06-19-2021, 03:41 AM | #3873 | |
Rep 2,369
Drives: E63 645Ci
06-19-2021, 03:48 AM | #3874 | |
Rep 2,369
Drives: E63 645Ci
The only other way would be to go to your Bluetooth settings on your phone, set connection with OEM to only phone calls and Android connection to music stream. This is how I would do it on the Android phone, but iPhones are so much more restricted for no apparent reason and you cannot select that - unless something has changed. |
06-19-2021, 08:38 AM | #3875 | ||
Rep 353
PS Also sound quality in this set up supposed to be better than via CarPlay. |
06-19-2021, 07:39 PM | #3876 |
Rep 3
Way to a complete wipe?
Hi Folks, I made the very unfortunate decision to update my Benz NTG 5.0 dLS n600+ firmware to 2.8.6 from 2.5.8. At the same time I upgraded my MCU as well. After that there is no audio coming from the head unit (earlier it all worked fine). From all the troubleshooting it seems to me audio routing or audio driver inside the head unit maybe at fault because all else is working as it should. To try and wipe everything down to zero and start again, I have done downgrades (to 1.2.2 firmware) and upgrades (to 2.3.5) in both firmware and MCU (oldest to newest) but some settings remain the same and are remembered/persist through the updates. I also deleted the config file via ADB but still that did not change anything. I wish to wipe the headunit completely clean and start it as if no one has messed with anything. Is this possible? (else is there way to fix the audio)
06-19-2021, 08:29 PM | #3877 |
Rep 3
Anything sound related is broken
Actually in addition to previous post, something else weird is happening. The android sound level setting app hangs, or does not respond to touch. The native music player app is not able to play any MP3 or FLAC files, it says error playing this file skipping to next one. So anything sound or music related is refusing to work..! All else is working fine ... Is there a way to directly call/contact MEKEDE?
06-19-2021, 11:37 PM | #3878 |
Rep 399
06-20-2021, 09:22 AM | #3879 | |
Rep 3
1. Computer -> USB-DAC -> headphone : sound through headphone 2. Computer -> USB-DAC -> aux-box -> Car USB-AUX: sound through car speakers 3. Head unit recognizes USb drives through both head unit USB ports. FiiO USB-DAC light indicators also show able to connect via USB. USB host enabled. But no sound coming through USB-DAC (the exact setup used to work before I did the firmware 2.8.6 and dGS MCU update, and since then no more) 4. Installed sound restorer app by Snaggly today, checked sound levels of KSW and Android 5. NEW TODAY: Either with phone bluetooth playback or internal memory video playback, Head unit 3.5 mm out -> a small speaker or to aux-box -> car-aux ---------> broken sound output (audio dropping every few seconds, no pattern to drops though) 6. With internal video playback, broken sound (via 3.5 mm) only came from an MKV file (ski resort video) but no sound from an MP4 file (ant-man trailer) playback. Also the playback for both video files is at times choppy (but the audio dropouts are not aligned with video choppiness) 7. .FLAC or MP3 files on internal memory or usb disk are not playable using the native music app. gives an error that file can't be played skipping to next one. 8. The android sound setting (not KSW), takes a long time to open and volume sliders dont respond right away All this tells at least to me that, the hardware is fine, the problem lies somewhere with firmware, codecs etc. Its almost as if there something at the core of media playback and sound output thats messed-up or unsynchronized. Please, any thoughts how this can be fixed? |
06-21-2021, 07:12 AM | #3881 |
Rep 6
Hello everybody!
