12-04-2021, 04:07 PM | #1 |
Rep 46
Transmisson not in park?
As i drove off after a cold start: i got on my dash console "transmisson not in park" and my car engine shut down. I turned it on, drove alittle and it went to same mode again. After 3rd try, i drove off with no issue. Only happens at cold start.
12-04-2021, 09:46 PM | #3 |
Rep 46
I did, 480134 direction of travel cannot be determined. This was random happened about 2 times in last month or so. Would I get a code if it was a bad door sensor? I read that this only happens when door is open and you try to drive. My doors were closed, and after my car turned off 3x in a row with same message…I was fine on 4th time turning it on.
12-05-2021, 09:05 AM | #4 |
Rep 16,079
This seems to be a code that even BMW can't figure out:
This relates to a sporadic fault that can occur in specific situations. No repair measures required. The fault must only be deleted if there is a customer complaint. |
Bmwerspeed1230.00 |
12-05-2021, 09:09 AM | #5 |
Rep 46
So I assume its not related to this. Thanks
