BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coding cable and ESYS, psdzdata
      01-02-2015, 09:50 PM   #89
O4x5dude
O4x5dude's Avatar
37
Drives: F82 M4
Can you send me the newest software and data for a 2012 F30 please ? Thanks in advance.
      01-02-2015, 11:33 PM   #90
shawnsheridan
shawnsheridan's Avatar
PM sent.
      01-08-2015, 02:31 AM   #91
BHKent
Drives: F30 328i
Hi Shawn, I have a 2012 328i.
I am downloading the psdzdata torrent listed in this thread early on.
Could you please send me the install/set-up instructions.
Regards and Thanks in advance
Brett
      01-08-2015, 03:07 AM   #92
shawnsheridan
Brett
PM sent.
      01-15-2015, 12:38 AM   #93
miretni
miretni's Avatar
Drives: F30 28i
PM sent.
Thanks shawnsheridan
I've been AFK for a long time, thanks for keeping send pm to the person who needs it, appreciate that.
2013 328i xdrive
      01-15-2015, 08:29 AM   #94
f30mvp
MVP
f30mvp's Avatar
Drives: BMW F30 XDrive
VO Coding
I am looking to revert some changes in Fem Body. If I VO Code (right click on the ecu and code) it will it revert all the changes I made for Fem Body or is that only after flashing the FA? Thanks
-2015 328i XDrive Sport-Black Sapphire Metallic | Leather Dakota Black/Red highlight
-ZSL | 7AC | ZCW | ZDA | ZDB | ZDH | ZLP | ZPP | ZTP | 688 | 8S4
      01-15-2015, 09:03 AM   #95
shawnsheridan
Yes, it will, so long as the FA used to VO Code FEM is original and not modified in any way.
      01-15-2015, 02:29 PM   #96
f30mvp
MVP
f30mvp's Avatar
Awesome worked just like I was hoping.
      01-15-2015, 05:34 PM   #97
f30mvp
MVP
f30mvp's Avatar
Enabling Sports Transmission & Launch Control on Sports Line
Info Please!
I have an 2015 328i XDrive. I was curious what is the point of coding Sports Transmission on my car(code example below)? I don't have paddle shifters, but I do have an 8 speed transmission with sports and sports + modes. I did attempt to code it and it seemed to shift into gear harder but I didn't notice any increase in speed.
Second question.
I also don't have launch Control (it doesn't even show up in the manual) I checked the code and EGS LC is currently set to aktiv, any thoughts?
Code Example to Enable Sports Auto Transmission
EGS 3000 Sportschalter aktiv nicht_aktiv Enable Sport Auto Transmission (Part 1)
EGS 3000 Sportschalter_alt aktiv nicht_aktiv Enable Sport Auto Transmission (Part 2)
      01-16-2015, 11:10 AM   #98
caesar77
caesar77's Avatar
South Africa
Drives: BMW E92 M3
Software please
Hi Shawn what a great help your are to the members. I am new to the forum and would appreciate if you could send me links for instructions and software. I have a F30 2014. Thank you.
      01-16-2015, 11:12 AM   #99
shawnsheridan
PM sent.
      01-16-2015, 11:40 PM   #100
to0nice4ya
Drives: 2014 435xi coupe
help with f36 coding
Hey shawn, i tried coding a f36 grand coupe last night but it seems like i dont have the newest pszdata since the car's vehicle data was F020-14-11-502, my esys only goes up to F020-12-07-502. Can you direct me to the newest files for this model please? Also, this is my first time upgrading the psdzdata. How do i update the files once i've downloaded them. I currently have version 53.4. Greatly appreciate your help.
      01-17-2015, 07:49 AM   #101
shawnsheridan
PM sent.
      01-17-2015, 06:31 PM   #102
phattbam
Drives: '17 Protonic Blue i3 REx
Hello Shawn,
I'm running into this issue when I try to read SVT
SVT <"ist"> could not be read.
      01-17-2015, 07:09 PM   #103
shawnsheridan
Originally Posted by phattbam View Post
Hello Shawn,
Use Read ECU Button next to it instead.
      01-17-2015, 07:17 PM   #104
phattbam
Ecu (0)
Is what I get. When I try to activate FA
I get No FP could be generated from FA "" , [C002]
      01-17-2015, 07:45 PM   #105
shawnsheridan
Ecu (0)
Check your Connection parameters:
On E-Sys Toolbar Press the "Connect" Button and in the "Open Connection" window under "Target", select desired Target Vehicle based on car's Chassis.
(e.g. "TargetSelector:Project=F020-14-11-502, VehicleInfo=F020")
*NOTE: Do NOT select the Target with the "_DIRECT" suffix (e.g. TargetSelector:Project=F020-14-11-502, VehicleInfo=F020_DIRECT).
In the "Open Connection" window under "Interface" select "Connection via VIN".
In the "Open Connection" window under "vehicle-specific parameter (optional)" select "Series, I-Step Shipment", and leave the two Dropdown boxes blank.
      01-17-2015, 07:49 PM   #106
phattbam
That's how I connected to it. Rebooted my laptop and disabled antivirus and made sure I get the yellow exclamation mark for my LAN connection before launching E-Sys
      01-17-2015, 07:50 PM   #107
shawnsheridan
I would need to look at it with TeamViewer.
      01-17-2015, 08:03 PM   #108
phattbam
Any other information I can provide?
      01-17-2015, 08:32 PM   #109
shawnsheridan
No. I would need to connect and look at it.
      01-20-2015, 02:48 AM   #110
Eliott_C
Drives: 2015 435i MSport Convertible
Hi Shawn, I would like to start coding so could you send me the link to the instruction and software ?
