11-13-2021, 06:17 PM | #1 |
Rep 277
Drives: 2016 340i MPPSK
Bilstein B16 PSS10 Standard Brief Review
Hello folks, I wanted to post a brief feedback for the Bilstein B16 Standard coilovers for RWD. I have seen few reviews for the Comfort version but not many for the Standard. I chose the Standard over the Comfort for the ability to lower 30-50mm vs. 10-30mm on the Comfort. The shorter springs make them a bit firmer ride at the same damper settings, based on what I was told.
Based on available forum reviews, I set the dampers to 4 all around. I believe this is the best damper setting for daily driving. In comparison to the M-Sport 704 springs, the damping is definitely firmer at 4. But it is not harsh at all nor there is a 'crash' sensation over bumps and holes (even compared to the softer M-Sport). Going over humps in high speed, the car does not delay in coming down from humps. It sticks to the ground, therefore there is no longer 'rollercoaster' type of feeling of coming down from the high speed humps, which sometimes makes the car feel unstable. There is ever so slight body roll that I can sense when tossing into a corner at 4, but I feel as though that I have more control during the cornering, opposed to the hefty weight transfer feeling from the M-Sport springs. I had KW V1 in my previous e90, and I can feel the difference in ride quality. Perhaps it is different in the F30, but the KW V1 in the e90 had a harsher feel and it 'crashed' over bumps (albeit no damper settings). I had to send for rebuild twice on my KW V1, in around 30k mile intervals. Hopefully the Bilsteins will not need rebuilding. One thing I noticed right after the install is that the car's handling feels more numb albelt the firmness of the suspension. The dullness of the rubber bushings on the control arms can be felt. My next upgrade will be the VAC monoballs for both upper and lower control arms. I am hoping this will alleviate the numb feeling. I purchased from X-ph and installed at Speedlogic in Fullerton. Great pricing and service from both as always! 12mm & 15mm spacers: Alignment numbers: Last edited by hoonywise; 11-13-2021 at 08:29 PM.. |
11-16-2021, 11:26 PM | #3 |
Rep 205
Drives: 14 F30 335i xDrive
Thanks for a nice review! I feel similar about the xDrive version on my car. I had the KW V3 on my car. I like them, rode well, smooth over small bumps and didn't crash over medium to larger bumps, just absorbed and dampened them out. Felt firm, but not harsh on street with very little body roll. The double adjustable was great for dialing them in on track. But they were way to soft and had a lot of body roll on track. I had them at full stiff and it still wasn't even close to enough for the 200tw tire category on track. Had them for something like 35-40k miles, not sure exactly because I'm notorious for not keeping track of the mileage I do things at. Then I had to take them off because they were in desperate need of a rebuild. Needed something so I got the Bilstein B16 pss10 standard as well. The reasons I got them were because they were available and I needed something quick and I was hoping they'd perform better on track. Haven't tracked it yet so can't comment on that.
Regarding the mono balls, that'll be a huge difference once you get them. Especially if you combine them with a camber plate. You'll start being able to actually feel what is going on with your front tires. (Although tire choice influences that a lot as well) The downside is the rear feels like a big elastic band once the front is all tight. 😂 Enjoy your new suspension! |
11-17-2021, 06:35 AM | #4 | |
Rep 5,400
11-17-2021, 09:08 AM | #5 |
Rep 191,194
Looks great!!
Thank you for the review
hoonywise53.00 |
11-17-2021, 10:14 AM | #6 | |
Rep 277
11-17-2021, 10:22 AM | #7 | ||
Rep 5,400
11-17-2021, 12:48 PM | #8 | ||
Rep 205
I do have sway bar upgrades waiting to go in. I'm doing the h&r front (one of 2 options for xDrive) and factory 15mm rear. I want to keep rear traction high and prefer to balance the car with trail breaking in the track. If the rear bar turns out not to be enough, I'll figure out an upgrade based on how it feels once I've had enough time on track with the setup. But it probably won't be until next year sometime at this point. Too many things in life keeping me from it for the time being. |
11-17-2021, 01:07 PM | #9 | |||
Rep 5,400
FYI- FaRKle is the one who mentioned that tidbit in conversation. We were talking about a buddy's car that had B16's. He said that the B16 spring specs in the front were so high that he would leave the stock front bar as is. But that the B16 spring set would cause the rear to need a higher sway in the 18-20mm range. I've had good luck with the H&R rear 20mm on my car. Obviously you know your car and how you want to set it up. Just passing that along. |
11-17-2021, 01:14 PM | #10 | ||||
Rep 205
johnung4540.00 |
10-15-2022, 02:56 AM | #11 |
Rep 49
Hi hoonywise
Thank you for your good post. i have the same 340i rdw with m sport 704 springs. How much is yours lowered compared to the 704 and how did you set this before assembly. ? . I also want drivability more than looks. I think I can see yours is not lowered to max. I am just to pull the tricker on B16 over the kw v2/v3. because of easy ajustment on the b16 as i see it. and a bit lower price ? Have you tried to go harden than 4 for the track or road , and what did you feel Thanks Last edited by Stampe; 10-15-2022 at 03:12 AM.. |
10-16-2022, 12:20 PM | #12 | |
Rep 277
I hope this helps! Front Rear |
Stampe17.50 |
