BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Stage 2 93 log
      09-25-2021, 05:03 PM   #1
Bloom_435i
Bloom_435i's Avatar
Drives: 15' 435i xdrive
Stage 2 93 log
Does everything look good in this log. https://www.bootmod3.net/log?id=614f...0b4356468f7cd6
      09-26-2021, 07:38 AM   #2
MadToy
Drives: '18 340i Xdrive
Looks good except for timing on Cylinder 6. Lagging behind the rest by several degrees across the board. I'd check the plug on that one. 4 is a bit off too, but not as much as 6.
2018 340i F30 Xdrive
      09-26-2021, 11:33 AM   #3
Bloom_435i
Bloom_435i's Avatar
Yea I was looking at that too, I already ordered ngk plugs
      09-27-2021, 12:55 PM   #4
thejeremyman9
thejeremyman9's Avatar
4364
Drives: 2015 BMW 335i
Unless its consistently the same cylinder(s) in multiple logs its probably fuel quality.
Also why NGKs and not new OEM bosch? Cause PTF said so?
      09-27-2021, 02:42 PM   #5
Bloom_435i
Bloom_435i's Avatar
Because I'm going to a e30 tune down the road so I'm getting 1 step colder ngk plugs. I'll do another log today and see if the results are the same
      09-27-2021, 03:33 PM   #6
thejeremyman9
4364
That's not a reason to change plugs though. I run OEM bosch OEM gap, as do many others, on both upgraded turbo and stock turbo, pump gas and ethanol maps, with or without meth, etc... no reason to change unless you have problems with OEM as you can just cause other issues... Even my 45k mile OEM plugs that were never changed worked on MHD stage 2+ E20 map with E30.
      09-27-2021, 05:24 PM   #7
Bloom_435i
Bloom_435i's Avatar
My car has 55000 miles and the plugs have never been changed, if the car runs terrible with these new plugs I'll get a set of Oem plugs
      09-27-2021, 05:50 PM   #8
MTWO
Drives: M2
Maybe an injector as well or carbon buildup in that cylinder
      10-11-2021, 05:36 PM   #9
Bloom_435i
Bloom_435i's Avatar
New plugs and possibly fixed the boost leak
https://www.bootmod3.net/log?id=6164...0b435691c48c17
      10-11-2021, 06:19 PM   #10
thejeremyman9
4364
Which plugs?
Looks pretty solid. I wouldn't rev above 6400 though. It's unnecessary, and that's where you start to get timing corrections and the "wavy" WGDC and boost ive seen in other logs as well.
      10-11-2021, 07:13 PM   #11
harkes
harkes's Avatar
China
1078
Drives: M135i, E39 M5, NSX and AE86
I'd be happy with that
(A Dane in China)
      10-11-2021, 07:41 PM   #12
MadToy
What gas are you running now? I'm thinking it's not the same as the previous log.
And I'm also on the stock plugs are better side. After several N55's and big turbo Audis, chasing timing drops was a nightmare. But I always ended up with the best results on stock plugs, with stock gap. Even with the big turbo - and dozens of plug changes :/. Best way to know is by running 3 or 4 logs and see if the drops are consistent.
1-4 plugs are simple to check quickly if desired, but really not necessary without seeing a pattern.
      10-11-2021, 09:29 PM   #13
Bloom_435i
Bloom_435i's Avatar
In both logs I was running 93 gas but from different stations. My old spark plug were never change since now. My car is at 56000 miles now. Im now on ngk plugs gapped at .022 and the car is running better
      10-12-2021, 10:07 AM   #14
5w20
@_sunbish
5w20's Avatar
282
Drives: Bmw 435i & 340i
In both logs I was running 93 gas but from different stations. My old spark plug were never change since now. My car is at 56000 miles now. Im not on ngk plugs gapped at .022 and the car is running better
now or not
      10-12-2021, 12:48 PM   #15
Bloom_435i
Bloom_435i's Avatar
now or not
Now my bad 😭
      10-12-2021, 01:48 PM   #16
Serwis44
How many kW stage 2 N55 ?
      10-12-2021, 01:51 PM   #17
thejeremyman9
4364
More than stock
      10-12-2021, 03:30 PM   #18
Bloom_435i
Bloom_435i's Avatar
Originally Posted by thejeremyman9 View Post
Originally Posted by serwis44 View Post
how many kw stage 2 n55 ?
more than stock
      10-12-2021, 05:26 PM   #19
n55david
n55david's Avatar
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
11teen more than stage 1.5
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
