BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > NBT EVO ID5 Bootloader failed
      05-17-2021, 04:43 PM   #1
RuleNormaliai
RuleNormaliai's Avatar
235
Drives: 2022 G20 330E
Hello, does anyone here have experience with HU NBT EVO failed bootloader?
my EVO failed while flashing the bootloader, now when i power it on it just cooler fan is blowing full speed, and i can't see it in ista or esys, so as i know i have to connect it directly with putty, but i don't know any commands to execute.
can anyone help me with that info?
ofcourse i'm willing to pay for valuable info
i have bench setup, tomorrow will get UART adapter.
Thank you in advance!
      06-11-2021, 02:08 PM   #2
Bmwf31drw
Andrebmw
Italy
Drives: BMW f31 luci touring
Did you solve It out? I have same problem.. i have USB uart and tried already with putty
      06-12-2021, 01:57 PM   #3
Wibbles
Coding ECU's remotely
Wibbles's Avatar
445
Drives: M3LR
try pinging 169.254.199.99 - if no response then you have issues, otherwise it should flash with esys
      06-12-2021, 07:23 PM   #4
Bmwf31drw
Andrebmw
Italy
i can still ping at 169.251.199.99 if i open transmitter i can send hard reset and the evo reboots i can read actual state bootloader etc..so the connection it's good.. i tried to flash but It fails.. i cant even see the hu in esys when i read ECU..tried with oabr to rj45 and with zgw via uds..but i still dont see the hu in esys..the fun full Speed i think because of the missing bootloader dump..can you help?
      06-13-2021, 10:53 AM   #5
Wibbles
Wibbles's Avatar
445
Drives: M3LR
Which version of esys and psdzdata are you using?
      06-13-2021, 02:38 PM   #6
goonar
Drives: F30 328i
You likely can recover it if you have HU Engineering Tool or the newer version of HU Tool. Happened to me when hacking an evo id4 to id6. Just sent the command to fully wipe the unit and boot loader, then reflashed the completely wiped unit. If you don’t have the tools to try with you may be able to find someone on here willing to send you a remote command execution with hu engineering tool.
      06-14-2021, 02:49 AM   #7
Wibbles
Wibbles's Avatar
445
Drives: M3LR
Send me a PM I can send you a HU Engineering code to clear the V850, then you can flash any bootloader version you want.
      06-14-2021, 12:48 PM   #8
Bmwf31drw
Andrebmw
Italy
Esys 3.30.1 psdzdata 4.28.41..
      06-14-2021, 01:07 PM   #9
Bmwf31drw
Andrebmw
Italy
bimmerpost doesnt allow me to send pm's maybe because in new ..Hope bimmerpost fix this issues..
      06-14-2021, 02:17 PM   #10
Wibbles
Wibbles's Avatar
445
Drives: M3LR
I have sent you a PM
      11-09-2021, 02:21 PM   #11
aggelosxr
aggelosxr
Greece
Drives: bmw m3 e30
hello RuleNormaliai,trying to send you pm for an eys coding that i will need on a vehicle but bimmer forum not allows it ,perhaps because i am new user.
If you can help i will appreciate it and also with a fee.
Have ista+,esys,charger on vehicle and teamviewer.
Thanks
      11-14-2021, 06:16 AM   #12
RuleNormaliai
235
Thanks
you can contact me by email
info(AT)bimmlab.eu
| MGU Patching/Virginizing | ConnectedDrive activation for US cars in EU (Only MGU/ATM2) | Feature Installer codes | Map Updates | CarPlay activations. | NBT EVO GPS Connector installs. | NBT EVO repairs | Remote BMW Coding |
      08-08-2022, 01:54 PM   #13
niter
Drives: Mini countryman SE
Hi
Its an old thread but could you send a HU engeneering code to me awell?
Thanks
      08-09-2022, 04:22 AM   #14
Wibbles
Wibbles's Avatar
445
Drives: M3LR
Originally Posted by niter View Post
Hi
Thanks
Send me a PM with your full 17 digit VIN and I can supply a code.
      08-09-2022, 04:43 AM   #15
maaii11
Drives: Mini F54
Hello
Maybe be you can read this
https://cartechnology.co.uk/showthre...3664#pid503664
use tool32 to fix it
ISTA release note
4.3 * NEW * HU-H2 - Note about repair measure
Fault description:
When programming a vehicle with HU-H2 NBTEvo, a note is displayed about a HU-H2 programming failure.
Model series affected:
Vehicles F0x, F1x, F2x, F3x, F4x, F5x, F6x, F8x, F90, G0x, G1x, G3x, I01, I1x, RRx with HU-H2.
Measure / Workaround:
1) Follow the note and carry out the repair measure (service function) for the HU-H2. This can take up to 20 minutes.
2) Calculate and execute measures plan.
Pay attention to final work.
Fault corrected by:
HU-H2s from a limited production period are affected by the fault. Please observe PuMA measure 64862978.
Affected application:
ISTA 4
      08-10-2022, 12:24 PM   #16
niter
Iam not allowed to send PM. Can i send email?
regards
      08-11-2022, 04:12 AM   #17
Wibbles
Wibbles's Avatar
445
Drives: M3LR
regards
I don't give out my email on public forums, sorry
