11-09-2020, 12:22 PM | #2 |
Rep 425
105k and I have spent exactly ZERO on repairs. Most realiable car I have ever owned
11-09-2020, 06:01 PM | #4 |
Rep 1,604
At 115k miles with only two minor repairs...barely broken in Solid engine thus far!
2020 M550i (G30) | Carbon Black/Black Nappa | DHP | DAP | Executive | Luxury Seating | Park Asst | Ceramic Controls | Front/Rear Heated Seats | 20" 668M wheels
2021 X3 (G02) | Dark Graphite Metallic/Cognac | Premium | DAP | Front/Rear Heated Seats Sold/Retired: 2012 328i (F30) |
sspade2464.50 |
11-09-2020, 07:42 PM | #5 |
Rep 1,482
122k 01/15 build.
More reliable than a Camry. No leaks. Only complaint is that the n20 doesn't sound as good as the n55. |
11-09-2020, 09:23 PM | #6 |
David
786
Rep 2,010
Might want to check your valve cover mine started weeping at 35k miles
11-10-2020, 12:20 AM | #7 |
Rep 1,058
Build date 11/12 n20. Car and engine have around 125k on them. No issues other than standard maintenance. (plugs, air filter, fluids, etc). Clutch should be coming soon but it holds FBO stage 2 with ease on the BM3 91/93/E30 OTS tunes.
11-10-2020, 02:20 AM | #8 |
Rep 1,045
Can I compete for the lowest N20 mileage ? My built date is Nov/13, and I just reached 40,000km (24,854 miles) couple days ago. This ongoing covid certainly is putting a stop on driving even more.
Mods: Dinan Tuned, Intake, Catless DP
floridaorange10134.50 |
11-10-2020, 08:40 PM | #9 |
¯\_(ツ)_/¯
945
Rep 1,762
100k, 09/2012 build
- shocks/struts - timing chain/guides - brakes Will be averaging 36-40k miles a year so I should blow by past everyone real fast
11-10-2020, 08:53 PM | #10 |
Rep 130
11-10-2020, 10:00 PM | #12 |
Rep 1,407
Drives: 13' F30 328i 6MT
2013 328i 6MT RWD ( 7/12 Build Date )
Just hit 107k miles and have been tuned since 60k miles, For the most part ZERO issues. I just did my manual trans fluid which was BLACK, The only issue which I have been monitoring is the Timing Chain / Oil pump stuff. I only have an oil pump whine when the cars warming up. Once its warm its completely gone and I do not have a chain noise / issue. I have done a ton of research on here and from what I have found the Oil Pump Whine and chain noise are completely separate issues. You could have one or the other or both, The pump whine I hear is more or less harmless besides the annoying sound and I have even heard that if you replace the pump it will come back. My chain is tight but in the future I may consider replacing it all with the KIT FCP has assembled, Right now theres no reason cars running great.
'13 F30 328i Sport 6MT | '18 G01 X3 xDrive30i | '95 E36 325i Vert 5MT
92 Sentra SE-R SR20DET DET Build Thread 89 E30 325is [sold & missed] |
11-10-2020, 10:04 PM | #13 | ||
Rep 130
11-10-2020, 10:08 PM | #14 |
Rep 1,407
Do you have an Auto or Manual? ( my car is a manual ).
BMW claims its one of their "Lifetime" fluids but if you know cars which Im sure you do thats just marketing BS... I did mine at 107k miles but anytime 75k-100k is prob fine for a manual, It cost me $36 from FCP and took about 30 mins or less to do ( see my post below ). https://f30.bimmerpost.com/forums/sh....php?t=1763206 Super simple and worth the piece of mind, Gonna tackle the diff next.... This has been a great car.
Ajax91552.00 |
11-11-2020, 05:48 AM | #15 |
¯\_(ツ)_/¯
945
Rep 1,762
Some stretching on it using the BMW procedure. Also wanted my engine to be reliable for the 180mi daily commutes
11-11-2020, 07:14 AM | #16 |
Rep 130
What were the symptoms of the TC? Or was it preventative maintenance ?
11-11-2020, 07:22 AM | #17 | |
Rep 130
11-11-2020, 07:59 AM | #18 |
¯\_(ツ)_/¯
945
Rep 1,762
No symptoms so it was preventative, but it failed the test
11-11-2020, 10:44 AM | #19 |
Rep 130
Oh I see. How was the test performed ? Was the valve cover removed? I heard there's some tool to check for tension on the chain or something like that
11-11-2020, 12:28 PM | #21 | |
Rep 1,407
Yeah lol thats makes no sense hahaha
Unfortunately Our N20s are known to have issues sometimes with them and why you need to monitor them and only replace if you feel its going south to avoid a catastrophic failure. Big Chain Threads - https://f30.bimmerpost.com/forums/sh....php?t=1622988 https://f30.bimmerpost.com/forums/sh....php?t=1595693 Chain DIY ( theres an install video as well ) ( very in depth ) - Chain Kit - https://www.fcpeuro.com/products/bmw...-11318648732kt As for your automatic its a ZF8HP and while BMW says ( lifetime ) ZF the MFR disagrees [ 60k intervals ]. Fluid Kit - https://www.fcpeuro.com/products/bmw...-24118612901kt ZF8HP Fluid DIY - ( Full Steps : https://blog.fcpeuro.com/how-to-serv...p-transmission ) Hope this helps, Def search around all this information is out there already.
