04-20-2019, 11:20 AM | #1 |
Respect My Authoritah
368
Rep 873
One Reverse Light Not Working
Alright people. Help me out. Both of my reverse lights were working, but I swapped them out for some canbus LED's. I coded them in BimmerCode and they worked perfectly for a few months. Now one of them won't light up, even when replaced with a stock bulb. I think there might be something wrong with the REM. Here's what I've done:
-Coded LED settings back to stock -Swapped LED's. It's clearly only the drivers side that's not working as the drivers LED works in the passenger socket. -Checked all related cables for burns/corrosion/cuts. -Checked all fuses related to bulbs(even the five REM fuses). -Not throwing any codes when scanned. What am I missing? Replace the REM next? Or the bulb housing?
2014 335xi M-Sport 6MT: Estoril Blue II, MHD Stage 2+ , Dinan Exhaust, Dinan CAI, ER Catted DP, ER Chargepipe, AA FMIC.
04-20-2019, 04:03 PM | #2 |
Rep 16,082
Since there is no left/right reverse lamp I'd break the connection on the socket to the drivers side bulb and run a wire from it to the supply on the passenger side. Since the current draw is far lower with LED that wouldn't put a strain on the passenger side wiring.
04-20-2019, 05:24 PM | #3 | |
368
Rep 873
04-20-2019, 05:40 PM | #4 |
Rep 16,082
I doubt the LEDs caused the problem. If so this topic would have popped up years ago. I also doubt that disconnecting the battery will have any effect, other than your having to reset your clock.
04-20-2019, 06:31 PM | #5 |
368
Rep 873
Correct and correct. Didn't do anything. Now have to reset clock. There's no power coming to the connector. Cables look good. Might just order the rear module.
04-20-2019, 06:53 PM | #6 |
368
Rep 873
What I really need to know is how would the REM fail to send a signal to only one bulb. Is wiring the more likely culprit?
04-20-2019, 08:46 PM | #8 |
368
Rep 873
I'll buy a multimeter tomorrow and check that. I bet tracing down which wires control the driver side will be tough.
04-21-2019, 04:04 AM | #10 |
New BMW owner
139
Rep 621
Drives: BMW 316d, BMW F40 116d
Don’t you just have a short circuit?
04-22-2019, 11:16 AM | #12 | ||
368
Rep 873
06-13-2019, 08:50 AM | #14 |
368
Rep 873
So the REM is throwing a code that's related to too many short circuits. Basically, it has shut down the driver reverse light and it won't come back on. It's reached the max shorts or something like that. Seems like the only way to fix this is to buy a new REM. I'll need to fix the short first. Anyone know how to reprogram one of these, or do I need a new one?
06-13-2019, 10:23 AM | #16 |
368
Rep 873
06-13-2019, 10:39 AM | #17 |
Rep 16,082
What are you using for a diagnostic tool? A fault code shouldn't come back after being cleared unless you do something to cause it, like putting the car in reverse.
06-13-2019, 04:28 PM | #18 |
368
Rep 873
I was using the diagnostics page of Bootmod3. I have an NT510 but haven't really taken the time to figure it out. Does it need to be done through that?
06-13-2019, 06:26 PM | #20 |
368
Rep 873
I'll figure it out and try to get it done with the 510
06-14-2019, 12:51 AM | #21 |
New BMW owner
139
Rep 621
Like I said in the first place, you just have a short circuit.
You either need Toolset32 or ISTA+ to remove the shortcircuit. OBD reader won’t do the job. |
06-14-2019, 07:44 AM | #22 |
Rep 16,082
If the OP has a short circuit no tool will remove it, unless said tool is perhaps a screwdriver. If he has a short circuit fault code an OBD reader won't remove it, but a diagnostic tool like the NT 510 should.
