02-04-2018, 10:23 AM | #1 |
Rep 1,862
Drives: powered by bootmod3
bootmod3 New Feature Release *** OBD Unlock and OFFLINE Flasher ***
Hey guys, some great news we're really happy to share with everyone of the new BM3 features.
OBD Unlock and the new OFFLINE Flasher (flashing without the need for internet, similar to Spotify downloaded songs you can play offline) features are now live in a wider closed beta. If you’d like to participate in this closed beta testing round let us know through our tech support portal as we’re doing it one car at a time and enable access to the feature on a per user account basis. To get started make sure to download the new OBD Agent version 0.9.42. iOS and Android apps aren’t updated yet so you’d need to use a laptop for this round of testing. Overview of what’s been covered: OBD Unlock: - New convenience option to unlock your DME and tune the car with BM3. The previous bench type unlock is still fully supported. - Unlock DME without pulling it out of the car or sending out for unlock - NO SPECIAL CABLES or hardware required. Uses the same ENET cable still that you can get on Amazon for around $16-20. No waiting time for special cables to be shipped or waiting on us to ship them as they're available through Amazon - Instant activation and OTS map download! No waiting after purchase - OBD unlock for new cars/install time around 260 seconds start to finish instead of 10-50minutes with other F series tuning solutions. - Revert back to Stock and locked. No chance of tamper code showing once flashed back. - No flash counter limitations - our dev cars have been flashed well over 1000 times. This has always been a BM3 feature. - Flash date freeze - unique BM3-first feature, no other tool supports today. Flash date never changes when flashing with BM3. - Flash counter freezes after OBD unlock OFFLINE Flasher: - Flash without internet access - Fastest flash time on F series platform. ~260secs for unlock flash, ~40secs for just a map switch! Others using USB/DCAN cables take 4-5x longer such as tuners using rebranded Frieling (FRC) USB cables and Bimmergeeks or similar USB/DCAN cables with OTG adapters used by some Android apps. - Twin DME cars (N63tu and S63tu) flash at the same time and in parallel and take the same time as single DME cars to flash. Other tools using USB/DCAN cables can only do one at a time due to limitations in connectivity pushing the initial install time and map switch time to well over an hour or 18mins for a simple map switch! - No special cables, hardware Or additional software required, just the standard ENET BMW coding cable that you can get on Amazon for around $16-20. - Whether using iOS and Android apps or just a laptop with a browser, maps are downloaded locally and flashed with no internet connection required. Flashing in remote areas, underground garages, bad wifi, is a non-issue. - Manages map updates automatically in case of tuning (custom) updates and downloads them prior to flashing without users needing to worry about managing it and you can save your downloaded map files anywhere you like (google drive, dropbox, iCloud, etc for backup if you like) - Backs up existing DME coding data automatically without users having to worry about it like with other tools and automatically re-applies it after flashing - The original online-type flasher for the DME stays in place as a secondary option through testing - TCU flashing (GTS flash) requires internet access still but we're looking to move it into offline mode as well. Some dev work that’s still in progress that we’d like to finish this week: - Add obd unlock support for N20, N63tu and the rest of N55. Very quick to do and we expect to finish it this week. - Update flash screen with new progress bars with time estimate countdown - OTS Map updates and new additions to the OTS Maps screen across all F series - Finalize closed beta testing of the above 2 new features There is no additional cost to the end user for any of these features and it is bundled in the cost of a BM3 software license along with all existing features already provided. |
ronanz1819.50 dotjonnL19.50 FSociety3811.50 TR-8R77.00 dr.roro195.50 PabloK597.00 Chicken_Joe606.00 Drpoomanchu307.50 ELiTeNeSs196.50 DragonGate71.50 eluded3005.00 Jadar1752.50 |
02-04-2018, 11:27 AM | #3 |
Rep 1,127
I have had an instance where the dealer flash my DME and I had to go get it unlocked again at my tuner. Can I use the ODB2 unlock if it happens again and will it support my existing custom tunes?
02-04-2018, 12:04 PM | #5 |
Rep 544
So just to be clear one would only have to pay the $595 plus the cable. And that includes an OBD flash no DME removal and a OTS map?
Will there be a Burble option?
2014 435i xDrive M-Sport, Fabspeed cat, Active Autowerke axle back, CTS Turbo intake, ER charge pipe, ER Competition Intercooler, MHD Tuning Stage 2+
02-04-2018, 01:01 PM | #7 | |
IG @bmwF9xG80
3812
Rep 7,593
1) Yes 2) Burble are included in STG2 OTS Maps (can be turned on/off on Map Request) Also they will be working on more development as time goes; allowing user to toggle the Burble via the App. #GameChanger Continues
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
02-04-2018, 01:40 PM | #10 |
Rep 258
Does the car's individual stock dme file get stored when unlocking via obd2 and that is what the stock map flashes back to, or is it a generic stock map? (as i have mmpk and am wondering if i swithc form bm3 ots maps back to stock will my mppk still be there?)
Also, is there any benefits of bench flash over obd2 now that the flash counters arent affected and no tamper codes?
2015 Jet Black F32 435i RWD Coupe - MPPK | MPE | JB4 | M4 437m Wheels | BMS Intake | Wagner Tuning Downpipe | Black Stepped FMIC | Evolution Raceworks Chargepipe | Machnt Schnell Air Scoops | BMS Sport Oil Cooler Thermostat delete | H&R Sport Springs | Best 1/4 et: 12.1s
02-04-2018, 03:57 PM | #12 | |
Rep 732
02-04-2018, 06:12 PM | #14 | |
Gettin It Figured Out
1820
Rep 2,669
Research....Research.....Research I'm partial to PTF's bm3 due to it's flexibility, tuner network and constant game changing/first to market capabilities... http://f80.bimmerpost.com/forums/sho....php?t=1462900 .
FSociety3811.50 DragonGate71.50 |
02-04-2018, 06:39 PM | #15 |
Rep 965
Drives: 2016 F36 435x MSport
my sweet pants expanding.
2010 Mazda RX8 - Sold (11/17)
2016 BMW 435xi GC - Current |
02-04-2018, 06:44 PM | #16 |
Rep 1,805
Good job BM3 guys!!!
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS |
02-04-2018, 07:49 PM | #18 |
Rep 220
Drives: 22 X3 M40i
Garage List 1991 Toyota Pickup ... [0.00]
1997 Nissan 200SX S ... [0.00] 2006 Mitsubishi Lan ... [0.00] 2009 BMW 335i [0.00] 2015 BMW X3 M Sport [0.00] |
02-05-2018, 04:43 AM | #21 |
Rep 2,354
Can be done in the app while you drive.
(A Dane in China) |
DragonGate71.50 |
02-05-2018, 11:25 AM | #22 |
Modder of everything I own
147
Rep 491
Awesome, subscribed!
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
Tags |
bm3, bmw, bootmod3 |
