BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Cell phone mount f30
      02-05-2017, 07:54 AM   #45
Brenzo
Brenzo's Avatar
Drives: 2015 M235i xDrive
Add me to the ProClip camp. They are great quality and lots of different mount and holder options.
I've had one in my past 4 cars. I prefer the vent clip even though it partially blocks my passenger's vent the 0.5% of the time I have a passenger in my car.
      02-21-2017, 09:49 PM   #46
etinifni
etinifni's Avatar
Drives: 2012 328i Modern Line
Have any of you that use the iOAuto Pro mount had an issue with the steel disc glue not holding to the back of your phone? The magnet on the dome is so strong that when pulling phone off the mount the disc that is supposed to stay attached to back of phone is peeling off and staying connected to the magnet. I've ordered a couple replacement discs & stickers but this seems like an ongoing issue. I'm wondering what glue to try and use because these replacement discs are not cheap relatively speaking.
:wave:
      02-23-2017, 11:26 PM   #47
barzul
barzul's Avatar
Indonesia
135
Drives: F30 Black Saphire
2016 BMW 320i  [10.00]
spigen vent mount ... works best for me
      05-07-2017, 03:38 PM   #48
Pr3dict
Drives: '17 340
but if you have the heat on in the car doesnt the heat blow right onto the back of your phone?
      05-07-2017, 04:28 PM   #49
tex2670
tex2670's Avatar
Drives: '23 X1 28i xDrive
Roll the wheel and close the vent.
      05-07-2017, 04:31 PM   #50
Pr3dict
Drives: '17 340
Haha so simple - times like this cause me to rethink if I'm worthy of driving a BMW.
      07-27-2017, 01:41 PM   #51
rogersmj
Drives: 2016 340i M-Sport
Found this thread when searching for a clean solution for mounting my iPhone. I've used vent mounts in other cars, but in the f30 I don't like how much it blocks my access to other controls/the main screen.
I have used ProClip in the past and they make a good product, but again I don't care for their position options in the f30.
Have you guys seen this cupholder dock at https://www.joli.design/ ? Has anyone used it?
I think I could run a charge cable into the bottom of the cupholder and into this dock. The phone would be mounted a little lower than is ideal, but at least it wouldn't be blocking other controls.
      07-27-2017, 02:53 PM   #52
blackf30n55
Drives: 2014 335i Msport
Wiz gear magnetic vent clip. 8 bucks on amazon
tex26702412.50
      07-27-2017, 03:06 PM   #53
jmg
jmg's Avatar
18704
Drives: G82 M4C X-Drive
2022 G82 M4C X-Drive  [9.85]
2018 F80 M3 CS  [9.87]
2019 i3 BEV  [0.00]
I can't stand vent clips. Why block a functioning vent for a phone? Ditto on cup holders.
Looks tacky to me. I also don't like loose wires hanging around, so anything that mounts on the top of the dash that leaves dangling wires is also a no-no.
Kuda mount is the only one I have found that looks OEM, is in a good place, and doesn't get in the way of anything. Couple that with a proclip swivel mount with a built in plug and its also the most painless way to get in and out of your car. Just drop it in and it's powered. Plus the wire is easily hidden under the trim and plugs into the lighter under your glovebox. Pretty much the most invisible mount I've come across. I've used it in my 340i and my M3:
Glamour shot:
20170201 - Interior - IMG_8787_100 by JMG, on Flickr
Dirty shot:
IMG_2592_100 by JMG, on Flickr
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing
Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3
IG: Raging_G82
BMW11279.00
Pauloxxi339.00
      07-27-2017, 04:43 PM   #54
rogersmj
@jmg So you just screwed the ProClip directly into the Kuda?
      07-27-2017, 07:23 PM   #55
jmg
jmg's Avatar
18704
2019 i3 BEV  [0.00]
Yes, but I honestly don't remember if it was pre-drilled or not if that is what you are asking. I was very easy to install the proclip into it and the Kuda is very, very solid.
