09-20-2015, 04:12 PM | #89 | |
Rep 886
02-15-2017, 03:26 PM | #90 | |
Canyon Carver
50
Rep 185
03-07-2017, 01:58 AM | #91 | |
Curmudgeon and Pedant
690
Rep 3,489
Failure of lubrication for the air pump, covered by a recall. |
03-24-2017, 12:57 AM | #92 | |
e90noob
1588
Rep 1,862
And that they need to investigate it Otherwise you will be placed at fault for the collision So what happened? You posted a month ago so I hope things went well for you |
03-24-2017, 10:34 AM | #93 | |
Canyon Carver
50
Rep 185
But I lost confidence in driving the car around. So I traded in the car with the same dealer and got a 135is. Took a $5k hit. |
03-24-2017, 07:49 PM | #94 | |
e90noob
1588
Rep 1,862
were your tires bald? were you driving in the snow with summer tires? you said you hit another car so you had damage to your own car and someone else's car if the brakes failed, i would not be dropping this that easily
Production date - 2008-04-22 |
03-26-2017, 10:24 PM | #95 | |
Canyon Carver
50
Rep 185
The tires were a bit bald. The front ones. I didn't hit the car in front. I meant to avoid hitting the car in front, I went off the road instead. I used hand brake to stop the car. The traffic was bad and I was going probably 20 -25 mph. |
04-11-2017, 09:00 AM | #96 |
Rep 16
I ran into this same problem and it scared the life out of me. 2016 320i is what I drive. Base model no m-sport anything. I was going about 50mph and I was coming up at a red light and the brake pedal became rock hard and would not go down. As I kept getting closer I just kept pumping the brake pedal and it eventually went down and I screeched the car to a stop. From there I drove the car to work and the whole time after that the brakes were giving a bad grinding noise. I then had the car towed to BMW. Next day I went to pick it up and they told me they found no problems in the vehicle's diagnostics or on the road tests.
I really hope BMW issues a recall on these f30s and fixes this problem. Terrifies me to drive my car now since I have to always worry about not being able to stop. |
08-10-2017, 08:46 PM | #97 |
Rep 136
Hey guys so two weeks ago my 340 msport xdrive started to have brake issues. It seemed that when braking the pedal becomes soft then dead and won't stop he car unless you pump it several times. It's even worse in situations of bumper to bumper traffic. Long story short took it to BMW and they can't replicate the problem; not surprised. They told me I have to come in to drive it with shop foreman in order for them to replicate the problem. Has anyone had issues with the b58. I'm scared to drive a car with potential brakes that can't stop the car. I had someone in my family drive the car that has had bmws for over decade and noticed issue right away. How can BMW not fix anything anymore?
What should I do guys? I think it can be air in brake line or brake vacuum pump having issues as did the n20. I've already had a 528 with n20 engine have its brakes fail and thankfully no one got hurt but the axle was broken because brakes completely failed and BMW didn't want to take liability on themselves saying that specific vin wasn't under recall even though that year was. I don't want history to repeat itself. I have to go tomorrow morning to BMW to attempt to replicate problem. Any advise . Thank you. |
09-08-2017, 02:06 PM | #98 |
Bimmer for Life
Rep 26
Drives: 2015 550i (F10/N64)
Vacuum Pump is pumping oil and jerky non-linear acceleration
Hello fellow beemers
I have a 2012 F30 N20 328i and have noticed my vacuum pump oil leak issue is tied to this brake failure issue thread. One or more of you have correctly stated the vacuum pump leak or failure is the root cause of the ultimate issues with the vehicle brakes not the brakes themselves. Well I have found another issues with the vacuum pump that causes another issue and could ultimately lead to brake issues. I discovered an oil leak while I was removing the decorative engine cover and disconnecting the turbo vacuum lines from the cover (see picture below). About a minute after I set the cover to the side the vacuum reservoir under the cover started pouring oil out. When I let it sit over the drain pan I got about 2 tablespoons of oil from the vacuum reservoir tank - disturbing! I have never seen oil in the vacuum lines before so I started to investigate. The lines going from the vacuum pump on the rear of the engine to the plastic cover reservoir and then to the vacuum waste-gate solenoid valve on my 328i. The vacuum pump failure is the root cause to many of the posts in this thread as its primary job is to supply vacuum boost to the brake