Is there a way to hide the menu header at the top of the screen? I think I have ever seen that it was possible with an ADB command ... Thanks in advance... |
06-21-2021, 07:35 AM | #3882 |
thecubasekid
Rep 4
Hi Folks,
new forum and new droid HU user here! Hi everyone! I just bought and installed an MSM 8917 Snap 425 HU running Android 10 in my wife's E81 120D (no idrive) and running ID7 in launcher. Pretty pleased with it tbf considering how little i cost me and is a great upgrade to the car, but do have a couple of gripes. For some reason it will not list tomtom as an available app to link to as default nav app (Sygic and others show in the list to link to but not tomtom, even though tomtom works just fine). Do the steps suggested to update factory settings xml on the 625 also apply to the 425 so i can set tomotm to launch as default nav app? My second gripe is the media app. I don't like it. I have Kodi installed for media and very happy with it, is there a way i can link to Kodi from the home page of the launcher instead of the inbuilt media app? Thanks/ Last edited by thecubasekid; 06-21-2021 at 07:47 AM.. Reason: spelling correction |
06-21-2021, 10:51 AM | #3883 | |
Rep 143
https://f30.bimmerpost.com/forums/sh...postcount=4013 |
06-21-2021, 05:41 PM | #3885 |
Rep 2,369
Drives: E63 645Ci
06-22-2021, 05:20 AM | #3886 | |
Rep 2,369
Drives: E63 645Ci
You can try extracting existing factory config file (if it exists and is located in the same place as on SD625 units) buy following these instructions: Code:
1. Create WiFi hotspot in a smartphone 2. Connect Head Unit & your laptop to WiFi hotspot. You need to know headunit's IP address (you can check it in the hotspot settings). You also need ADB on your laptop (you could use folder ADB from either rooting tool or overlay tool) 3. Connect to IP & port of the headunit (default port is 5555): adb connect xxx.xxx.xx.xx:port 4. Get the factory_config.xml: adb pull /mnt/vendor/persist/OEM/factory_config.xml 5. Disconnect anything: adb disconnect Last edited by RedErik; 06-22-2021 at 05:36 AM.. |
06-22-2021, 09:50 AM | #3887 |
thecubasekid
Rep 4
Thanks for the reply and advice!
will have a go at getting adb working. My unit was advertised as SD425, i did see the 450's advertised but didn't get one of those. i also asked the seller (Navifly) if they could send me the default factory config for my unit as i guessed if not identical, it likely would have an equivalent to the 625, Navifly have been fairly responsive to my questions although tbf i worked out my issues my self as they mostly didn't seem to grasp what i was asking, but at least they replied and tried to help. Remains to be seen if they will actually send me one... i was sort of expecting to be on my own to some degree, as i got an OEM looking HU for my 330ci E46 about 4 years ago from Aliexpress and had to work it all out - that unit was pretty flaky initially however, after lots of work / flashing diff things and sorting the apps out turned out to be fantastic, allowing me to use Nova launcher, custom boot logo and steering controls working in all apps, not sure i will get so far with this one but we will see. was planning to get one for my F10 but am holding off now to see how good i can get this one in the wife's car going! Last edited by thecubasekid; 06-22-2021 at 10:00 AM.. |
06-22-2021, 11:30 AM | #3888 |
Rep 40
Hi guys, need some help. I just installed a front camera (dvr input) and the "F_CAM" app works. However, I didn't find any other app that will recognize the camera.
A. Are there other apps or configuration that can work with the dvr can other than "F_CAM" ? I tried many on the app store but none can connect to the camera. B. If the answer to A is no, i use a different launcher but can't access the "F_CAM" app for summer reason. (maybe system shortcut?). How can I export/download the app to use in the new launcher? Thank you! |
06-22-2021, 05:05 PM | #3890 |
Rep 1,048
I checked the update in comparison to 2.8.6, this version 2.9.4 is from 9th July 2021.
This Update is very buggy / beta like , so if your system is running fine, i don`t recommend to update to 2.9.4 ! However if you still want to Update it can be found here: https://mega.nz/folder/kIB3CSZD#wnqmCQnF8i7VW1yIEvz66g Code:
ro.build.display.id=Ksw-Q-Userdebug_OS_v2.9.4 ro.build.version.incremental=eng.zlx.20210609.115043 ro.system.build.date=Wed Jun 9 11:50:25 CST 2021 ro.system.build.fingerprint=qti/msm8953_64/msm8953_64:10/QKQ1.191008.001/zlx06091150:userdebug/test-keys
Kri |
06-23-2021, 02:48 AM | #3891 | |
Rep 353
06-23-2021, 03:01 AM | #3892 | |
Rep 353
If nothing helps then more likely it is a hardware issue inside android HU. Then you can try to reconnect 12V power to android from ACC fuse/wire as an option and see if that works. |
06-24-2021, 01:29 AM | #3893 | ||
Rep 40
there should be an Android up for the dvr av(?) connection, or a way to create a shortcut to f_cam? that app works well for me but limited. any help with either options would be greatly appreciated. and I use smart launcher which I recommend. very clean, main all icons on the side, accessible via controller wheel. |
06-24-2021, 01:34 AM | #3894 |
Rep 40
FYI, if you're thinking about getting an Android 10 hu and don't want to wait a month I recommend the Pemp 64/4gb. Great unit and can be had for $450 after $50 discount.
https://www.amazon.com/dp/B08VHVSHY1...PM5ZGPMBFPQ35E Last edited by 30secs; 06-24-2021 at 03:40 PM.. |
