't want to just dump the exhaust out of the DP or headers, not because it needs back pressure, but because you want some exhaust velocity. I hope that makes sense.
03-08-2019, 08:55 AM | #120 |
Rep 420
Exhaust turbines operate via pressure differential.
i.e. high pressure on one side and low pressure on the other. A turbine will be most effient while there is as little pressure on the outlet side as possible. You will need optimal pressure and velocity on the inlet of the turbine (cylinder head exhaust ports and turbo manifold, which is totally out of the scope of this topic/thread), but on the outlet of the turbine, exhaust gas velocity is of little concern. The only concern on the turbine and back, should be minimizing back pressure. So you will want to go as big as realistically possible on the turbo back exhaust, which due to clearance constraints means 3.0" turbo back. Any bigger and you will be rubbing hard parts and increasing noise/drone, with no added increase in performance.... Now on an NA engine, this is different. Exhaust gas velocity, scavenging and back pressure is very important through the cylinder head exhaust ports, header, collector and exhaust system. You will want velocity as high as possible, with out hindering pressure/flow. This will not be possible at all rpms, so it will need to be tuned to your desired powerband (and your ability to tolerate high noise levels lol). An exhaust system with ideal velocity for a given engine at low RPMs, will have too high of exhaust gas velocity at higher RPMs, in turn creating too high of backpressure at higher rpms, reducing torque/power output. Vice versa, an exhaust system with ideal velocity for a given engine at high RPMs, will have a low exhaust gas velocity at lower RPMs, in turn reducing the scavenging effect at low rpms and reducing low rpm torque. Last edited by CandyRedRC46; 03-08-2019 at 09:11 AM.. |
03-08-2019, 12:49 PM | #121 |
Rep 5,457
Drives: F30
@rjdnyy224
CandyRedRC46 Both of those explanations provide quite a bit of insight. Much appreciated. So far, Ive removed my cat restriction... plan is to throw MPE on this spring/summer (along with BM3). That will leave me with only a stock resonator remaining which I will most likely keep depending on sound. In theory this should make my exhaust "free'er flowing." |
CandyRedRC46242.00 rjd_F301999.50 |
03-08-2019, 01:10 PM | #122 |
Rep 2,665
Is 2.5" not enough on my 320i? Thanks for the detailed info - very insightful indeed!
03-08-2019, 02:11 PM | #123 |
Rep 420
03-08-2019, 03:44 PM | #124 | |
Rep 3,679
sspade2464.50 |
03-08-2019, 06:12 PM | #125 | ||
Rep 5,457
Drives: F30
My cold starts are horrible currently... as is the CEL im staring at... I need BM3 bad! Waiting for someone to offer up a used license for $350. That honestly appears to be current fair market value. Ive actually seen them go for less! |
03-08-2019, 09:35 PM | #127 | |
Rep 5,457
Drives: F30
If I was in Florida (or SoCal), I'd already have it too. Been in full ski mode the past couple months. Gotta pick my spots, everything fun is super expensive Only about a month or so left and the focus will be back on the bimmer full time! |
floridaorange10144.00 |
03-08-2019, 10:01 PM | #128 | |
Rep 3,679
$350 for a used license would be a great deal, hopefully you can find it!
03-16-2019, 08:19 AM | #129 |
Rep 172
03-18-2019, 02:41 PM | #130 |
Rep 420
I am not sure what your definition of plug and play is, the factory cat back is one entire solid piece, you would have to find an entire 328i catback, cut it at the axle back and then use your axleback or see if you could find the entire 328i mid pipe for sale, already cut in the right spots. Either way there isn't much plug and play for these cars so you will need to get creative, beyond the downpipes....
03-19-2019, 08:13 AM | #131 |
Rep 172
Thank! I got it. Basically I need to find one whole piece of 328 exhuast after the downpipe. I am trying to stay stock looking (without additional welding/clamps) so I can pass the annual inspection.
02-27-2022, 08:00 PM | #132 | |
Rep 1