booster - HOWEVER on the diaphragm waste-gate turbos on the early N20 engines from the 2012 and 2013 model years I seem to have found a pre-failure symptom of the vacuum pump. Most of the threads seem to be later models which have had failures and are also equipped with an electronic waste-gate rather than the vacuum. GOOD news is I called my dealer and BMW has extended the warranty on the vacuum pumps on many cars to 10 years, 100K miles. So check with your dealer to see if you can get it fixed for FREE if you experience either intermittent brake boost lose or an oil leak from the turbo waste-gate vacuum line as pictured here. I did also find a recall for the later model engines for vacuum pump failures for exactly what many are describing as the lose of "assisted brakes". Now to the REAL REASON I was removing my engine cover was for the last few months I have noticed that when under high acceleration the power does not come on and climb with the normal linear feel. When the engine is hot, accelerating hard, and mostly at high RPM the engine surges power. It is hard to explain and the lose or pause in between normal power is very short and does not limit the ultimate power but just appears to hesitate in small burps as I am accelerating. Now that I have found the vacuum line full of oil I believe i may have found my power surge issue. With oil in the waste-gate lines the waste-gate diaphragm cannot release back to the closed position quickly but rather S..L..O..W..L..Y keeping the turbo from a consistent PSI at peak or high acceleration. I will keep everyone updated on if the vacuum pump issue fixes the problem with the power surging as I have been trying to diagnosis this for a few weeks now. |
03-17-2019, 01:58 PM | #100 |
2014 BMW 328i xDrive Certified
Rep 3
I have never had this experience and I have owned a 2011 BMW 328i xDrive and two 2014 BMW 328i xDrive. All BMW's were purchased from the dealer.
09-01-2019, 07:41 PM | #101 |
Rep 1
Brakes
Question, what is the best affordable brake kit for a 2016 435i Gran Coupe M Sport?
I was considering buying the POWER STOP Z26 Street Warrior Brake Kit; any suggestions? |
12-17-2019, 09:46 PM | #102 | |
Rep 1
2018 X1 Brakes vacuum booster issue
------- So glad I found this thread - at least I know I'm not the only one! I had my first ever accident on 11/29/19 after over 3 decades of driving due to the same issue. I was too shocked to even think about the hand break! Thank god my speed was around 40 m/hr and there were no fatalities but both cars are totaled and I've been dealing with the pain of bruised ribs + body and numb arm because of the seatbelt & airbag. I also feel horrible for the moms and kids in the other car but thank god they only have soft tissue injuries. I absolutely love the X1 and this was my 3rd leased one, but I noticed a slow brakes action from the beginning. Then a couple of scary incidents of the brakes first failing and then working after pumping it a couple of times. A couple of days later, on 11/12/19 I took the car to BMW dealership for its first service and complained of the brakes not functioning properly. My car was delivered back to me and I was told my brakes were fine. Now a BMW engineer is supposed to come to investigate the blackbox and cause of the crash but I'm a typical female who doesn't know anything about cars and I'm afraid if I'll be taken seriously since it's my claim against the engineering giant. I just truly hope that the BMW makes sure that this would never ever happen to anyone else. Despite all this, after test driving so many cars, I leased my 4th X1 yesterday. Can I hate all men because of one horrible one? :/ |
08-28-2021, 02:33 PM | #103 |
Rep 7
I have another problem with F31 320d, left front caliper is grabing 1sec slower then right caliper . Driving faster then 80 kph you notice that car is going for 1sec right then is even. I have dissambled, cleaned and lubticate brake pistons, changed front brake lines, changed brake fluid 2 times. Can be that brake caliper at itself has problem?
10-27-2021, 05:09 PM | #106 |
Rep 10,249
Humble suggestion. This question will get more traction if created in a separate thread.
02-03-2024, 02:10 PM | #108 | |
Rep 7
Two or three times in the parking, I think each time with cold start and had to panic shift to neutral and/or use handbrake to stop the car. Few weeks back I had this when it was -20degC outside during driving, and almost reared driver in front. I assumed there was no air in the brake assist since pedal was very hard, but I was able to slow down the car, though very slightly. |
Tags |
brake, recall |
