BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Hard acceleration stutter - 2015 335xi MT
      08-24-2021, 03:40 PM   #23
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
Originally Posted by redbullfan View Post
My symptoms were still there with x-Delete. My mechanic told me that the clutches inside the transfer case still bind and will have the same behavior. I just picked up a new transfer case and am getting it installed on Thursday. will update if my issues is gone.
My symptoms went away with xDelete which makes me think I probably have some mild wear on the output shaft and/or flange. Your issue might be far more serious than mine if you're hearing metallic noises and the symptoms persist even after disabling xDrive.
      08-25-2021, 09:31 AM   #24
redbullfan
redbullfan's Avatar
356
Drives: 22 TR X3MC
2022 BMW X3MC  [0.00]
Considering you have a 328D I would look into taking your car into the dealer since I'm pretty sure theres an open recall for the transfer case
2022 X3M Comp
2013 335i xDrive (Sold)
      08-25-2021, 10:04 AM   #25
AndrewC1989
Already did last year and the car checked out, but that was before the symptoms appeared. They're not bad enough to replicate regularly yet so I'm waiting till they're worse to go back again. I'm out of warranty and don't want to show up and pay a $165 diagnostic fee just for them to tell me they didn't notice any issues.
      08-25-2021, 01:21 PM   #26
redbullfan
redbullfan's Avatar
356
Drives: 22 TR X3MC
If it's not happening that often, the cheapest thing to do first is changing the fluid and see if that helps.
2022 X3M Comp
      08-25-2021, 06:01 PM   #27
AndrewC1989
Changed the fluid, flex disc, and output flange about 17k miles ago. Probably bought me some time but still feels like I'm driving a ticking time bomb. Once symptoms become more frequent I'll take it in.
      10-16-2021, 02:34 PM   #28
AndrewC1989
Update: changed the transfer case fluid (again) at 70k, and did the rear diff fluid, transmission fluid/filter, and accessory belt and tensioner while I was at it. The car feels much smoother now. The transfer case stutter is still there occasionally (only when I'm WOT above 60mph) however It's much more subdued and it's not nearly as bad as it used to be. Definitely a large and noticeable improvement. Hopefully, I can just keep doing a fluid change every 2 years and never have to actually address it.
      10-16-2021, 11:54 PM   #29
SoCalM235iR
Drives: M235iR
To the OP. I had multiple coils fail from about 30K on and they didn't always have catastrophic failures that threw codes.
At least two times I had issues only under hard acceleration and full boost, but no codes. It took as much as a full month later for a fault that produced a code. Replaced that coil and the problem you describe went away until the next coil failure. I replaced them all and that situation hasn't occurred.
With a stock tune the peak boost might occur in that range you're having the problem.
Not suggesting shotgun repairs but coil failure is very common.
      10-17-2021, 02:53 AM   #30
imperfectluck
imperfectluck's Avatar
427
Drives: 20' F87
+1 to this as I had a coil pack that was causing issues under hard acceleration also. I had done the plugs recently and knew it wasn't the problem and it rang to me that I never did coils on the car ever and she's now sitting with 82k miles (surprised I made it this far without noticing it along the way). After changing all six, the car hauls ass again and makes me smile a little more.
      10-22-2022, 08:41 PM   #31
bryannichelson
Drives: BMW 335i
I have the same stutter issue on hard acceleration. Only when I get aggressive with the throttle. 2015 6 speed, intake, charge pipe, intercooler, muffler delete. Replaced plugs and it got better. Found a missing bolt on charge pipe sensor and replaced it and again made it better but still stutters when I get hard on the throttle but 2nd gear is the least affected. I'm going to keep looking for boost leaks but at a loss of the main issue. please help.
      10-23-2022, 04:47 PM   #32
thejeremyman9
thejeremyman9's Avatar
4364
Drives: 2015 BMW 335i
Pressure/smoke test and post logs
      10-24-2022, 01:48 PM   #33
akgambino
Drives: 2013 F30 335xi M-Sport (PWG)
Post a log, could be clutch slipping (super common issue with tuned 6mt n55)
2013 F30 335i xDrive M-Sport 6MT (FBO/BM3 custom tune by HCP, 91 oct, 550i clutch, xDelete)
      11-08-2022, 04:19 PM   #34
cup4leafs
Drives: bmw 335i
Did anyoen get a resolution to this?
I see this issue on all of the forums and I'm having the same issue.
I have replaced the plugs and coils and ran a smoke test and fixed two leaks I found.
I suspect that its either fuel pressure or an injector but before I start going down the expensive path of replacing injectors or high pressure fuel pump I wanted to see if anyone had any success with other updates.
My car:
2011 335xi
m-sport
6MT
MHD
Updated cp, intake, dp, dinen coils, plugs, GFB DV
      11-08-2022, 06:00 PM   #35
thejeremyman9
4364
My car:
2011 335xi
m-sport
6MT
MHD
Scan for codes and post datalog(s). Fuel issue would definitely show up in a log. Clutch slip usually does too if its significant at all. Also what intake?
