11-11-2018, 02:09 PM | #1 |
Rep 1,862
Drives: powered by bootmod3
*** bootmod3 *** New Feature Release - Map Configuration options for ALL maps
Hey guys, we've pushed out a new release Friday enabling end users to configure map configuration settings not just for OTS maps but all maps including stock as well as custom maps
This has been requested in the past for people that would like to create for example a Stock Tune with just CEL, VMAX and burble overrides and run with that during winter months for example. In some cases people wanted to try customizing burble themselves using the config screen on their own maps as well as custom tunes they've worked on in the past which is now a possibility as well. Original map settings are always kept in tact as well so you can go back to them if needed. Version 0.10.039 of the system is already up on the Web at www.bootmod3.net. iOS and Android app updates are on the way out and should be available very soon as well. In the attached screenshots we're showing a sample stock map with the config button and options on it. Have a great rest of your Sunday, all the best
YouTube Channel [NEW] | Facebook User Group (20,000+ members) | Tech Support Website | Wiki | FAQ | iOS App | Android App | bootmod3 Web
Sales Support Email: sales@protuningfreaks.com | Tech Support Email: support@protuningfreaks.com |
11-11-2018, 02:28 PM | #2 | |
Rep 657
Current: 2017 Bmw 540i M sport bluestone metallic
Previous:F30 328i 2012 PWG: FBO Vrsf 6 stepped fmic, Afe intake, Catless DP ER, FTP CP's, FTP turbo inlet, GFB DV+, Gplus oil cooler, BM3 stg 2 tune, Cary Jordan E50 tuned stock fuel system. |
11-11-2018, 09:06 PM | #3 | |
Rep 325
Drives: 2016 F36
◊ 2016 F36 xDrive N26 ◊ Black Sapphire Metallic ⁞ Dakota Black ◊
║ VRSF HD FMIC ║ ER DP custom paint ║ AWE cat back Exhaust Suite ║ NGK Plugs ║Bootmod3 Stage 1 93 ║ GFB DV+ ║ BMS 10mm Front ⁞ 12mm Rear Spacers ║ P Style BSM Rear Spoiler ║ Smoked Front Reflectors ║ Madico Onyx 20 Tint ║ LCI Lighted Trim Bezel ║ Opti-Coat Pro+ ║ |
rjd_F301999.50 |
11-15-2018, 02:35 PM | #4 |
Rep 133
Hi all!
I have a question, I am currently working with a Stage 1 N20 engine, in a BMW 428i GC (F36), I have a little doubt. My idea is not to move to a Stage 2, since I will not install neither downpipe nor high flow catalyst, but I love the Pops And Bangs, in the following picture, which is my current configuration. My fear is this: What aggressiveness do you advise me not to damage my catalyst oem? Is it very high now? What would you advise me to be the right one? both in time, as in aggressiveness, thank you very much! A greeting! |
11-15-2018, 03:10 PM | #5 | |
Rep 3,680
11-15-2018, 04:41 PM | #6 | |
Rep 133
That's why I want to try to get an optimal configuration trying not to damage the catalyst. The pops and bangs OEM are very lights for my taste, I recognize that the current ones are quite strong and forceful. I currently have Turbo-Back remus and M Performance sports exhaust modified internally to increase its sound. I know I have to re-flash again and I want to leave it already good so I do not keep flashing continuously. I hope someone will guide me a little along this path to know how to leave it well. |
11-15-2018, 04:57 PM | #7 |
Rep 348
Great update! However, I have a very annoying issue I hope you can fix in a future update. Whenever we go to adjust the settings in map config, it does not show the actual values, it wont show you until you touch the little circle adjusters. Every single time you touch one of those circle adjusters, it would change your settings and jump to a different value immediately, I tested with an iPhone, iPad and computer(a lot easier to work with but still happens). Is it possible to make the values appear with first press instead of being immediately adjustable or the second(or hold/long touch) touch to unlock the adjuster? Maybe I'm the only one with this fat finger issue but I hope this is important enough to look into, I really look forward to a fix.
Keep up the great work! Thank you! |
11-15-2018, 05:06 PM | #8 | |
Rep 3,680
Good luck
11-16-2018, 08:29 AM | #9 | |
Rep 133
It does not always make shots type AK47, only in strong reductions where the engine exceeds 4,600 rpm, if you drive normally and release the pedal at about 3,400 rpm, there are loud detonations without getting the shots. Attached a video of shots with the programming of STOCK and Burbles in Stock In stopped with the Sport or Sport + mode if you always do it but it is because of the configuration of the turbo that opens the electric westgate and ... better to get rid of behind is not going to mess someone jejej. |
11-16-2018, 09:31 AM | #10 | |
Rep 3,680
11-16-2018, 11:40 AM | #11 | |
Rep 133
In this all modes I say, here was not made the flashing of BM3 is completely stock. And in this other is in aggressiveness 4, 0.2s - Comfort, 1.3s - Sport What do you think ?, if of Stock you hear shots jajajaja, that's why I'm a mess. ashamed0002: Last edited by spirit3d88; 11-16-2018 at 11:54 AM.. |
11-16-2018, 12:50 PM | #12 | |
Rep 3,680
Cn_flame5.00 |
11-16-2018, 01:52 PM | #13 | |
Rep 133
By having the latest version, he started doing this. Well, I'll lower the aggressiveness then because otherwise ... jajaj I see myself without a catalyst |
rjd_F301999.50 |
bm3, bootmod3 |
