10-13-2021, 02:54 PM | #1 |
Rep 80
What should I do to fix this?
Bootmod3 sent me this when I sent them my log about 2 knocks.
"Looks like you have misfires up top near redline. AFR is super unstable and STFT (fuel trims) too. Also, are you at high elevation? Did you gap your spark plugs?" I'm going to go ahead and change my sparks and make sure there gapped right and install a PR ignition kit. Also used a liqui moly speed tec gasoline additive if that has to do with anything. 2014 m sport 435i rwd fbo upgraded turbo VRSF Chargepipe, vrsf race fmic, and hi flow downpipe BMS aluminum elite intake Stage 2H 93 bootmod3 ngk Cold spark plugs oem ignition coils Vargas stage 1 upgraded turbo 92500 miles xHP stage 3 transmission tune |
10-13-2021, 03:13 PM | #2 |
Rep 7,598
Isn't this a follow up to another thread you posted with said logs? You don't need to keep creating new threads. I can see you have started 20 threads and have only 55 posts which is crazy and just creates clutter and makes it more challenging for people to follow along and provide good responses when most of them are related.
Enough forum policing... I am pretty sure i commented on the same thing near redline on that log and said not to rev that high. Post the logs you are talking about. And answer their questions. |
10-13-2021, 03:24 PM | #3 | |
Rep 80
https://www.bootmod3.net/log?id=6164...729b7f195b5001 |
10-13-2021, 03:41 PM | #4 | |
Rep 7,598