IG: Raging_G82
      07-29-2017, 04:23 AM   #56
DrifterX
DrifterX's Avatar
Drives: 2016 340i M Sport 6MT+RWD
This - no use for a CD drive in a car anymore when you can plug in your phone for all the music you could ever listen in a car. I'll take a pic of how the mount looks in my car when I get back from vacation
https://www.amazon.ca/Spigen-A230-Pr...igen+car+mount
2016 Estoril Blue II 340i M Sport | ///MPPSK | 6MT | RWD | Fully Loaded
BM3 Stage 2+ 93 | B58TU HPFP | VRSF v2 Catted Downpipe | 550i Clutch
      07-29-2017, 10:29 AM   #57
jmg
jmg's Avatar
18704
2019 i3 BEV  [0.00]
I actually use the DVD every single day, with DVDinmotion coded. Also, you block many of the controls with the CD mount
IG: Raging_G82
      08-03-2017, 11:13 AM   #58
rlmesq
Drives: 2018 440i M Sport
Anybody have the approximate dimensions of the flat front area of the Kuda mount? I'm thinking about getting one to hold the display and controller for my Beltronics STiR+ integrated radar detector.
      08-03-2017, 12:29 PM   #59
jmg
jmg's Avatar
18704
2019 i3 BEV  [0.00]
I'll measure it next time I'm in the car.
IG: Raging_G82
      08-03-2017, 12:31 PM   #60
MachinesWithSouls
MachinesWithSouls's Avatar
Drives: 2022 M3 6MT
2022 BMW M3  [10.00]
Originally Posted by Hack14 View Post
ProClip is definitely a great choice. However, in the past few years I've been using Ram Mounts in all my vehicles.
Right now I'm using a Ram Mount cupholder mount with a small arm and Xgrip cradle, but they have a plethora of mounting options available for every vehicle. All of which are customizable for different locations and with differents sized arms, balls and cradles.
You should definitely give them a shot, they're incredible.
http://www.rammount.com
I second that. Used it for 2 years now. Fell off maybe twice, and that's because I attached it to the windshield.
2022 M3 6MT - Portimao Blue Metallic
2022 X3 M40i - Tanzanite Blue Metallic
      08-03-2017, 01:16 PM   #61
BMW11
Drives: M340
Glamour shot:
Dirty shot:
that Kuda Mount looks like a great solution. How does it actually attach to the car in the position you have it?
      08-03-2017, 01:49 PM   #62
jmg
jmg's Avatar
18704
2019 i3 BEV  [0.00]
Pressure mounted, no drilling, and VERY solid. I've installed and uninstalled it in two F30s and my F80, no problems.
Here are the instructions:
http://www.kudausa.com/manuals/092585_kuda_mount.pdf
Basically, pull back the trim a bit, insert the mount, bend this metal plate attached to the mount to lock it in, and push the trim back into place.
IG: Raging_G82
BMW11279.00
      08-03-2017, 02:02 PM   #63
BMW11
Drives: M340
thanks for the info
      08-03-2017, 04:47 PM   #64
rlmesq
Many thanks! I'll post pix of the install if it works out.
      08-03-2017, 10:19 PM   #65
d_a_m
d_a_m's Avatar
Drives: 2013 BMW 328i
I started using this.
https://www.amazon.com/dp/B01MR4AO9D..._hB-Gzb0900F0R
You use the 2 sided 3M tape (included), stick it somewhere on the dash and you're good to go. You don't have to worry about taking up a vent or having it too low and away from your view. It's magnetic, so be careful with pulling your phone off too hard which can pull the sticky part.
///437m wheels///Depo Headlights ///3M 1080 Carbon Fiber Interior Wrap///M-Sport Bumper Conversion///Dinan Suspension///M-Style Kidney Grilles
"If we knew what it was we were doing, it would not be called research, would it?"
      08-04-2017, 10:34 AM   #66
jmg
jmg's Avatar
18704
2019 i3 BEV  [0.00]
My iPhone is in my pocket with my wallet. Is what's on the iPhone a magnet, or what's on the mount? I don't want magnets near my wallet.
IG: Raging_G82
